Form Cure V2 time and temperature settings
Formlabs updates post-curing settings periodically with new and improved materials. Download the latest PDF version (only English), and check for updated post-curing settings.
Select the material type and version to see the recommended Form Cure V2 time and temperature settings. To post-cure previous resin formulations with the Form Cure, use the recommended time and temperature for the closest resin version.
Over-curing is acceptable, unless otherwise stated. Increase the post-curing time for thick, bulky parts because they are slower to heat to the proper temperature.
For parts printed in a Formlabs resin for biocompatible applications, follow the post-curing steps in the relevant instructions for use or application guide. For Formlabs Fast Cure settings, see the support article Fast Cure time settings.
Tip:
Looking for settings for the Form Cure V1? Click here.
Form Cure V2 settings
Downloadable PDF
Formlabs updates post-curing settings periodically with new and improved materials. Download the latest PDF version (English only), and check for updated post-curing settings when using a new resin or revised formulation.
