Choosing the right resin
Tip:
For further guidance about materials, consult the Formlabs material selector or the Materials Catalog.
Do not mix different resins (e.g., Clear Resin and Black Resin). Print settings for different resins are carefully calculated based on each resin’s material properties, color, and curing settings.
Resins designated as biocompatible must maintain separate accessories, including a dedicated resin tank, build platform, and finishing equipment.
Alumina 4N Resin (SDS)
VERSION HISTORY
Recommended lifetime/shelf life: 3 months (room temperature)
Refrigeration at -25–4 °C can add up to 12 months of additional shelf life, or 15 months total.
PRINTERS
Form 3/3+Form 3B/3B+Form 4/4B
RESIN TANKS
Form 3 Tank V2.1Form 4 Tank
LAYER THICKNESS(microns)
Form 3/3B/3+/3B+50
Form 4/4B50
Related articles:
BEGO™ VarseoSmileⓇ TriniQⓇ Resin (SDS)
VERSION HISTORY
Recommended lifetime: 36 months
Ceramic-filled material for highly accurate permanent restorative parts, provisional restorative parts, and denture teeth.
PRINTERS
Form 4B
RESIN TANKS
Form 4 Tank
Layer Thickness(microns)
Form 4B50, 100
Related articles:
Using BEGO™ VarseoSmileⓇ TriniQⓇ Resin
BioMed Amber Resin (SDS)
VERSION HISTORY
Recommended lifetime/shelf life: 24 months
Stiff, functionally strong medical-grade material for biocompatible parts that require short-term skin and mucosal membrane contact.
PRINTERS
Form 2Form 3B/3B+Form 3BLForm 4BForm 4BL
RESIN TANKS
Form 2 LTForm 3 Tank (all)Form 3L Tank (all)Form 4 TankForm 4L Tank
Form 250, 100
Form 3B/3B+50, 100
Form 3BL100
Form 4B50, 100
Form 4BL50, 100
* Wash in IPA with a concentration of 99% or higher to comply with biocompatibility regulations. Fully dry and inspect the parts for any uncured resin, and re-wash in fresh IPA if necessary.
Related articles:
Using BioMed Amber Resin
BioMed Black Resin (SDS)
VERSION HISTORY
BioMed Black Resin is a medical-grade material designed for a wide range of end-use applications where performance, aesthetics and biocompatibility are critical. BioMed Black Resin is USP Class VI certified, and printed parts are validated for long-term contact with skin and short-term mucosal membrane contact.
PRINTERS
RESIN TANKS
Form 2 StandardForm 2 LTForm 3 Tank (all)Form 3L Tank (all)Form 4 TankForm 4L Tank
Form 250, 100
Form 3B/3B+50, 100
Form 3BL50, 100
Form 4B50, 100
Form 4BL50, 100
Related articles:
Using BioMed Black Resin
BioMed Clear Resin (SDS)
VERSION HISTORY
Medical-grade material designed for rigid, non-brittle, biocompatible parts that require long-term skin and mucosal membrane contact and for end-use medical devices.
PRINTERS
RESIN TANKS
Form 2100
Form 3B/3B+100
Form 3BL100
Form 4B50, 100
Form 4BL100
Related articles:
Using BioMed Clear Resin
BioMed Durable Resin (SDS)
VERSION HISTORY
BioMed Durable Resin is a clear material for applications requiring impact, shatter, and abrasion resistance.
PRINTERS
RESIN TANKS
BioMed Durable Resin V1
Form 3B/3B+100
Form 3BL100
BioMed Durable Resin V1.1
Form 4B100
Form 4BL100
Related articles:
Using BioMed Durable Resin
BioMed Elastic 50A Resin (SDS)
VERSION HISTORY
Recommended lifetime: 24 months
PRINTERS
Form 3BForm 3BLForm 4BForm 4BL
RESIN TANKS
Form 3B100
Form 3BL100
Form 4B100
Form 4BL100
Related articles:
Using BioMed Elastic 50A Resin
BioMed Flex 80A Resin (SDS)
VERSION HISTORY
PRINTERS
RESIN TANKS
Form 3B50, 100
Form 3BL100
Form 4B100
Form 4BL100
Related articles:
Using BioMed Flex 80A Resin
BioMed White Resin (SDS)
VERSION HISTORY
BioMed White Resin is a medical-grade material designed for a wide range of end-use applications where performance, aesthetics and biocompatibility are critical. BioMed White Resin is USP Class VI certified, and printed parts are validated for long-term contact with skin and short-term mucosal membrane contact. BioMed White Resin is also certified for short-term contact with tissue, bone, and dentin.
PRINTERS
RESIN TANKS
Form 250, 100
Form 3B/3B+50, 100
Form 3BL50, 100
Form 4B100
Form 4BL100
Related articles:
Using BioMed White Resin
Black Resin (SDS)
VERSION HISTORY
Highly pigmented, opaque matte surface, great for printing small, intricate features.
PRINTERS
Form 1+Form 2Form 3/3+Form 3B/3B+Form 3L/3BLForm 4/4BForm 4L/4BL
RESIN TANKS
Black Resin V4
Form 1+25, 50, 100
Form 225, 50, 100
Form 3/3B/3+/3B+25, 50, 100
Form 3L/3BL50, 100
Black Resin V4.1
Form 3L/3BL50, 100
Black Resin V5
Form 4/4B25, 50, 100
Form 4L/4BL25, 50, 100
Related articles:
Standard resins
Castable Resin (SDS)
VERSION HISTORY
Recommended lifetime/shelf life: 18 months
Developed for clean burnout with direct investment casting.
PRINTERS
Form 1+Form 2
RESIN TANKS
Form 1+25, 50, 100
Form 225, 50, 100
* Wash Castable Resin for the shortest time necessary to remove liquid resin. Allow solvent to fully evaporate from the parts before curing and casting.
Related articles:
Castable Wax Resin (SDS)
VERSION HISTORY
20% wax-fill material captures intricate features, offers smooth surfaces and high strength without post-curing. Developed for casting with zero ash content and clean burnout. Suitable for custom try-ons and direct investment casting.
PRINTERS
RESIN TANKS
Form 225, 50
Form 3L/3BL50
Form 4/4B25, 50
Form 4L/4BL50
* Wash Castable Wax Resin for the shortest time necessary to remove liquid resin. Allow solvent to fully evaporate from the parts before casting. Use compressed air to remove solvent completely from any internal channels and hollows.
Related articles:
Using Castable Wax Resin
Printing crowns and bridges with Castable Wax Resin
Introduction to Casting for 3D Printed Jewelry Patterns [en] [fr] [ja]
3D Print High Detail Jewelry with New Castable Wax Resin [en] [de] [fr] [it]
New in Formlabs Dental: The Digital Advantage for Casting and Pressing [en] [de] [fr] [it]
Castable Wax 40 Resin (SDS)
VERSION HISTORY
Recommended lifetime/shelf life: 24–48 months
40% wax-fill and low expansion direct casting resin with superior castability, accommodates a wide range of design features such as stone holes and engraves.
PRINTERS
RESIN TANKS
Form 2 LTForm 3 Tank V2.1
Form 225, 50
* Wash Castable Wax 40 Resin for the shortest time necessary to remove liquid resin. Allow solvent to fully evaporate from the parts before casting. Use compressed air to remove solvent completely from any internal channels and hollows.
Related articles:
Using Castable Wax 40 Resin
Introduction to Casting for 3D Printed Jewelry Patterns [en] [de] [fr] [it]
Castable Wax 40 Resin Promises Castability Without Compromise [en] [de] [fr] [it] [es]
Ceramic Resin (SDS)
VERSION HISTORY
Recommended lifetime/shelf life: 12 months
Composite, silica-filled resin that can be fired in a kiln or furnace to create a fully ceramic piece. This experimental Form X material requires more trial and error than other Formlabs products.
PRINTERS
Form 2
RESIN TANKS
Form 2 Standard
Form 250, 100
* Maintain separate wash buckets to prevent ceramic particles adhering to parts printed with other resins.
Related articles:
Introducing Ceramic Resin for the Form 2 [en] [de] [fr] [it]
Design guidelines for Ceramic Resin
Printing and troubleshooting Ceramic Resin
Firing and glazing Ceramic Resin
Clear Resin (SDS)
VERSION HISTORY
Transparent, polishes to near optical clarity, great for internal channels and working with light.
PRINTERS
RESIN TANKS
Clear Resin V4
Form 1+25, 50, 100, 200
Form 225, 50, 100
Form 3L/3BL50, 100
Clear Resin V4.1
Form 3L/3BL50, 100
Clear Resin V5
Related articles:
Polishing Clear Resin for a transparent finish
Adjusting layer thickness in PreForm
Clear Cast Resin (SDS)
VERSION HISTORY
Translucent resin for creating sacrificial patterns for investment casting.
PRINTERS
Form 2Form 3Form 3BForm 3L/3BLForm 4/4BForm 4L/4BL
RESIN TANKS
Form 250, 100
Form 3/3B50, 100
Form 3/3BL50, 100
Form 4/4B50, 100
Form 4L/4BL100
Related articles:
Using Clear Cast Resin
Color Kit: Color Base Resin and Pigments* (SDS)
VERSION HISTORY
Opaque matte finish, 16 supported colors and potential for many more with opaque and matte finish. Colorful prints without finishing and painting.
PRINTERS
RESIN TANKS
Form 225, 50, 100
Form 3L/3BL100
Form 4/4B50, 100
Form 4L/4BL100
* Color Base is formulated to be mixed with the appropriate amount of Color Pigment. Color Base will not print successfully without the pigments, and the pigments are not designed for use with any resin except the Color Base.
Related articles:
Using Color Kit
Create Your Own Color Resin with Formlabs New Color Kit [en] [de] [fr]
Color Resin (SDS)
VERSION HISTORY
Choose any color to closely match final parts without painting, coating, or pigment mixing. Each order is custom-manufactured and quality checked, ensuring reliable results.
PRINTERS
RESIN TANKS
Form 4/4B100
Form 4L/4BL100
Related articles:
Using Color Resin
Custom Tray Resin (SDS)
VERSION HISTORY
Long-term biocompatible material formulated for manufacturing impression trays.
PRINTERS
RESIN TANKS
Form 2200
Form 3B/3B+200
Form 3BL200
Form 4B100
Form 4BL100
WASH SETTINGS*
Related articles:
Using Custom Tray Resin
Dental LT Clear Resin (SDS)
VERSION HISTORY
Designed for hard splints and retainers with high resistance to fracture and wear. Class IIa biocompatible.
PRINTERS
RESIN TANKS
Form 2100
Form 3B/3B+100
Form 3BL100
Form 4B100
Form 4BL100
* Wash Dental LT Clear Resin V1 in IPA with a concentration of 96% or higher and Dental LT Clear Resin V2 in IPA with a concentration of 99% or higher to comply with biocompatibility regulations. For optimum mechanical properties, do not wash Dental LT Clear Resin in IPA for more than 20 minutes.
Related articles:
Dental resins
Printing splints with Dental LT Clear Resin
3D Print Hard Splints on the Form 2 in Less Than 50 Minutes [en] [de] [fr]
How Low-Cost Splints Enable Preventative Patient Care [en] [de] [fr]
Dental LT Comfort Resin (SDS)
VERSION HISTORY
Dental LT Comfort Resin is engineered to be more flexible than Dental LT Clear Resin, making it more durable and more comfortable for patients.
PRINTERS
RESIN TANKS
Dental LT Comfort Resin V1
Form 3B/3B+100
Form 3BL100
Dental LT Comfort Resin V1.1
Form 4B100
Form 4BL100
Related articles:
Using Dental LT Comfort Resin
Dental SG Resin (SDS)
VERSION HISTORY
Designed for surgical and pilot drill guides. Class I biocompatible resin (EN-ISO 10993-1:2009/AC:2010, USP Class VI).
PRINTERS
Form 2Form 3B/3B+
RESIN TANKS
Form 250, 100
Form 3B/3B+50, 100
* Wash in IPA with a concentration of 96% or higher to comply with biocompatibility regulations. Fully dry and inspect the parts for any uncured resin, and re-wash in fresh IPA if necessary.
Related articles:
Using Dental SG Resin
Digital Dentistry
Maximize Implant Profitability: How to Design and 3D Print Surgical Guides In-House [en] [de] [fr]
Denture Base Resin (SDS)
VERSION HISTORY
Recommended lifetime/shelf life: 36 months
Developed for biocompatible denture bases and teeth with fewer steps and less variability than traditional workflows. Class IIa biocompatible.
PRINTERS
Form 2Form 3B/3B+Form 4B
RESIN TANKS
Form 2 StandardForm 2 LTForm 3 Tank (all)Form 4 Tank
Form 250
Form 3B/3B+50
Form 4B50
Related articles:
Digital Dentures
Using Digital Dentures Resins
Now Shipping: The First Truly Accessible 3D Printed Denture Solution (English only)
Denture Teeth Resin (SDS)
VERSION HISTORY
Use to create biocompatible denture bases and teeth with fewer steps and less variability than traditional workflows. Class IIa biocompatible.
PRINTERS
Form 2Form 3B/3B+
RESIN TANKS
Form 250
Form 3B/3B+50
Related articles:
3D Printed Digital Dentures (English only)
Draft Resin (SDS)
VERSION HISTORY
Fast print speed makes it ideal for same-day design iterations and printing bulky parts in less than eight hours.
PRINTERS
RESIN TANKS
Form 2 LTForm 3 Tank V2/V2.1Form 3L Tank (all)
Form 2100, 200
Form 3/3B/3+/3B+100, 200
Form 3L/3BL100, 200
Related articles:
Using Draft Resin
Durable Resin (SDS)
VERSION HISTORY
Similar physical properties to polypropylene (PP) or high density polyethylene (HDPE), where high elongation, deformation, or impact resistance are required.
PRINTERS
RESIN TANKS
Durable Resin V2
Form 250, 100
Form 3/3B/3+/3B+50, 100
Form 3L/3BL50, 100
Durable Resin V2.1
Form 4/4B50, 100
Form 4L/4BL50, 100
* Do not leave Durable Resin parts printed in IPA for longer than 20 minutes total, as excessive alcohol exposure affects the quality of the final part.
Related articles:
Using Durable Resin
Engineering resins
VERSION HISTORY
Designed for applications requiring high elongation and high energy return. Use for prototypes that must bend, stretch, compress, and hold up to repeated cycles.
PRINTERS
Form 3/3+ Form 3B/3B+Form 3L/3BLForm 4/4BForm 4L/4BL
RESIN TANKS
Form 3 Tank V2/V2.1Form 3L Tank (all)Form 4 TankForm 4L Tank
Form 3/3B/3+/3B+100
Form 3L/3BL100
Form 4/4B100
Form 4L/4BL100
* Do not leave Elastic 50A Resin parts in solvent for longer than 20 minutes total, as excessive alcohol exposure affects the quality of the final part.
Related articles:
Introducing Elastic Resin: A Soft, Resilient 3D Printing Material [en] [de] [fr] [it]
Using Elastic 50A Resin
Solvent compatibility
ESD Resin (SDS)
VERSION HISTORY
Formlabs ESD Resin safely dissipates static buildup that can damage sensitive electronics, making it ideal for producing robust custom parts that comply with ESD safety standards.
PRINTERS
RESIN TANKS
Form 3L/3BL100
Form 4/4B50, 100
Form 4L/4BL50, 100
* Do not leave ESD Resin parts in solvent for longer than 20 minutes total, as excessive alcohol exposure affects the quality of the final part.
Related articles:
Using ESD Resin
Fast Model Resin (SDS)
VERSION HISTORY
Fast Model Resin is Formlabs’ fastest resin, capable of printing at speeds of over 100 mm per hour. Print dental models in minutes or large prototypes in less than two hours.
PRINTERS
RESIN TANKS
Form 4/4B100, 160, 200
Form 4L/4BL100, 160, 200
Related articles:
Using Draft Resin
Flame Retardant Resin (SDS)
VERSION HISTORY
PRINTERS
RESIN TANKS
Form 3L/3BL100
Form 4/4B50, 100
Form 4L/4BL50, 100
Related articles:
Using Flame Retardant Resin
Flexible 80A Resin (SDS)
VERSION HISTORY
Simulates 80A durometer rubber, high impact resistance and compression, great for ergonomic soft-touch grips.
PRINTERS
RESIN TANKS
Flexible 80A Resin V1
Form 250, 100
Form 3L/3BL100
Flexible 80A Resin V1.1
Form 4/4B100
Form 4L/4BL100
Related articles:
Using Flexible 80A Resin
3D Printing for Engineers & Product Designers
Grey Resin (SDS)
VERSION HISTORY
Neutral and matte tone, great for showing off surface finish and for printing small, accurate features, photographs easily.
PRINTERS
RESIN TANKS
Grey Resin V4
Form 1+25, 50, 100
Form 225, 50, 100, 160
Form 3/3B/3+/3B+25, 50, 100, 160
Form 3L/3BL25, 50, 100
Grey Resin V4.1
Grey Resin V5
Form 4L/4BL25, 50, 100, 150
Grey Pro Resin (SDS)
VERSION HISTORY
Versatile material, resistant to deformation over time, suitable for concept modeling, functional prototyping, and parts intended for repeated use.
PRINTERS
Form 2 Form 3/3+ Form 3B/3B+ Form 3L/3BL
RESIN TANKS
Form 2 LT Form 3 Tank V2/V2.1 Form 3L Tank (all)
Form 250, 100
Form 3L/3BL50, 100
* For the Form 3, Resin Tank V2 is required for printing with Grey Pro Resin.
Related articles:
Rethink Product Development With Two New Engineering Resins [en] [de] [fr]
Using Grey Pro Resin
High Temp Resin (SDS)
VERSION HISTORY
HDT of 238 °C @ 0.45 MPa for V2 (FLHTAM02) and 289 °C @ 0.45 MPa for V1 (FLHTAM01), designed for static applications that experience high temperatures, including thermoforming, vulcanization, and electronics encapsulation.
PRINTERS
RESIN TANKS
Form 1+25, 50, 100
Form 225, 50, 100
Form 3L/3BL50, 100
Form 4/4B50, 100
Form 4L/4BL50, 100
* Do not wash High Temp Resin for more than 6 minutes in solvent, or the part will absorb solvent.
Related articles:
Using High Temp Resin
3D Printing For High Thermal Stability: Get to Know High Temp Resin [en] [de] [fr]
IBT Flex Resin (SDS)
VERSION HISTORY
PRINTERS
RESIN TANKS
Form 3B50, 100, 200
Form 3BL100
Form 4B50, 100
Form 4BL100
Related articles:
Using IBT Flex Resin
IBT Resin (SDS)
VERSION HISTORY
Designed for manufacturing biocompatible indirect bonding trays for orthodontic bracket placement.
PRINTERS
RESIN TANKS
Form 2 LTForm 3 Tank V2.1Form 3L Tank (all)
Form 2100
Form 3B/3B+100
Form 3BL100
Related articles:
Using IBT Resin
Model Resin (SDS)
VERSION HISTORY
Recommended lifetime/shelf life: 24 months (Model Resin V3), 18 months (Model Resin V2)
Highly accurate, formulated for printing crown and bridge models with removable dies.
PRINTERS
RESIN TANKS
Form 2 LTForm 3 V2.1Form 3L Tank (all)
Form 250, 100
Form 3/3+50, 100
Form 3B/3B+50, 100
Form 3L/3BL50
Related articles:
Printing crown and bridge models with Model Resin
Permanent Crown Resin (SDS)
VERSION HISTORY
Long-term biocompatible material developed for dental crowns, inlays, onlays, and veneers.
PRINTERS
Form 3B/3B+
RESIN TANKS
Form 3 Tank (all)
Form 3/3+50
Related articles:
Using Permanent Crown Resin
Precision Model Resin (SDS)
VERSION HISTORY
PRINTERS
RESIN TANKS
Form 4/4B25, 50
Form 4L/4BL50, 100
Related articles:
Premium Teeth Resin (SDS)
VERSION HISTORY
A nano-ceramic filled Class II material designed for denture teeth and temporary full-arch implant-supported restorations (All-on-X appliances).
PRINTERS
RESIN TANKS
Form 3B50, 100
Form 3BL100
Form 4B50, 100
Form 4BL50
Related articles:
Using Premium Teeth Resin
PU Rigid 650 Resin (SDS)
VERSION HISTORY
Parts printed with PU Rigid 650 Resin have extremely high impact strength and the physical properties of polyurethane, making them ideal for end-use applications that are intended to be exposed to harsh conditions. PU Rigid 650 and PU Rigid 1000 Resin have been evaluated as a skin contacting device in accordance with ISO 10993-1.
PRINTERS
RESIN TANKS
Form 250, 100
Form 3L/3BL100
Related articles:
PU Rigid 1000 Resin (SDS)
VERSION HISTORY
Parts printed with PU Rigid 1000 Resin have extremely high impact strength and the physical properties of polyurethane, making them ideal for end-use applications that are intended to be exposed to harsh conditions. PU Rigid 650 and PU Rigid 1000 Resin have been evaluated as a skin contacting device in accordance with ISO 10993-1.
PRINTERS
RESIN TANKS
Form 250, 100
Form 3L/3BL100
Related articles:
Rigid 4000 Resin (SDS)
VERSION HISTORY
Reinforced with glass for very high stiffness and a polished finish, highly resistant to deformation over time. Great for printing thin walls and features. Not suited for parts that must bend.
PRINTERS
Form 2 Form 3/3+ Form 3B/3B+Form 3L/3BLForm 4/4BForm 4L/4BL
RESIN TANKS
Form 2 LTForm 3 Tank V2/V2.1Form 3L Tank (all)Form 4 TankForm 4L Tank
Form 250, 100
Form 3L/3BL50, 100
Form 4/4B50, 100
Form 4L/4BL50, 100
* Maintain separate wash buckets.
Related articles:
Using Rigid 4000 Resin
Rigid 10K Resin (SDS)
VERSION HISTORY
With a stiffness simulating that of glass and fiber-filled thermoplastics, Rigid 10K Resin is designed to maintain structural integrity under any condition.
PRINTERS
RESIN TANKS
Rigid 10K Resin V1
Form 250, 100
Form 3L/3BL100
Rigid 10K Resin V1.1
Form 4/4B50, 100
Form 4L/4BL50, 100
* Maintain separate wash buckets to prevent glass particles adhering to parts printed with other resins.
Related articles:
Formlabs Introduces Family of Rigid Resins and Launches Two New Resins [en] [de] [fr] [it] [es]
Using Rigid 10K Resin
Silicone 40A Resin (SDS)
VERSION HISTORY
PRINTERS
RESIN TANKS
Form 3/3B/3+/3B+100
Form 4/4B100
Related articles:
Using Silicone 40A Resin
Soft Tissue Resin (SDS)
VERSION HISTORY
Designed for simulation of the gingiva for dental implant modeling in customizable color pigments.
PRINTERS
Form 2Form 3B/3B+
RESIN TANKS
Form 250, 100
Related articles:
Using Soft Tissue Resin
Surgical Guide Resin (SDS)
VERSION HISTORY
PRINTERS
RESIN TANKS
Form 250, 100
Form 3B/3B+100
Form 3BL100
Form 4B50, 100
Form 4BL50, 100
Related articles:
Temporary CB Resin (SDS)
VERSION HISTORY
Long-term biocompatible material developed for dental crowns, bridges, inlays, onlays, and veneers.
PRINTERS
Form 2Form 3B/3B+
RESIN TANKS
Form 250
Form 3B/3B+50
Related articles:
Using Temporary CB Resin
Tough 1000 Resin (SDS)
VERSION HISTORY
Simulates HDPE plastic. Great for parts requiring high impact strength, a low-friction surface, or the ability to bend, compress, or deform without cracking.
PRINTERS
RESIN TANKS
Form 4/4B100
Form 4L/4BLComing soon
Related articles:
Tough 1500 Resin (SDS)
VERSION HISTORY
Simulates PP plastic. Great for functional prototyping of assemblies, snap-fits and hinges.
PRINTERS
RESIN TANKS
Tough 1500 Resin V1
Form 250, 100
Form 3L/3BL50, 100
Tough 1500 Resin V1.1
Form 4/4B50, 100
Form 4L/4BL100
Tough 1500 Resin V2
Form 4/4B50, 100
Form 4L/4BL50, 100
Related articles:
Tough 2000 Resin (SDS)
VERSION HISTORY
Simulates ABS plastic. Choose for applications that will undergo high stress and strain. Great for functional prototyping of assemblies, machining, and snap-fits.
PRINTERS
RESIN TANKS
Tough 2000 Resin V1
Form 250, 100
Form 3L/3BL50, 100
Form 4/4B50, 100
Tough 2000 Resin V1.1
Form 4/4B50, 100
Form 4L/4BL50, 100
Tough 2000 Resin V2
Form 4/4B100
* Tackiness has been observed on part surfaces when washed in alcohol with more than 5% resin concentration.
Related articles:
Using Tough 2000 Resin
Adding Screw Threads to 3D Printed Parts [en] [de] [fr] [it]
True Cast Resin (SDS)
VERSION HISTORY
Use True Cast Resin for precision casting of intricate jewelry and complex engineering components up to 5 mm thick.
PRINTERS
Form 4/4B
RESIN TANKS
Form 4 Tank
Form 4/4B25, 50
Related articles:
Using True Cast Resin
White Resin (SDS)
VERSION HISTORY
Neutral matte surface, slightly translucent when thin.
PRINTERS
RESIN TANKS
White Resin V4
Form 1+50, 100
Form 250, 100
Form 3L/3BL50, 100
White Resin V4.1
Form 3L/3BL50, 100
White Resin 5V5
Form 4/4B50, 100
Form 4L/4BL50, 100
