Can I dye Formlabs resins?
Color Resin V5
Color Resin V5 makes it possible to print custom-color parts with SLA 3D printers with consistency and high accuracy.
Parts printed with Color Resin V5
To order Color Resin V5 in custom colors, enter Hex codes or RGB profiles to order resin in a spectrum of colors to match your brand, product line, or creative vision. When ordering Color Resin V5, the store page will show you your requested color and the closest achievable color. Learn more about color tolerancing here.
Color Resin V5 is custom-manufactured in one week for a time-efficient and cost-effective solution for creating easy and affordable custom-colored SLA parts, including color-coded jigs and fixtures, realistic prototypes, and high-quality end-use parts.
Color Resin V5 is compatible with Form 4 and Form 4L generation printers, and is currently only available in the USA. For color printing on previous generations or in other regions, try Color Kit.
Color Kit
Color Kit enables you to print many models in one consistent color, right off the printer, without the additional work of finishing and painting.
Color Kit contains a Color Base cartridge and all five Color Pigments. Use Color Kit to mix and print matte, opaque parts in a range of colors without the manual work of finishing and painting.
Color Kit is compatible with the following SLA printers:
Adding third-party materials, dyes, or other substances to Formlabs resins alters the chemical composition of the resin. This may prevent the photoinitiators from functioning properly and may void your warranty.
Color Kit (Form 2, Form 3, and Form 3L printers)
Color Kit (Form 4 and Form 4L generation printers)
