Adding and removing printers on Dashboard
Dashboard allows you to remotely monitor your prints and printers, track material usage, and explore past and future Formlabs purchases. Add printers to Dashboard to start tracking them. Remove them from Dashboard if you no longer wish to track their activity.
Once the printer is registered to Dashboard and Dashboard logging is enabled on the printer, the printer can begin to send data to Dashboard as long as the Wi-Fi or Ethernet connections are able to access the internet. Connecting to a local area network is not sufficient for sending data to Dashboard.
Note:
If someone has already registered the printer, attempting to re-register the printer using the four digit verification code will add your account to the printer group as a member.
Adding printers to Dashboard
For Form 4 generation printers running firmware versions 1.4.1 or older, enable Dashboard Logging before adding your printer to Dashboard.
Enable Remote printing and monitoring.
Connect a printer to Dashboard using the personal registration code from the printer's Settings menu.
  1. Ensure the printer's firmware is up to date.
  2. Navigate to the Dashboard registration menu on your printer's touchscreen:
2.
Form 3 generation
Form 3L generation
Fuse 1 generation
Form 4 generation
Form 4L generation
Fuse X1
Tap Settings > Connectivity > Register to Dashboard. Tap Settings > Connectivity > Remote printing and monitoring > Add account.
Note:
If the printer is already registered to Dashboard, the touchscreen displays the group information.
  1. Tap Register. A unique four-character code appears.
Form 2 touchscreen asking to register to dashboard
  1. The touchscreen displays a custom registration code: a sequence of four alphanumeric characters, 0–9 and A–Z.
Form 2 touchscreen showing dashboard registration code
  1. Open Dashboard online at formlabs.com/dashboard and log in.
  1. Click Printers. A list of your printers and printer groups appears. If this is your first time registering a printer, the page is blank.
Within Dashboard, the 'Printers' menu item is highlighted on the menu running along the left side of the screen.
  1. Click + Add Printer. The Add New Printer window appears
Add New Printer window November 2024
  1. Enter the registration code into Dashboard
Enter registration code.
  1. Click Add. Your printer is added to your Dashboard or to the selected group./li>
Note:
If the printer is already registered to Dashboard, this process adds to the existing Printer Group.
  1. Confirm the printer's registration with Dashboard and the printer's touchscreen.
A printers touchscreen displays a success message.
Tip:
Your Dashboard account uses the same log-in credentials to access orders and saved addresses for the store, as well as your newsletter and mailing preferences.
Removing a printer from Dashboard
If you no longer want to track a printer on Dashboard, you can delete it. Once a printer is registered to a Printer Group in Dashboard, it cannot be added to another. The printer must be moved or deleted from its current Printer Group first.
Note:
Only an admin can delete a printer from a Printer Group.
To delete a printer from Dashboard:
  1. Log in to Dashboard.
  2. Click Printers. A list of your printers and printer groups appears.
  3. Click Organize Printers. The Edit Printers page appears.
Organize Printers.
  1. Select the checkbox next to each printer you want to remove. If the printer is part of a group and you are not an admin of the group, the checkbox is not available.
Checkboxes.
  1. Click Delete Selected to delete the selected printers from Dashboard and remove them from their respective groups.
