Saving changes in PreForm
Save your print job as a FORM file in PreForm for later access to the model's orientation and supports.
Note:
To protect privacy, print jobs cannot be downloaded from your printer or from Dashboard. Refer to the support article Connectivity and security for more information about privacy.
Save changes in Preform
To save changes in PreForm:
  1. In the menu bar, click File > Save As.... A window opens.
  2. Choose where to save the file.
  3. Name the file.
  4. In the Save as type dropdown, select PreForm Jobs (*.form).
  5. Click Save. Your orientation and supports are saved as a FORM file, which you can open and make changes to later.
Saving projects
Starting with PreForm 3.62.0, PreForm supports projects—you can set up builds across different printers and materials, switch between them from the new project panel, and move parts freely as your project plan evolves.
Saving all builds in a project
Projects with multiple builds save as a single FORM file. Use the File menu or keyboard shortcuts to save and load project FORM files normally without needing to save each build separately.
Saving a single build from a project
To save one build out of multiple in a project:
  1. Right-click the build to be saved in the Project panel. A context menu appears.
  2. Click Export. A window opens.
  3. Choose where to save the file.
  4. Name the file. The default name is the same as that of the parent project.
Exporting a single build from a project
