Note:
Incorrect calibration will lead to print failures.
Formlabs SLA printers use a system called LevelSense to determine the amount of resin in the resin tank during printing. On Form Studio 1 printers, the LevelSense board is located above the back-left corner of the resin tank. If the LevelSense system is not calibrated properly, the printer may report inaccurate resin level readings, leading to error messages or unexpected behavior.
Formlabs recommends recalibrating the resin level sensor in the following situations:
Note:
Tools required:
Calibrating the resin level sensor
To calibrate the resin level sensor:
Remove all consumables from the printer.
