Starting a print (SLA)
Before you begin
After purchasing your printer, select the necessary consumables that best suit your work environment and use case:
  • Choose and purchase resin based on your application and printer model.
  • Choose and purchase a washing solvent based on your application.
  • Purchase additional supplies.
Step 1: Set up PreForm
After setting up the printer, download PreForm:
Step 2: Prepare a model in PreForm
Once the latest version of PreForm is installed on your computer:
Step 3: Transfer a file from PreForm to the printer
After setting up your model in PreForm, choose a printer to run the print job:
Step 4: Start a print on the printer
After transferring the print job, confirm the print job on the printer’s touchscreen to start the print.
Step 5: Manage usage and data in Dashboard
