Preparing your workspace for the Form 4L generation printer
Before receiving your printer, prepare a space to install and operate the Form 4L generation printer and house the necessary accessories and consumables. Choose a location separate from any machinery or tooling that generates dust or sparks, such as wood or metal working equipment.
Workspace requirements
Reserve the following minimum dimensions for the most convenient access (W × D × H):
  • Form 4L generation printer: 88.9 × 116.8 × 81.3 cm (35.0 × 46.0 × 32.0 in)
  • Form 4L Finish Kit: 55 × 85 × 90 cm (21.7 × 33.5 × 35.4 in)
  • Additional space for other post-processing tools (e.g., Form Wash L, Form Cure L, or Formlabs-approved third-party devices)
    • Form Wash L: 100 × 120 × 120 cm (40 × 48 × 48 in)
    • Form Cure L V2: 60 × 110 × 56 cm (23.6 × 43.3 × 22.0 in)
The printer requires a power source that meets the following requirements:
  • 100–240 VAC
  • Maximum 9 A
  • 50/60 Hz
  • 900 W
Figure displaying the Form 4L, Form Wash L, and Form Cure L with their dimensions and the recommended space around each machine.
Storing consumables
Formlabs materials require proper storage to maximize the usable lifetime. Light and temperature affect shelf life significantly. For optimal results, follow Formlabs guidelines for storing and handling resins.
Consider dedicating shelf space as storage for consumables. Resin cartridges can be stored next to each other vertically on a flat surface. Form 4 generation resin tanks and Form 4 generation build platforms lay flat and are stackable for efficient storage.
Additional supplies
Aside from the contents of the printer package, you need additional supplies to post-process printed parts and to clean and maintain the printer. Prepare your workspace by purchasing them in advance:
  • Isopropyl alcohol (90% or higher) and/or tripropylene glycol monomethyl ether
  • Low-fiber paper towels
  • Non-abrasive microfiber cloth
  • Non-reactive nitrile gloves
  • PEC*PADs
  • Safety glasses
