Replacing the Fuse 1+ 30W nitrogen controller board
On Fuse 1+ 30W printers, the nitrogen controller board manages the flow of nitrogen when you are printing with an inert gas atmosphere. A faulty or malfunctioning nitrogen controller board may prevent you from printing with nitrogen.
Use this guide to replace the nitrogen controller board on a Fuse 1+ 30W printer.
Required supplies:
  • Replacement nitrogen controller board
Third-party:
  • Antistatic wrist band
Estimated time: 15–30 minutes
Danger:
Preparing the workspace
Overview: Prepare the printer and a dust-free workspace for replacing the nitrogen controller board.
Step 1: Prepare the workspace
Step 2: Unplug the printer
Danger:
Step 3: Disconnect the nitrogen source
Disconnect the nitrogen hose from the quick-disconnect fitting, if connected.
Step 4: Remove the Wi-Fi antenna
Unscrew and remove the Wi-Fi antenna, if it is connected.
Removing the lower rear panel
Overview: Remove the lower rear panel to access the interior of the printer.
Step 1: Remove the lower rear panel screws
The six black lower rear panel screws are circled in red. The four chrome lower rear panel grounding screws are circled in blue.
Using a 2.5 mm hex driver, remove the six black panel screws and the four chrome panel grounding screws securing the lower rear panel to the printer. Set the screws aside, taking care to separate the black and chrome screws for later reinstallation.
Step 2: Remove the lower rear panel from the printer
Pull the lower rear panel straight back and away from the printer. Lay it down on a flat, clean surface.
Removing the original nitrogen controller board
Overview: Disconnect and remove the original nitrogen controller board.
Step 1: Prepare to remove the nitrogen controller board
Put on an antistatic wrist band and connect it to a known ground point. Do not connect the wristband any surfaces that are powder-coated or painted.
Locate the nitrogen controller board, pictured here.
Remove the original N2 Board
Step 2: Disconnect the cables from the nitrogen controller board
Disconnect all JST connectors from the nitrogen controller board. For cables that have a locking tab, make sure to disengage the locking tab first, then pull the connector away from the board via its plastic housing.
Step 3: Uninstall the nitrogen controller board
Using a 2.5 mm hex drive, loosen and remove the four 8.0 mm M3 socket screws securing the nitrogen controller board to the back of the printer. Maneuver the board away from the printer, being careful not to snag or pull any of the loose connectors.
Installing the replacement nitrogen controller board
Overview: Mount, secure, and connect the replacement nitrogen controller board
Step 1: Prepare the new nitrogen controller board
If you are not still wearing one, put on an antistatic wrist band and connect it to a known ground point. Remove the new nitrogen controller board from its packaging.
Step 2: Mount and secure the nitrogen controller board
Orient the board with the connector labeled J083 at the top-left corner. Align the four screw holes on the board with the corresponding screw holes on the back of the printer. Ensure that none of the loose cables become trapped behind the board while maneuvering it into place.
Thread one 8 mm M3 socket head screw into each of the four screw holes. Recheck that none of the cables are trapped behind the board, then use a 2.5 mm hex driver to tighten the screws until snug.
Step 3: Reconnect the cables
Reconnect all seven JST connectors to the nitrogen board. Refer to the image here to match each cable to its place on the board.
Install the new N2 Board
Reinstalling the lower rear panel
Overview: After installing the replacement power supply, reinstall and secure the lower rear panel.
Step 1: Mount and secure the lower rear panel
Thread the panel screws into the indicated screw holes on the lower rear panel. Refer to the image for the correct locations of the black and chrome screws. Using a 2.5 mm hex driver, screw in the six black panel screws and four chrome panel grounding screws securing the lower rear panel to the printer.
The placement of the chrome screws is critical to the printer's electrical grounding. Incorrect placement may lead to printer damage.
Step 2: Reinstall the Wi-Fi antenna (optional)
Screw the Wi-Fi antenna onto the jack on the back of the unit.
Step 3: Reconnect the nitrogen supply
Reconnect the nitrogen hose to the quick-disconnect fitting.
Finalizing the repair
Overview: After installing the replacement nitrogen controller board, power on the printer and perform final checks.
Step 1: Power on the printer
Step 2: Check the nitrogen supply
Confirm that nitrogen supply pressure into the Fuse 1+ 30W is in the range of 248–862 kPa (36–125 psi) and the flow rate is at least 14 L/min (0.5 SCFM). When using a nitrogen supply such as bottled nitrogen gas or liquid nitrogen, ensure that there is enough available nitrogen to complete the print. When printing with an inert gas atmosphere, the printer requires approximately 14 L (0.5 cu ft) of nitrogen gas per minute.
Step 3: Enable the nitrogen system
Tap the printer icon in the left sidebar to access the printer status screen. Toggle Nitrogen System to ON. Confirm that the touchscreen shows N2 Mode and that both the Inlet Pressure and the Valve Pressure are in range.
Re-adjust N2 pressure
Step 4: Test the repair
Start a print using nitrogen. Monitor the printer to ensure that the print proceeds normally. Contact Formlabs Support or your certified service provider to share the results of the procedure.
