Using Dental LT Comfort Resin
Dental LT Comfort Resin is engineered to be more flexible than Dental LT Clear Resin, making it more durable and more comfortable for patients. The splint gradually becomes more flexible in the mouth, providing optimal comfort and improving patient compliance with treatment plans.
Dental LT Comfort Resin also provides exceptional clarity, reducing polishing time.
alttext
Recommended for:
  • Occlusal splints and nightguards
  • Bleaching trays
  • Tooth positioners
  • Space maintainers
Dental LT Comfort Resin prints at 100 microns.
 Dental LT Comfort ResinDental LT Clear Resin
Ultimate tensile strength (MPa)2952
Tensile modulus (MPa)9942080
Elongation at break (%)3312
Durometer/Shore Hardness75D78D
Flexural modulus (GPa)0.640.23
IZOD Impact strength (J/m)9835
To learn more about the performance properties of Formlabs resins, refer to the library of material properties data sheets.
Required resources
Made by Formlabs:
Made by third parties:
  • Dental design software (CAD)
  • Intraoral or desktop optical scanner
  • Dental handpiece with cutting and finishing wheels
  • Isopropyl alcohol (IPA) ≥ 99%
Printing with Dental LT Comfort Resin
To prepare a model for printing in PreForm, follow the instructions in the manufacturing guide. When printing occlusal splints and guards, follow the steps in our application guide 3D Printing Splints with Formlabs SLA 3D Printers [EN] [DE] [ES] [FR] [IT] [JA] [KO] [PT] [RU] [ZH]:
  1. Open PreForm
  2. Open the Dental Workspace
  3. Select or create an occlusal guard template
  4. Import the scan(s) into the Dental Workspace
    1. PreForm Dental Workspace imports, orients, and supports your splint.
  5. Send the print job to the printer
Note:
If you encounter fit issues when the default Dental Workspace preset, reduce the angle of the splints relative to the build platform.
Washing
Follow the part washing recommendations in the manufacturing guide for the clearest and best possible results. Improper washing can lead to suboptimal mechanical and biocompatibility properties.
Post-curing requirements
Follow the post-curing recommendations in the manufacturing guide for the clearest and best possible results. Improper post-curing can lead to suboptimal mechanical and biocompatibility properties.
Newly post-cured splints have a slight green tint. Over time the part will photobleach to a clear blue hue.
  • Do not post-cure beyond the recommended post-cure settings, as this may cause discoloration.
  • Allow post-cured splints to cool completely before removing supports or fitting.
  • Remove supports only after post-curing to prevent warping.
Additional resources
