Danger:
This procedure involves operating your printer with a panel removed. Do not touch any electrical components on the printer while the panel is removed and the printer is powered on.
There are three types of fans in Form 4 and Form 4L generation printers. If you are hearing a loud or rattling noise from your printer, the resolution depends on which fan is the source of the noise.
Symptoms
Causes
Troubleshooting steps
Determine which fan is faulty by disconnecting the fans one at a time. See the appropriate section below for your printer type.
Danger:
Form 4 generation
Form 4L generation
Testing the Light Processing Unit fans
