Formlabs API downloads and release notes
This article summarizes the changes for each version of the Formlabs API and links to the associated downloads.
Formlabs Local API
VERSION CHANGELOG DATE SERVER DOWNLOADS
1.0.2 documentation
  • Updated PreFormServer for PreForm release 3.64.2.
October 23, 2026
PreFormServer Windows Download
PreFormServer MacOS (Apple Silicon ARM 64) Download
PreFormServer MacOS (Intel-based) Download
1.0.0 documentation
  • Updated PreFormServer for PreForm release 3.64.0.
  • API V1.0 is officially released: Find more information about the API functionality on the API Reference page.
  • Translate no longer clamps to the build volume: /scene/model/translate/ no longer forces models back inside the build volume, matching PreForm, which allows models outside the build volume.
  • Crash saving with the "default" scene: Fixed PreForm Server crashing when saving an FPS file with the documented default scene alias.
October 14, 2026
0.9.31 Documentation
  • Updated PreFormServer for PreForm release 3.63.1.
September 25, 2026
0.9.30 Documentation
  • Updated PreFormServer for PreForm release 3.63.0.
  • More reliable PreForm Server startup signaling: Improved how the headless PreForm Server signals that it has finished starting up and is ready for requests, making it more reliable for automation and scripting.
September 16, 2026
0.9.29 Documentation
  • Updated PreFormServer for PreForm release 3.62.1.
August 19, 2026
PreFormServer MacOS Download
0.9.28 Documentation
  • Updated PreFormServer for PreForm release 3.62.0.
August 11, 2026
0.9.27 Documentation
  • Updated PreFormServer for PreForm release 3.60.4.
July 30, 2026
0.9.26 Documentation
  • Updated PreFormServer for PreForm release 3.60.3.
July 14, 2026
0.9.25 Documentation
  • Updated PreFormServer for PreForm release 3.60.2.
June 23, 2026
0.9.24 Documentation
  • Updated PreFormServer for PreForm release 3.60.1.
June 10, 2026
0.9.23 Documentation
  • Updated PreFormServer for PreForm release 3.60.0.
  • Memory leak in Scan to Model: Fixed a memory leak in the Scan to Model feature that could cause PreForm (and PreForm Server) to consume increasing amounts of RAM over time when running repeated scan-to-model operations, leading to system instability in high-volume workflows.
June 9, 2026
0.9.22 Documentation
  • Updated PreFormServer for PreForm release 3.59.1.
  • "Separate Bodies" is now available in public release builds.
May 22, 2026
0.9.21 Documentation
  • Updated PreFormServer for PreForm release 3.59.0.
  • Added POST /scene/{scene_id}/thin-wall-detection/ endpoint to detect thin-wall regions in models below a configurable thickness threshold. Returns per-model results including total thin volume, region count, and per-region breakdown (volumes and bounding boxes).
May 12, 2026
0.9.20 Documentation
  • Updated PreFormServer for PreForm release 3.58.1.
April 23, 2026
0.9.19 Documentation
  • Updated PreFormServer for PreForm release 3.58.0.
April 15, 2026
0.9.18 Documentation
  • Updated PreFormServer for PreForm release 3.57.2.
March 31, 2026
0.9.17 Documentation
  • Updated PreFormServer for PreForm release 3.57.1.
March 24, 2026
0.9.16 Documentation
  • Updated PreFormServer for PreForm release 3.57.0.
March 18, 2026
0.9.15 Documentation
  • Updated PreFormServer for PreForm release 3.56.2.
March 5, 2026
0.9.14 Documentation
  • Updated PreFormServer for PreForm release 3.56.1.
February 26, 2026
0.9.13 Documentation
  • Updated PreFormServer for PreForm release 3.56.0.
February 24, 2026
0.9.12 Documentation
  • Updated PreFormServer for PreForm release 3.55.1.
January 28, 2026
0.9.11 Documentation
  • Updated PreFormServer for PreForm release 3.55.0.
January 13, 2026
0.9.10 Documentation
  • Updated PreFormServer for PreForm release 3.54.1.
December 9, 2025
0.9.9 Documentation
  • Updated PreFormServer for PreForm release 3.54.0.
November 18, 2025
0.9.8 Documentation
  • Updated PreFormServer for PreForm release 3.53.0.
  • Fixed a bug where Auto Support did not work with mini raft settings.
October 21, 2025
0.9.7 Documentation
  • Updated PreFormServer for PreForm release 3.52.1.
  • Added delete scene endpoints.
  • Added the “enable_smooth_contour_extended_sides” option to the scan to model endpoint.
September 25, 2025
0.9.6 Documentation
  • Updated PreFormServer to match PreForm 3.51.1 release.
August 29, 2025
0.9.5 Documentation
  • Updated PreFormServer to match PreForm 3.51.0 release.
August 19, 2025
0.9.4 Documentation
  • Updated PreFormServer to match PreForm 3.50.2 release.
August 4, 2025
0.9.3 Documentation
  • Updated PreFormServer to match PreForm 3.50.1 release.
  • Fixed issue where printing multiple jobs at the same time may cause layers from different jobs to appear in the same job
  • No API changes
July 30, 2025
0.9.2 Documentation
  • Updated PreFormServer to match PreForm 3.50.0 release.
  • Update /scene/{scene_id}/scan-to-model/ endpoint to support new list of files input.
  • Fixed bug preventing uploading Fuse 1+ scenes to Dashboard group queues.
  • Fixed where custom fps files were not registered on scene creation.
  • Fix loading and applying custom print settings when loading .form files
July 22, 2025
0.9.1 Documentation
  • Updated PreFormServer to match PreForm 3.49.0 release
June 17, 2025
0.9.0 Documentation
  • Updated PreFormServer to match PreForm 3.48.0 release
  • Added support for editing multiple scenes in parallel. Previously, the Formlabs Local API only allowed creating and editing a single scene at a time but now you can create and use API endpoints targeting separate scenes. For example, you can estimate the print time on one scene while importing a model into another scene at the same time.
    • API endpoints have been updated to target specific scene IDs.
    • API endpoints to modify scenes without a scene ID are still available but are deprecated and will be removed in a future release.
  • Added custom_bounds parameter to /scene/{scene_id}/scan-to-model/ endpoint to keep selected models inside in the layout operation.
  • Added /scene/pack-and-cage/ endpoint to automatically arrange models in the build volume and create a cage around them.
May 27, 2025
0.8.14 Documentation
  • Updated PreFormServer to match PreForm 3.47.0 release
  • Added /scene/add-drain-holes/ endpoint for adding drain holes to parts
  • Added /scene/label/ endpoint to adding labels to parts
  • Added support for asynchronous loading and saving .form files
  • Added shell and wall thickness parameters to /scene/scan-to-model/ endpoint
April 23, 2025
v0.8.13 Documentation
  • Updated PreFormServer to match PreForm 3.46.1 release
  • No changes to API
April 7, 2025
  • Updated PreFormServer to match PreForm 3.46.0 release
  • Added /scene/hollow/ endpoint to hollow models in a scene
  • Added /scene/interferences/ endpoint that Returns a list of pairs of IDs of interfering models.
  • Allow generating supports on models already on the build platform with the MINI_RAFTS_ON_BP option in the /scene/auto-support/ endpoint
  • Fixed incorrectly document return type of /scene/scan-to-model/ endpoint
  • Add cutoff_below_gumline_mm option to /scene/scan-to-model/ endpoint
  • Support saving .webp images and a flyaround_transform option in the /scene/save-screenshot/ endpoint
  • Fixed issue creating biocompatible material scenes for Form 4B printers
March 24, 2025
v0.8.12 Documentation
  • Added new /scan-to-model/ endpoint, encompassing functionality of the “Scan to Model” wizard in the PreForm dental workspace
  • /auto-orient/, /auto-support/, /auto-layout/, and /auto-pack/ endpoints can all now be directly called with no further arguments
  • Allow saving empty .form files
  • /save-screenshot endpoint can now output an animated image flyaround of models
  • Added start_or_connect_to_preform_server() pattern to python repo, to allow optionally connecting to a server which is already running
  • Update PreFormServer functionality to match PreForm 3.45.1
February 28, 2025
v0.8.11 Documentation
  • Updated PreFormServer to match PreForm 3.44.2 release
  • No changes to API
February 17, 2025
v0.8.10 Documentation
  • Updated PreFormServer to match PreForm 3.44.1 release
  • No changes to API
February 10, 2025
v0.8.9 Documentation
  • /scene/save-screenshot/ now allows arbitrary angles
  • /scene/auto-support/ now has only_minima option to produce PreForm's "Support all minima" functionality
  • /scene/auto-layout/ now allows mode: "DENTAL" option to produce results of auto-layout in a dental workspace. In this mode, auto-layout attempts turning the models at finer angles in order to better nest shapes like dental arches
  • /scene/estimate-print-time/ now includes a breakdown of pre-print and cooldown times for SLS machines
  • formlabs-api-python repo:
    • Added full docker instructions for running PreFormServer in a linux docker container running Wine
    • Added speedrun.py example for finding settings to produce lower print times and exporting as a .fps file
  • Updated PreFormServer to match PreForm 3.44.0 release
January 29, 2025
v0.8.8 Documentation
  • Updated PreFormServer to match PreForm 3.43.2 release
  • No changes to API
January 21, 2025
v0.8.7 Documentation
  • Updated PreFormServer to match PreForm 3.43.1 release
  • No changes to API
December 18, 2024
v0.8.6 Documentation
  • Updated /list-materials/ endpoint:
    • Fixed: don't include biocompatible materials for non-biocompatible printers
    • Included build volume dimensions and supported product names for each printer type
    • Included description text for each material
  • Updated device listing endpoints:
    • Included ready_to_print_now property if a printer will start printing newly uploaded jobs immediately
    • Added new parameter can_print to filter the list to only devices that can have jobs uploaded to them for printing
    • Updated Fleet Control Printer Group information to include queue paused status, list of supported machine types, and the list of printer IDs
  • Updated print endpoint to support the optional print_now parameter which can be used to control queueing vs. printing now for printer types that support it
  • Added endpoint to upload new firmware to a device
  • Added support for making more operations asynchronously: save screenshot, import model, auto orient, auto support, auto layout, auto pack, calculate print validations, estimate print time, discover devices, upload firmware
  • Added endpoints to logout and get logged in user information
  • Removed the need to whitelist the PreFormServer application on MacOS
  • Updated PreFormServer to match PreForm 3.43.0 release
December 10, 2024
v0.8.5 Documentation
  • Update PreFormServer to match PreForm 3.42.1 release
  • No changes to API
November 27, 2024
v0.8.3 Documentation
  • Added async support for the print upload endpoint and new endpoints to poll for the progress of the long running operation
  • Added support for Print Settings Editor .fps files when creating a scene and updating a scene's properties
  • Added endpoint to export a scene's current settings as a .fps file
  • Update PreFormServer to match PreForm 3.42.0 release
November 6, 2024
v0.8.2 Documentation
  • Updated PreFormServer to match PreForm 3.41.2 release
  • No changes to API
October 31, 2024
v0.8.1 Documentation
  • Updated PreFormServer to match PreForm 3.41.1 release
  • No changes to API
October 25, 2024
v0.8.0 Documentation (Beta) First release October 15, 2024
Formlabs Web API
VERSIONCHANGELOGDATE
  • Removed probably_finished field from print data
  • Add consumable_type field to cartridge data
December 6, 2024
v0.8.0 Documentation (Beta)First releaseOctober 15, 2024
