Note:
Remote printing requires a Formlabs account and that your printer be connected to the internet.
Print on-the-go with just your computer. You can insert consumables, send a print job, and start the print from anywhere.
Note:
Priming a local printer
Note:
Priming a printer is a deprecated feature for Form 3, Form 3B, Form 3L, and Form 3BL printers. It is only available for Form 3/Form 3B printers running firmware versions 1.20.33 or earlier and Form 3L/Form 3BL printers running firmware 1.11.14 or earlier. The feature has been replaced with automatic printer readying.
Prime a printer without enabling Remote Printing to automatically start a print when your computer is on the same network. As long as a printer is Primed beforehand, you can send a print job to the queue and have it automatically begin printing from several rooms away.
Note:
If you are away from your printer or connected to a different network, then the primed printer is disabled in PreForm and the print job does not upload to the printer queue. Enable Remote Printing to print from a different network than your printer.
Setting up remote printing
When Remote Printing is active, the printer does not communicate with PreForm directly. Instead, both PreForm and the printer pass information to Dashboard and Dashboard shares information between the two.
Ensure you’re all set up and ready to go before sending a print job to the printer:
Note:
You must be logged in to the same Formlabs account within PreForm to see your remote printer in PreForm.
Making remote printing part of your workflow
Sending a print job to a printer with Remote Printing enabled adds that print job to the print queue. If the inserted consumables do not match the selected PreForm material, then the print job does not print and must be reuploaded with matching materials to begin.
To start another remote print:
Note:
Prevent continued use by disabling Remote Printing.
