What happens when Formlabs retires a material formulation?
Formlabs will give at least three months of notice before retiring a material during which users can still make ongoing purchases. Depending on material popularity, the sunsetting period may be longer than three months to give users more time to transition. When a new version of a material is released, both versions will be sold in parallel for a period of time. In some cases, a material may be retired without a direct replacement available.
If the new version of a material is only supported on the newest generation of printer, the old version of the resin will remain available on the legacy printer generation for as long as the printer is actively supported, or Formlabs cannot support making the material anymore.
Example: Formlabs releases Tough 1500 Resin V2, which is only compatible with Form 4 generation printers.
  • Tough 1500 Resin V1.1 is sunset on Form 4 generation printers since it is replaced by a new version.
  • Tough 1500 Resin V1 remains on Form 3 generation printers for as long as there is ongoing support for that generation of hardware.
Formlabs material sunsetting roadmap (2023 to present)
Material Compatible printers Last available date Replacement material Replacement available on:
Dental LT Clear Resin V1 Form 3/B/+
Form 2
12/1/23 Dental LT Clear Resin V2 Form 4B
Form 3B/L/+
Form 2
Ceramic Resin V1 Form 2 12/31/23 Alumina 4N Resin V1 Form 4/B
Form 3/B/+
Denture Teeth Resin V1 Form 3/B/+
Form 2
12/3/24 Premium Teeth Resin V1 Form 4B/L
Form 3B/+
Form 2
Elastic 50A Resin V1 Form 3/B/L/+
Form 2
3/17/25 Flexible 50A Resin V2 Form 4/B/L
Form 3/B/L/+
Polypropylene Powder V1 Fuse 1+ 30W 5/16/2025 None N/A
PU Rigid 650 Resin V1 Form 3/B/L/+
Form 2
8/8/2025 None N/A
PU Rigid 1000 Resin V1 Form 3/B/L/+
Form 2
8/8/2025 None N/A
Black Resin V4 Form 3/B/L/+
Form 2
12/31/2025 Black Resin V4.1 Form 3/B/L/+
Clear Resin V4 Form 3/B/L/+
Form 2
12/31/2025 Clear Resin V4.1 Form 3/B/L/+
White Resin V4 Form 3/B/L/+
Form 2
12/31/2025 White Resin V4.1 Form 3/B/L/+
Tough 1500 Resin V1.1 Form 4/B/L 12/31/2025 Tough 1500 Resin V2 Form 4/B/L
Temporary CB Resin V1 Form 3B/+ 3/1/2026 Premium Teeth Resin V1 Form 4B/L
Form 3B/+, Form 3BL
BEGO™ VarseoSmile® TriniQ® Resin V1 Form 4B
Permanent Crown Resin V1 Form 3B/+ 3/1/2026 BEGO™ VarseoSmile® TriniQ® Resin V1 Form 4B
Castable Wax 40 Resin V1 Form 3/B/+ 3/1/2026 True Cast Resin V1 Form 4/B
Castable Wax Resin V1 Form 4/B/L
Form 3/B/L/+
Grey Resin V4 Form 3/B/L/+
Form 2
3/31/2026 Grey Resin V4.1 Form 3/B/L/+
Tough 2000 Resin V1.1 Form 4/B/L 8/31/2026 Tough 2000 Resin V2 Form 4/B/L
Durable Resin V2.1 Form 4/B/L 8/31/2026 Tough 1000 Resin V1 Form 4/B/L
Denture Based V1 (LP, OP, and RP) Form 2/3B/4B As supplies last Contact Sales
Flexible 80A Resin V1.1 Form 4/B/L 12/31/2026 Flexible 80A Resin V2 Form 4/B/L
