Resin version history
Formlabs reformulates its resins periodically. Some formulations of Formlabs resins are compatible with and may be mixed with earlier versions. To determine whether this is the case for the resins you use, consult the section for that resin.
Alpha Black Resin (SDS)
FormulationFinishAvailability
FLAPBK01opaque✔ (October 2026)
Alpha Clear Resin (SDS)
FLAPCL01translucent✔ (October 2026)
Alpha Fast Resin (SDS)
FLAPFA01opaque✔ (October 2026)
Alpha Grey Resin (SDS)
FLAPGR01opaque✔ (October 2026)
Alpha Model Resin (SDS)
FLAPMD01opaque✔ (October 2026)
Alpha White Resin (SDS)
FLAPWH01opaque✔ (October 2026)
Alumina 4N Resin (SDS)
FLAL4N01opaque✔ (September 2023)
BEGO™ VarseoSmileⓇ TriniQⓇ Resin Resin (SDS)
FLTQA201
FLTQA301
FLTQB101
opaque✔ (September 2024)
BioMed Amber Resin (SDS)
FLBMAM01translucent✔ (June 2020)
BioMed Black Resin (SDS)
Formulation Finish Availability
FLBMBL01 opaque ✔(April 2022)
BioMed Clear Resin (SDS)
FLBMCL01translucent✔ (June 2020)
BioMed Durable Resin (SDS)
Formulation Finish Availability Reason for reformulation Can mix with earlier versions?
FLBMDU01 translucent ✔(June 2023)
FLBMDU11 translucent ✔(April 2024) Form 4 generation No
BioMed Flex 50A Resin* (SDS)
FLBMEL01translucent✔ (October 2023)
* Name change from BioMed Elastic 50A Resin to BioMed Flex 50A Resin
BioMed Flex 80A Resin (SDS)
FLBMFL01translucent✔ (October 2023)
BioMed White Resin (SDS)
FLBWHM01opaque✔ (April 2022)
Black Resin (SDS)
FormulationFinishAvailabilityReason for reformulationCan mix with earlier versions?
FLGPBK01opaqueReleased June 2014, discontinued
FLGPBK02opaqueReleased April 2016, discontinuedSupply chainNo
FLGPBK03opaqueReleased June 2017, discontinuedMatte finishCan mix with V2
FLGPBK04opaque✔ (December 2017)Supply chainCan mix with V3
FLGPBK41opaque✔ (October 2024)Deeper color, better print reliabilityNo
FLGPBK05opaque✔ (April 2024)Form 4 generationNo
Castable Resin (SDS)
FormulationFinishAvailabilityReason for reformulationCan be mixed with earlier versions?
FLGPCL01opaqueReleased October 2014, discontinued
FLGPCL02opaque✔ (June 2016)More opaque, better detailCan mix with V1
Castable Wax Resin (SDS)
FLCWPU01translucent✔ (July 2018)
Castable Wax 40 Resin (SDS)
FLCW4001opaque✔ (January 2021)
Ceramic Resin (SDS)
FLCEWH01opaqueReleased May 2018, discontinued
Clear Resin (SDS)
FLGPCL01translucentReleased May 2013, discontinued
FLGPCL02translucentReleased November 2014, discontinuedReduced yellowingNo
FLGPCL03translucentReleased April 2016, discontinued
FLGPCL04translucent✔ (September 2017)Formulation improvementCan mix with V2
FLGPCL41translucent✔ (October 2024)More color-neutral and transparent partsNo
FLGPCL05translucent✔ (April 2024)Form 4 generationNo
Clear Cast Resin (SDS)
FLCCCL01translucent✔ (September 2024)
Color Kit: Color Base Resin and Pigments (SDS)
FLGPCB01opaque✔ (December 2017)
Color Resin (SDS)
FLGPCO05 opaque ✔(June 2025)
Custom Tray Resin (SDS)
FLCTBL01translucent✔ (June 2020)
Dental LT Clear Resin (SDS)
FLDLCL01translucentReleased October 2017, discontinued
FLDLCL02translucent✔ (June 2020)Reduced yellowing, improved durability, higher resistance to fractureNo
Dental LT Comfort Resin (SDS)
FLDLCO01translucent✔ (June 2023)
FLDLCO11translucent✔ (April 2024)Form 4 generationNo
Dental SG Resin (SDS)
FLDGOR01translucentReleased April 2016, discontinued
Denture Base Resin (SDS)
FLDBLP01
FLDBOP01
FLDBRP01
FLDPDP01
translucent ✔(January 2019)
FLDBLP02
FLDBOP02
FLDBDP02
translucent ✔(July 2026) Improved formulation No
Denture Teeth Resin (SDS)
FLDTA101
FLDTA201
FLDTA301
FLDTAS01
FLDTB101
FLDTB201
opaque Released January 2019, discontinued
Draft Resin (SDS)
FLDRBL01opaqueReleased April 2019, discontinued
FLDRGR02opaque✔ (October 2020)Color change, improved material propertiesNo
Durable Resin (SDS)
FLDUCL01translucentReleased January 2017, discontinued
FLDUCL02translucent✔ (November 2017)Supply chainNo
FLDUCL21translucent✔ (April 2024)Form 4 generationNo
ESD Resin (SDS)
FLESDS01opaque✔ (January 2022)
Fast Model Resin (SDS)
FLFMGR01opaque✔ (April 2024)
Flame Retardant Resin (SDS)
FLFRGR01opaque✔ (May 2023)
Flexible 50A Resin* (SDS)
FLELCL01translucentReleased January 2019, discontinued
FLELCL02translucent✔ (February 2024)Easier support removal, decreased printing time, and clearer post-cured appearanceNo
* Name change from Elastic Resin to Elastic 50A Resin, then Flexible 50A Resin
Flexible 80A Resin (SDS)
FLFLGR01 translucent Released October 2014, discontinued
FLFLGR02 opaque Released September 2017, discontinued Color change to black, better tear strength No
FLFL8001 translucent ✔(June 2020) Color change to clear, better tear strength and elongation at break
Name change from Flexible Resin to Flexible 80A Resin
No
FLFL8011 translucent ✔(April 2024) Form 4 generation No
FLFL8002 opaque ✔(June 2026) Color change to black, better tear strength and rebound No
Grey Resin (SDS)
FLGPGR01opaqueReleased August 2013, discontinued
FLGPGR02opaqueReleased November 2014, discontinuedSupply chain
Improvements
Color change
No
FLGPGR03opaque Matte finish, improved accuracyCan mix with V2
FLGPGR04opaque✔ (November 2017)Supply chainCan mix with V3
FLGPGR05opaque✔ (April 2024)Form 4 generationNo
FLGPGR41opaque✔ (March 2025)Increased toughnessNo
Grey Pro Resin (SDS)
FLPRGR01opaque✔ (January 2018)
High Temp Resin (SDS)
FLHTAM01translucentReleased October 2016, discontinued
FLHTAM02translucent✔ (December 2018)Less brittleNo
IBT Resin (SDS)
FLIBCL01translucent✔ (January 2021)
IBT Flex Resin (SDS)
FLIBFL01translucent✔ (October 2023)
Model Resin (SDS)
FormulationFinishAvailabilityCan mix with earlier versions?
FLDMBE01opaqueReleased March 2017, discontinued
FLDMBE02opaque✔ (October 2017)No
FLDMBE03opaque✔ (December 2021)No
Permanent Crown Resin (SDS)
FLPCA201
FLPCA301
FLPCB101
FLPCC201
Precision Model Resin (SDS)
FLPMBE01opaque✔ (April 2024)
Premium Teeth Resin (SDS)
FLPTA201
FLPTA301
FLPTB101
FLPTBL01
opaque✔ (January 2024)
PU Rigid 650 Resin (SDS)
FLPU6501opaque✔ (June 2022)
PU Rigid 1000 Resin (SDS)
FLPU1001opaque✔ (June 2022)
Rigid 4000 Resin* (SDS)
FLRGWH01opaque✔ (January 2018)
* Name change from Rigid Resin to Rigid 4000 Resin
Rigid 10K Resin (SDS)
FLRG1001opaque✔ (October 2020)
FLRG1011opaque✔ (April 2024)Form 4 generationNo
Silicone 40A Resin (SDS)
FLSI4001opaque✔ (September 2023)
Soft Tissue Resin (Starter Pack) (SDS)
FLFL8001 opaque ✔(December 2020)
Surgical Guide Resin (SDS)
FLSGAM01translucent✔ (November 2019)
Temporary CB Resin (SDS)
FLTCA201
FLTCA301
FLTCB101
FLTCC201
opaque✔ (June 2020)
Tough 1000 Resin (SDS)
FLTO1001opaque✔ (November 2025)
Tough 1500 Resin (SDS)
FLTO1501opaque✔ (February 2020)
FLTO1511opaque✔ (April 2024)Form 4 generationNo
FLTO1502opaque✔ (March 2025)Increased toughnessNo
Tough 2000 Resin (SDS)
FLTOTL01translucentReleased June 2015, discontinued
FLTOTL02translucentReleased April 2016, discontinuedSupply chainCan mix with V1
FLTOTL03translucentReleased October 2016, discontinuedStiffer and strongerNo
FLTOTL04translucentReleased April 2017, discontinuedSupply chainCan mix with V3
FLTOTL05translucentReleased October 2017, discontinuedSupply chainCan mix with V4
FLTO2001opaque✔ (March 2020)Name change from Tough Resin to Tough 2000 ResinNo
FLTO2011opaque✔ (April 2024)Form 4 generationNo
FLTO2002opaque✔ (November 2025)Improved material propertiesNo
True Cast Resin (SDS)
FLTCLV01 opaque ✔ (June 2025)
White Resin (SDS)
FLGPWH01opaqueReleased December 2013, discontinued
FLGPWH02opaque Improved colorNo
FLGPWH03opaque Matte finishNo
FLGPWH04opaque✔ (November 2017)Supply chainCan mix with V3
FLGPWH05opaque✔ (April 2024)Form 4 generationNo
FLGPWH41opaque✔ (December 2024)Brighter white colorNo
