Registering the Fuse 1 to Dashboard
Register a Fuse 1 to Dashboard through the touchscreen on the machine. Once the Fuse 1 is registered to Dashboard and Dashboard logging is enabled on the machine, the printer can send data to Dashboard as long as the Wi-Fi or Ethernet connections are able to access the internet. Connecting only to a local area network is not sufficient for sending data to Dashboard.
Registering through the touchscreen
Connect a Fuse 1 to Dashboard by securing a personal registration code from the printer's Settings menu and inputting the code online in the Dashboard.
To register through the touchscreen:
  1. Ensure the firmware on your Fuse 1 is up to date.
  2. On the printer's touchscreen, tap Settings > Connectivity > Register to Dashboard.
  3. Tap Register. The touchscreen displays a custom registration code: a sequence of four alphanumeric characters, 0–9 and A–Z.
The 'Register to Dashboard' screen displayed on the printer's touchscreen
  1. Open Dashboard online at formlabs.com/dashboard and log in.
  1. Click Printers. A list of previously registered Formlabs devices appears. If this is your first time registering a machine, then the space is blank.
The 'Printers' tab in Dashboard
  1. Click + Add New Printer. The Register a Formlabs printer to your account screen appears.
The 'Add New Printer' button in Dashboard
  1. Select a team or create a new team to add the machine to, or select My Dashboard to only add it to your own account.
The 'My Dashboard' button in Dashboard
  1. Enter the registration code displayed on the printer's touchscreen into the associated fields.
  1. Click Register Printer. Your machine is added to the selected team or to your own account.
The 'Register Printer' button in Dashboard
  1. Confirm the Dashboard registration on the touchscreen of the newly added machine.
The 'Printer added to Dashboard' message is displayed on the touchscreen of the newly registered machine
Tip:
Your Formlabs account uses the same log-in credentials to access orders and saved addresses for the Formlabs store, as well as your newsletter and mailing preferences.
