Replacing the Fuse Sift sifter flange
The Fuse Sift sifter flange secures the bellows above the used powder hopper. If the flange is faulty or damaged, powder may leak past the bellows and fall into or below the machine. If the rivets that secure the flange to the machine come loose, the sifter mechanism will vibrate in unexpected ways, leading to noisy operation and potential damage.
Use this guide to replace the Fuse Sift sifter flange.
Fuse Sift sifter rework kit
Required Supplies:
Third-party:
  • 6.0 mm hex driver
  • 6.5 mm slotted screwdriver
  • 3.5 mm (#28) drill bit
  • Drill
  • 1.3 Nm torque screwdriver with 2.0 mm hex bit
  • 12.5 Nm torque screwdriver with 6.0 mm hex bit
  • Flashlight
  • Tape
  • Compliant vacuum with static dissipative components, such as a Class II, Division 2 vacuum
  • Vacuum brush tools
  • Appropriate personal protective equipment for the powder in use, as defined in the safety data sheet (SDS)
  • Nonreactive nitrile gloves
  • Loctite 243 or equivalent threadlocker
Estimated time: 45–60 minutes
Preparing the workspace
Overview: Prepare the Fuse Sift and your workspace for replacing the sifter flange and gasket.
Step 1: Remove and store printed parts
Remove any printed parts from the Fuse Sift workspace to prevent them from being damaged inadvertently.
Step 2: Clean the workspace
Using the vacuum attached to your Fuse Sift, clean the workspace. Vacuum any loose powder inside the workspace, under the hood, on the print bed and the surrounding port, and on the vent filter.
Step 3: Clean below the surface grate
Cleaning the Fuse Sift
Remove the sifter surface grate from the workspace to expose the sifter mesh. Set the sifter surface grate aside.
Vacuum all powder and debris on top of and around the sieve and the sifter frame. After vacuuming, ensure that the sieve is properly secured onto the sifter by all eight turnbuckles.
Step 4: Unplug the Fuse Sift
Power off the Fuse Sift, then unplug the power cable from the rear panel.
Danger:
Performing this procedure on the Fuse Sift while it is plugged in increases the risk of electric shock. After disconnecting the power from the Fuse Sift, wait at least five minutes before servicing.
Step 5: Unscrew the Wi-Fi antenna
Remove the Wi-Fi antenna, if present.
Warning:
Use appropriate personal protective equipment when handling loose or unsintered powder. Refer to the support article Safety with Formlabs SLS products or your powder’s safety data sheet (SDS) for more information.
Removing the upper front enclosure panel
Overview: Remove the upper front enclosure panel to begin accessing the sifter flange.
Step 1: Unscrew the upper front enclosure panel mounting screws
Using a 2.5 mm hex driver, loosen and remove the four black 8.0 mm M4 button screws underneath the upper front enclosure panel lip. Remove the three black 8.0 mm M4 button screws from the left-hand side of the same panel. Set the screws aside.
Step 2: Remove the upper front enclosure panel
Slide the panel downwards to remove it from the Fuse Sift. Set the upper front enclosure panel aside.
Removing the rear enclosure panel
Overview: Separate the rear enclosure panel from the Fuse Sift in order to access the vibration motor.
Step 1: Unscrew the rear enclosure panel mounting screws
Use a 2.5 mm hex driver to remove the 16 black 8.0 mm M4 screws securing the rear panel to the Fuse Sift. Set the screws aside.
Step 2: Remove the rear closure panel
Separate the rear enclosure panel from the Fuse Sift and set it aside.
Remove the rear enclosure panel
Detaching the vibration motor
Overview: Detach the vibration motor from the sifter assembly in order to remove the sifter flange.
Step 1: Unscrew the vibration motor mounting screws
Locate the vibration motor, positioned on the back of the sifter assembly. Using a 6.0 mm hex driver, loosen and remove the four 20.0 mm M8 cap screws and lock washers securing the motor. Set the screws and lock washers aside.
You may need to use a ball-end hex driver or loosen the vibration motor cable gland to access all four screws.
Place the motor horizontally on the upper shelf assembly.
Removing the existing sifter flange and gasket
Overview: Drill out the rivets that secure the sifter flange to the Fuse Sift and remove it from the machine.
Step 1: Locate the sifter flange rivets
Locate and remove the eight grey stickers applied to the work surface around the sifter. These stickers cover a set of rivets.
Remove the existing sifter flange & gasket
Step 2: Drill out the sifter flange rivets
Using a drill with a 3.5 mm (#28) drill bit, drill out the rivets. Bore through the center of each rivet while pushing downward on the back of the drill. If a rivet begins spinning in the work surface, try gripping it from below with pliers.
The rivets may remain in the existing sifter flange, so long as they are disengaged from the work surface. The sifter flange will sink into the sifter once all eight rivets have been drilled out.
Step 3: Separate the upper sifter bellows from the sifter flange
Use a 6.5 mm slotted screwdriver to completely open and unlink the hose clamp securing the upper sifter bellows to the existing sifter flange. Remove the hose clamp from the machine and set it aside. Gently pull the upper sifter bellows down and away from the existing sifter flange.
Step 4: Remove the sifter flange and gasket
Carefully remove the existing sifter flange through the clearance at the front of the machine. Avoid gouging, tearing, or puncturing the upper sifter bellows while removing the existing sifter flange. If the sifter flange gasket does not come out with the sifter flange, pull it out as well.
Set the sifter flange and gasket aside for disposal.
Installing the replacement sifter flange and gasket
Overview: Mount and secure the replacement sifter flange and gasket using the jig and fasteners included in the sifter rework kit.
Step 1: Check the sifter rework kit
Unpack the sifter rework kit and ensure that the following items are present:
  • Replacement sifter flange
  • Replacement sifter flange gasket
  • SLS-printed jig
  • Disc magnet
  • Countersunk stainless steel washers, 10x
  • M3 lock nuts, 10x
  • 10.0 mm M3 countersunk screws, 10x
Press the disc magnet into the larger pocket of the SLS-printed jig. If it does not stay in place, tape it to the jig.
Install the new sifter flange & gasket
Step 2: Mount the gasket
Place the replacement flange gasket onto the replacement sifter flange, ensuring that the 16 holes in the gasket align with the 16 holes in the flange. Note that the gasket does not adhere in place, so you may need to readjust it as you work to keep the holes aligned.
Step 3: Prepare a sifter flange and gasket mounting screw
Locate the front-most counterbore at the 5 o’clock position in the work surface. Place one countersunk washer into the couterbore, followed by a 10.0 mm M3 countersunk screw.
Step 4: Mount the softer flange and gasket
Bring the new sifter flange and gasket into the machine with the gasket facing up. Orient it so that the M3 screw sticking through the work surface passes through the aligned clearance holes in the new sifter flange and gasket.
Step 5: Begin securing the sifter flange and gasket
Thread one lock nut onto the M3 screw by hand. Take the jig and place the hex pocket over the lock nut. Rotate the jig towards the sifter flange until the magnet holds the jig in place.
From the top of the work surface, use a 2.0 mm hex driver to fully thread the M3 countersunk screw into the lock nut below. You may find it helpful to have a second person hold the jig in place or press the flange upwards against the work surface. Remove the jig from the machine once the screw is tightened.
Step 6: Continue securing the sifter flange and gasket
Repeat steps 3–5 for the remaining seven sifter flange mounting points in the order depicted here.
Step 7: Fully torque the sifter flange mounting screws
Using a 1.3 Nm torque screwdriver with a 2.0 mm hex bit, torque all eight screws in the order depicted here.
Step 8: Mount the upper sifter bellows onto the sifter flange
Begin sliding the lip of the upper sifter bellows onto the sifter flange. Start at the front of the machine, then work the lip of the upper sifter bellows into position through the sifter clearance hole in the work surface.
Step 9: Place the hose clamp around the upper bellows
Open the hose clamp and feed it around the upper sifter bellows from the rear of the machine. Go to the front of the machine and use a 6.5 mm slotted screwdriver to feed the hose clamp band into the hose clamp’s screw cage until the clamp is loosely secure around the flange and the top of the bellows.
Step 10: Check the position of the upper sifter bellows and hose clamp.
Confirm that the upper sifter bellows and hose clamp are concentrically aligned with the sifter flange. Make sure that there are no kinks or creases where the bellows lip contacts the sifter flange and that neither the upper sifter bellows lip nor hose clamp band are caught on the protruding M3 screws.
Step 11: Secure the upper sifter bellows
Use a 6.5 mm slotted screwdriver to close the hose clamp as much as possible and secure the upper sifter bellows to the sifter flange.
Step 12: Clean the work surface
Vacuum any debris on top of and around the sifter mesh, the sifter and the entire work surface that resulted from replacing the sifter flange. Any debris from replacing the sifter flange that is not collected before resuming use of the machine may contaminate your powder or obstruct the Fuse Sift doser assembly.
Reinstalling the vibration motor
Overview: Mount and secure vibration motor.
Step 1: Mount the vibration motor
Align the vibration motor with the four M8 taps on the back of the sifter assembly so that the motor’s cable is on the right-hand side.
Install the new vibration motor
Step 2: Secure the vibration motor
Place one lock washer onto each of the four vibration motor mounting screws. Apply a small dab of Loctite 243 or equivalent threadlocker to the threads of each screw. Thread one screw into each of the four screw holes in the motor and sifter assembly. Use a 6.0 mm hex driver to replace the 4X 20.0 mm M8 cap screws to secure the vibration motor to the sifter assembly.
Step 3: Torque the vibration motor screws
Use a torque screwdriver with a 6.0 mm hex bit to torque each of the vibration motor mounting screws to 12.5 Nm in the order depicted here.
Reinstalling the rear enclosure panel
Overview: Mount and secure the rear enclosure panel after installing the new sifter flange and gasket.
Step 1: Prepare the rear panel retention screws
Apply a small amount of Loctite 243 or other similar threadlocker to each of the 16 black 8.0 mm M4 button screws that secure the rear panel to the Fuse Sift.
Step 2: Mount the rear panel
Mount the rear panel onto the Fuse Sift.
Step 3: Secure the rear panel
Thread one 8.0 mm M4 button screw into each of the 16 screw holes in the rear panel. Use a 2.5 mm hex driver to tighten until snug.
Replace the rear enclosure panel
Tip:
Start with the top three screws to hold the panel in place while you thread and tighten the remaining screws.
Reinstalling the upper front enclosure panel
Overview: After reinstalling the rear enclosure panel, reinstall the upper front enclosure panel.
Step 1: Align the upper front enclosure panel
Replace the upper front enclosure panel
Align the upper front enclosure panel with the so that the black tab on the right-hand side of the panel and the two black flanges on the left-hand side of the panel are not visible. Start by aligning the smaller tab on the right first.
Step 2: Mount the upper front enclosure panel
Slide the panel upwards until it locks into place. Note that the panel can still fall down if knocked or hit.
Step 3: Secure the upper front enclosure panel
Apply a small dab of Loctite 243 or equivalent threadlocker to each of the seven black 8.0 mm M4 button head screws that secure the upper front enclosure panel to the Fuse Sift. Thread one of the screws into each of the seven screw holes in the panel. Using a 2.5 mm hex driver, tighten the screws until snug.
Finalizing the repair
Overview: After installing the new sifter flange and gasket, power on the Fuse Sift and test its functions.
Step 1: Power on the Fuse Sift
Reconnect the Fuse Sift to its power source. Flip the power switch to the ON position.
Step 2: Test the sifter
Turn on the sifter using the Fuse Sift touchscreen. Check that the machine does not make any unexpected noises and does not leak powder through the sifter bellows. Contact Formlabs Support or your certified service provider to share the results of the procedure.
