Certifications and standards (hardware)
Declaration of medical and non-medical devices
Formlabs Inc. hereby declares that the products listed in this document are classified as Medical Devices as defined in Article II of the Regulation (EU) 2017/745 or in Section 201(h) of the Federal Food Drug & Cosmetic (FD&C) Act at the present time. All other Formlabs products not included in this list are not classified as medical devices.
EC Declarations of Conformity (hardware)
Quality system standards
Formlabs electrical equipment is manufactured in facilities with ISO 9001 QMS certifications. Please see this letter for a formal statement regarding manufacturing standards for Formlabs printers. Formlabs is unable to share certificates.
Product safety certifications
Support articles:
Formlabs hardware products are certified to the following relevant US, Canadian, and European safety standards:
Fuse X1
Safety Standards
  • UL 2011 - pending
  • CSA C22.2 No. 301 - pending
  • EN 60204-1 - pending
  • IEC 62368-1 - pending
  • IEC 60825-1 (Laser Safety) - pending
EMC Standards
  • FCC 47CFR Part 15 Subpart B: 12/2025
  • AS/NZS CISPR 32:2015
  • CENELEC EN 55032:2015+A11
  • ETSI EN 301 489-1:2019 Ed.2.2.3
  • ETSI EN 301 489-3:2023 Ed.2.3.2
Fuse 1 and Fuse 1+ 30W
  • European Machinery Directive 2006/42/EC
  • Electromagnetic Compatibility 2014/30/EU
  • Restriction of Hazardous Substances Directive 2011/65/EU
  • EN ISO 12100:2010
  • ISO 11553-1:2020
  • ISO 11252:2013
  • ISO 11554:2017
  • UL/CSA/IEC 62368-1:2014 Ed.2
  • IEC 60825-1:2014
  • Intertek Control Number: 5020213
Fuse Sift
  • EN ISO 12100:2010
  • IEC 60825-1:2014
  • Intertek Control Number: 5020214
Fuse Blast
  • EN ISO 12100:2010
  • Outline of Investigation for Machinery [UL SUBJECT 2011:2022 Ed.7]
  • Industrial Electrical Machinery (R2021) [CSA C22.2#301:2016 Ed.1]
  • IEC 61010-1:2010, IEC 61010-1:2010/AMD1:2016
Form 4/Form 4B
  • EN ISO 12100:2010
  • UL 62368-1:2019 Ed.3+R:22Oct2021
  • CSA C22.2#62368-1:2019 Ed.3+U1
  • IEC 61000-3-2: 2018
  • Intertek Control Number: 5029059
Form 4L/Form 4BL
  • EN ISO 12100:2010
Form 3/Form 3+ and Form 3B/Form 3B+
  • UL/CSA/ IEC 62368-1:2014
  • UL E File #: E477754
  • EN ISO 12100:2010
  • IEC 62368-1:2018
  • Intertek Control Number: 5025752
Form 3L and Form 3BL
  • EN ISO 12100:2010
Form 2
  • EN ISO 12100:2010
Form Wash and Form Wash (2nd Generation)
  • EN ISO 12100:2010
  • IEC 62368-1:2018
  • Intertek Control Number: 5009963
Form Cure
  • EN ISO 12100:2010
  • IEC 62368-1:2018
Form Wash L
  • EN ISO 12100:2010
  • UL-61010-1:2012 Ed.3+R:19Jul2019
  • CSA C22.2#61010-1-12:2012 Ed.3 +U1;U2;A1
  • IEC 61010-1:2010/AMD1:2016
Form Cure L
  • EN ISO 12100:2010
  • UL 61010-1:2012 Ed.3+R:19Jul2019
  • UL 61010-2-010:2019 Ed.4
  • CSA C22.2#61010-2-010:2019 Ed.4
  • IEC 61010-1:2010/AMD1:2016, IEC 61010-2-010:2019
FDA Laser Accession
Formlabs has a laser accession number which is applicable to all our printers that have a laser: 2632437-000. This number is valid until August/September 2027.
Safe Unattended Use
This is to certify that Formlabs LFS and SLS 3D printers are safe for unattended / overnight use when operating according to the prescriptions from the latest versions of Formlabs operation manuals and with Formlabs manufactured resin.
Fire safety
Fire safety is evaluated as part of safety as a whole during hardware compliance testing. All Formlabs hardware products that have been certified through a Nationally Recognized Testing Laboratory (NRTL) have been evaluated for fire safety.
German Social Accident Insurance (DGUV)
Formlabs expects all printers to comply with DGUV requirements. If you are going to test a Fuse 1 generation printer for DGUV compliance, please contact Formlabs in advance to obtain full context on the best way to validate DGUV compliance.
Specifically, for RISO (insulation resistance) testing: The Fuse 1+ 30W contains Metal Oxide Varistors (MOVs) at the line inlet designed to shunt overvoltage to the ground. During a standard 500 VDC insulation test, these MOVs naturally conduct a small amount of current. This is a common occurrence in industrial electronics where surge protection is present, causing the tester to report a low resistance value despite the insulation being intact.
Formlabs verifies safety using dielectric strength testing per IEC 62368-1 and IEC 60204-1 during manufacturing. We recommend following the protocols within EN 50699 that account for electronic components. Specifically, the installer should perform a Protective Conductor Current measurement using the differential current method while the device is running. If the leakage current is within the limits specified by IEC 62368-1, the machine is safe for operation and the insulation resistance result can be documented as influenced by protective components. Alternatively, testing at a reduced voltage of 250 VDC may prevent the MOVs from conducting and allow for a passing resistance reading.
Country of origin
Formlabs printers, materials, and associated products are manufactured in a variety of locations and comply with a variety of safety and quality standards in different jurisdictions. Please contact your Sales representative for country of origin information for a specific Formlabs product.
TAA and ITAR compliance
Formlabs sells TAA-compliant SLA and SLS printer packages. For pricing and more information, contact Formlabs Sales.
Formlabs products can be used in ITAR-compliant settings. Printers and accessories can be run entirely offline, and integrated Wi-Fi and camera capabilities can be physically disabled or removed if needed.
Formlabs cannot accept any 3D models or other technical data that are restricted by any export control laws, including the International Traffic in Arms Regulations (ITAR) and Export Administration Regulations (EAR), other than data classified as EAR99. Please do not upload any files that may be export controlled under applicable law.
