Printing with High Volume Manufacturing mode (Form Studio 1)
Before a Form Studio 1 printer starts a print, it fills the resin tank and heats the resin. For most users, this process does not have a significant impact on workflow. For more industrial applications with higher throughput requirements, mid-print resin tank fills can add up.
Note:
High Volume Manufacturing mode was added in firmware version 1.0.0 but will not be enabled until a week after the firmware release (week of November 22, 2026). The feature will be enabled automatically if your printer is connected to the internet without any additional firmware update.
Form Studio 1 with High Volume Manufacturing mode enabled
On Form Studio 1 printers, you can enable High Volume Manufacturing mode to keep your printer ready at all times. To enable High Volume Manufacturing mode:
  1. On the printer’s touchscreen, tap Settings > Configuration. The Configuration screen appears.
  2. Toggle High Volume Manufacturing mode to ON. The toggle turns blue and a small factory icon appears in the status bar at the top of the screen.
When you enable High Volume Manufacturing mode, the printer:
  • Keeps the resin tank filled at all times, not just immediately before a print starts
  • Holds the resin at its target temperature for up to 75 minutes, keeping your resin ready to print during longer breaks in production.
