Solvent Compatibility
Formlabs measures resistance to solvents by observing, measuring, and weighing printed cubes (originally measuring 1 cm × 1 cm × 1 cm) before and after immersion in a solvent for 24 hours. For resin samples, the cubes are washed and post-cured according to the standard post-curing recommendations for that resin. For more information about material properties, read the technical data sheets.
Note:
Formlabs does not provide solvent compatibility data on materials that are classified as medical devices. Formlabs cannot guarantee that parts printed in materials for biocompatible applications retain their biocompatibility after exposure to solvents other than those specified in the manufacturing guide for that material.
Tested solvents and results
Results are reported as weight gain percentage after 24 hours of exposure to solvent.
SolventAcetic Acid 5%AcetoneBleach ~5% NaOClButyl AcetateDiesel FuelDiethyl glycol Monomethyl EtherHydraulic OilHydrogen peroxide (3%)Isooctane (gasoline)Isopropyl AlcoholMineral oil (Heavy)Mineral oil (light)Salt Water (3.5% NaCl)Skydrol 5Sodium Hydroxide solution (0.025% PH 10)Strong Acid (HCl conc)Tripropylene glycol monomethyl ether (TPM)WaterXylene
BioMed Black Resin0.33.10.20.40.110.20.3<0.10.20.20.20.30.60.30.20.60.30.3
BioMed Durable Resin0.712.40.550.130.20.60.0220.10.10.50.60.50.71.10.54.8
BioMed Elastic 50A Resin1.543.40.6133.17.931.43.90.915.639.20.40.70.641.20.745.643.60.7163.9
BioMed Flex 80A Resin1.465.30.597.55.130.92.50.7925.90.20.40.528.10.637.331.20.6112.5
BioMed White Resin0.42.90.30.4<0.11<0.10.3<0.10.2<0.1<0.10.40.50.30.20.60.30.3
Black Resin V4.10.53.10.4-0.100.50.500-0.1000.40.20.40.20.10.50
Black Resin V50.94.90.70.30.110.20.9<0.10.30.20.20.80.50.80.50.30.8<0.1
Clear Cast Resin<1Sample cracked<1<1<11.7<1<1<1<1<1<1<11<1Sample distortedNot tested<1<1
Clear Resin V4.10.53.10.4-0.100.50.500-0.1000.40.20.40.20.10.50
Clear Resin V50.95.10.70.30.11.10.10.9<0.10.30.20.20.80.70.80.50.50.9<0.1
Color Resin V51.20.40.20.10.20.40.5<0.1<0.10.10.40.40.10.20.110.30.10.1
Draft Resin V20.10.10.10.10.20.40.5<0.1<0.10.10.40.40.10.20.110.30.10.1
Durable Resin V21.3Sample cracked<17.9<17.8<11<15.1<1<1<11.3<1Sample distortedNot tested<16.5
Elastic 50A Resin V12.837.3239.64.228.62.12.23.525.6<1<11.721.7239.4Not tested2.346.6
Elastic 50A Resin V21.543.40.6133.17.931.43.90.915.639.20.40.70.641.20.745.643.60.7163.9
ESD Resin0.513.10.53.80.23.60.20.6<0.12.60.10.10.60.50.71.40.60.71.6
Fast Model Resin0.68.90.70.5<0.13.10.20.9<0.10.80.10.20.810.80.50.70.80.2
Flame Retardant ResinNot tested2.10.30.4<0.10.3<0.10.2<0.10.2<0.1<0.10.2<0.10.3<0.10.10.2Not tested
Flexible 80A Resin0.937.40.651.42.319.310.71.611.7<0.10.10.510.70.628.613.60.764.1
Grey Resin V4
Clear Resin V4
Black Resin V4
White Resin V4
Color Resin V1
Grey Pro Resin0.8110.70.8<0.12.40.20.8<0.11.60.30.40.60.50.78.2Not tested0.80.4
Grey Resin V4.10.53.10.4-0.100.50.500-0.1000.40.20.40.20.10.50
Grey Resin V50.94.90.70.30.110.20.9<0.10.30.20.20.80.50.80.50.30.8<0.1
High Temp Resin V2<12<1<1<11<1<1<1<1<1<1<11.1<1<1Not tested<1<1
Model Resin V30.20.90.1<0.10.1<0.10.10.1<0.1<0.10.20.20.20.40.2<0.10.20.2<0.1
Nylon 110.10.10.10.10.20.40.5<0.1<0.10.10.40.40.10.20.110.30.10.1
Nylon 11 CF0.20.20.20.20.60.510.200.211.30.20.80.20.80.80.10.2
Nylon 120.10.10.20.20.40.50.60.2<0.10.20.70.50.20.60.20.80.30.10.1
Nylon 12 GF0.20.20.20.20.60.510.200.211.30.20.80.20.80.80.10.2
Nylon 12 Tough0.20.20.10.10.60.50.90.10.10.310.80.20.80.15.60.80.10.2
Nylon 12 White0.20.20.20.21.311.70.10.30.22.220.11.90.14.81.10.10.2
Polupropylene<0.10.20.10.71.10.91.50.30.9<0.11.61.4<0.11.1<0.1<0.10.9<0.13
Precision Model110.30.80.60.22.10.21.01-0.030.60.20.30.90.30.90.50.30.9<0.1
PU Rigid 1000 Resin0.4110.33.5<0.13.5<0.10.3<0.11.7<0.1<0.10.10.20.20.3-1.10.22.7
PU Rigid 650 Resin0.48.9<0.12.6<0.12.7<0.10.2<0.11.3<0.1<0.10.70.30.10.2-30.32
Rigid 10K Resin<0.1<0.10.10.10.10.40.2<0.10<0.1<0.10.20.10.60.10.20.4<0.1<0.1
Rigid 4000 Resin0.83.30.7<0.1<0.11.40.20.9<0.10.40.20.20.71.10.75.3Not tested0.7<0.1
Silicone 40A Resin<0.111.5<0.192.332.92.510<0.169.85.91.62<0.123.2<0.10.4Not tested<0.1Not tested
Tough 1000 Resin0.230.4038.90.76.90.10.239.86.90.100.250.27.37062.7
Tough 1500 Resin V10.7190.650.15.30.20.7<0.13.2<0.1<0.10.70.50.74.40.60.73.2
Tough 1500 Resin V20.2229.64-0.0541.350.045.710.040.3142.926.540.040.020.242.410.172.155.90.2172.57
Tough 2000 Resin V10.718.80.66.20.15.3<0.10.6<0.13.70.20.10.60.90.63Not tested0.64.1
Tough 2000 Resin V20.1722.920.1118.650.084.650.060.2121.244.210.070.120.160.960.181.961.860.1927.69
TPU 90A1.328.60.916.52.114.42.810.74.82.12.30.96.50.9-5.29.90.920.8
White Resin V4.10.53.10.4-0.100.50.500-0.1000.40.20.40.20.10.50
White Resin V50.94.90.70.30.110.20.9<0.10.30.20.20.80.50.80.50.30.8<0.1
