Checking a printer’s model type
Every Formlabs printer is programmed to be compatible with a select set of materials. Depending on your printer’s model type, the available selection of materials may differ.
To view a printer’s model:
  1. On the printer’s touchscreen, access your printer’s details. Either:
    • Tap Settings > System > Printer Details. The Printer Details screen appears.
    • Tap Settings > General > About. The About screen appears.
    • Tap Settings > General > About this printer. The About this printer screen appears.
  2. The Model field displays the printer’s model type.
ModelPrinterMaterial Compatibility
Form 2Form 2Prints biocompatible materials.
Form 3Form 3Does not print biocompatible materials.
Form 3 2019Form 3Prints biocompatible materials.
Form 3BForm 3BPrints biocompatible materials.
Form 3+Form 3+Does not print biocompatible materials.
Form 3B+Form 3B+Prints biocompatible materials.
Form 3L BiocompatibleForm 3BLPrints biocompatible materials.
Form 3LForm 3LDoes not print biocompatible materials.
Form 4Form 4Does not print biocompatible materials.
Form 4BForm 4BPrints biocompatible materials.
Form 4LForm 4LDoes not print biocompatible materials.
Form 4BLForm 4BLPrints biocompatible materials.
Fuse 1Fuse 1Does not print biocompatible materials.
Fuse 1+ 30WFuse 1+ 30WDoes not print biocompatible materials.
Tip:
Compare your printer to the complete selection of materials in the Choosing the right material support article to see which resins are compatible with your printer.
