Alpha Black Resin
Alpha Clear Resin
Alpha Fast Resin
Alpha Grey Resin
Alpha Model Resin
Alpha White Resin |
Default |
1 min |
No heat |
| Maximum strength |
5 min |
60 °C |
| Alumina 4N Resin |
N/A |
N/A |
N/A |
| BEGO™ VarseoSmileⓇ TriniQⓇ Resin |
Full post-cure |
Refer to the Compatibility Overview for washing and post-curing instructions for this resin. View the PDF at the attached link. |
| BioMed Amber Resin |
Full post-cure² |
Refer to the Manufacturing Guide for washing and post-curing instructions for this resin. |
| BioMed Black Resin |
Full post-cure² |
| BioMed Clear Resin |
Full post-cure² |
BioMed Durable Resin V1
BioMed Durable Resin V1.1 |
Full post-cure² |
BioMed Flex 50A Resin11
(formerly BioMed Elastic 50A Resin) |
Full post-cure² |
| BioMed Flex 80A Resin11 |
Full post-cure² |
| BioMed White Resin |
Full post-cure² |
| Black Resin V4/V4.1 |
Default |
10 min |
60 °C |
| Black Resin V5 |
Default |
1 min |
No heat |
| Full cure |
5 min |
60 °C |
Castable Wax Resin
Castable Wax 40 Resin |
N/A3 |
N/A |
N/A |
| Ceramic Resin |
N/A¹ |
N/A |
N/A |
| Clear Resin V4 |
Default |
5 min |
60 °C |
| Clear Resin V4.1 |
Default |
7 min |
60 °C |
| Clear Resin V5 |
Default |
1 min |
No heat |
| Full cure |
5 min |
60 °C |
| Color Kit |
Default |
10 min |
60 °C |
| Color Resin V5 |
Default |
1 min |
N/A |
| Full cure |
10 min |
60 °C |
| Custom Tray Resin |
Full post-cure² |
| Dental LT Clear Resin V2 |
Full post-cure² |
Dental LT Comfort Resin V1
Dental LT Comfort Resin V1.1 |
Full post-cure² |
| Denture Base Resin V1 |
Full post-cure² |
Refer to the Instructions for Use for washing and post-curing instructions for this resin. |
| Denture Base Resin V2 |
Full post-cure² |
| Denture Teeth Resin |
Full post-cure² |
| Draft Resin V2 |
Better elongation |
5 min |
No heat |
| Better UTS |
5 min |
60 °C |
Durable Resin V2
Durable Resin V2.1 |
Full post-cure4 |
12 min |
60 °C |
Flexible 50A Resin
(formerly Elastic 50A Resin V2) |
Full post-cure5 |
7 min |
70 °C |
| ESD Resin |
Default |
10 min |
70 °C |
| Fast Model Resin |
Default |
1 min |
No heat |
| Flame Retardant Resin |
Default |
5 min preheat
10 min post-cure |
100 °C |
Flexible 80A Resin V1
Flexible 80A Resin V1.1 |
Default |
3 min |
60 °C |
| Flexible 80A Resin V2 |
Default |
Cycle 15: 5 min
Cycle 2: 5 min |
Cycle 15: No heat
Cycle 2: 80 °C |
| Grey Resin V4 Grey Resin V4.1 |
Default |
10 min |
60 °C |
| Grey Resin V5 |
Default |
1 min |
No heat |
| Full cure |
5 min |
60 °C |
| Grey Pro Resin |
Default |
8 min |
80 °C |
| High Temp Resin V2 |
Default |
15 min |
80 °C |
| IBT Resin |
Full post-cure² |
| IBT Flex Resin |
Full post-cure² |
| Model Resin V2 |
Default |
10 min |
60 °C |
| Model Resin V3 |
Default |
2 min |
60 °C |
| Permanent Crown Resin |
Full post-cure² |
Refer to the Instructions for Use [EN] [EU] for washing and post-curing instructions for this resin. |
| Precision Model Resin |
Default |
1 min |
No heat |
| Premium Teeth Resin |
Full post-cure² |
| PU Rigid 650 Resin |
N/A |
Refer to the support article Using PU Rigid 650 Resin. |
| PU Rigid 1000 Resin |
N/A |
Refer to the support article Using PU Rigid 1000 Resin. |
| Rigid 4000 Resin |
Default |
6 min |
80 °C |
Rigid 10K Resin V1
Rigid 10K Resin V1.1 |
Default |
3 min preheat
7 min post-cure |
80 °C |
| Silicone 40A Resin |
Default |
10 min |
60 °C |
| Surgical Guide Resin |
Full post-cure² |
| Temporary CB Resin |
Full post-cure² |
| Tough 1000 Resin |
Default |
12 min |
70 °C |
| Low warp |
12 min |
No heat |
Tough 1500 Resin V1
Tough 1500 Resin V1.1
Tough 1500 Resin V2 |
Low warp |
12 min |
No heat |
| Default |
12 min |
70 °C |
Tough 2000 Resin V1
Tough 2000 Resin V1.1 |
Low warp |
7 min |
No heat |
| Default |
7 min |
70 °C |
| Tough 2000 Resin V2 |
Low warp |
12 min |
40 °C |
| Default |
12 min |
70 °C |
| True Cast Resin V1 |
Full post-cure |
3 min |
N/A |
White Resin V4
White Resin V4.1 |
Default |
10 min |
60 °C |
| White Resin V5 |
Default |
1 min |
No heat |
| Full cure |
5 min |
60 °C |
