備考:
溶剤の保管や取扱い方法については、溶剤のサプライヤが発行している安全データシート(SDS)に記載されている内容を常に一次情報源としてご参照ください。
備考:
The Form Studio Wash+Cure removes uncured resin from the surface of printed parts by simultaneously soaking and moving them in a solvent. The machine can be used with Formlabs Resin Washing Solution, isopropyl alcohol (IPA), or tripropylene glycol monomethyl ether (TPM).
After your parts are washed and dried, swap the wash bucket for the turntable and switch the machine to cure mode. Place the printed parts on the turntable and post-cure them so the resin achieves its optimal mechanical properties.
The table below indicates the recommended times to wash and post-cure parts printed in Formlabs resins using the Form Studio Wash+Cure. Formlabs updates wash settings periodically with new and improved materials. Check for updated wash settings when using a new resin or revised formulation.
Note:
When using TPM, wash your printed parts as you would with IPA. Use longer wash times if necessary—some resins will not absorb TPM or swell as much with exposure to the solvent. Refer to the support article Washing prints with TPM for more information about the TPM wash process and the effect of TPM on resins.
| Resin | Wash time | Post-cure time |
| Alpha Black Resin V1 | 5 minutes (or until clean) | 5 minutes |
| Alpha Clear Resin V1 | 5 minutes (or until clean) | 5 minutes |
| Alpha Fast Resin V1 | 5 minutes (or until clean) | 5 minutes |
| Alpha Grey Resin V1 | 5 minutes (or until clean) | 5 minutes |
| Alpha Model Resin V1 | 5 minutes (or until clean) | 5 minutes |
| Alpha White Resin V1 | 5 minutes (or until clean) | 5 minutes |
| Flexible 80A Resin V2 |
5 minutes + 5 minutes (or until clean) Wash parts printed in Flexible 80A Resin V2 in two cycles, preferably using fresh solvent for the second wash. |
Step 1 (optional): Place dry parts in a glass beaker (or other UV-transparent container) and completely submerge the parts in room temperature water. Cure for 5 minutes. Step 2: Remove parts from water. Cure for 30 minutes. |
| Tough 1500 Resin V2 (Form Studio 1) |
10 minutes (or until clean)
25 minutes |
| True Cast Resin V1 |
5 minutes Dry with compressed air, rinse with fresh solvent, then dry with compressed again. |
3 minutes |
推奨洗浄時間の変更
以下の場合、推奨洗浄時間を延長する必要があります。
使用済み溶剤の再利用または廃棄
使用済み溶剤の安全な廃棄方法については、サポート記事イソプロピルアルコール(IPA)、Formlabs Resin Washing Solution、トリプロピレングリコールモノメチルエーテル(TPM)をご参照ください。
備考:
液体または部分的に硬化したレジンを排水溝に流したり、家庭ゴミといっしょに廃棄したりしないでください。溶けたレジンが含まれている溶剤を排水溝に流したり、家庭ゴミといっしょに廃棄したりしないでください。使用済み溶剤の安全かつ適切な処理方法は、地域によって異なります。
