Tip:
When opening the Fuse Sift hood, either hang the gloves from the hook on the inner face of the Fuse Sift Glovebox or pull the gloves inside-out to avoid spilling loose powder.
The Fuse Sift Glovebox and Parts Carrier help contain the loose powder in your Fuse Sift, keeping your hands and workspace clean. Use the gloves when handling and depowdering your printed parts, then put them in the Parts Carrier to move them to the Fuse Blast or any other finishing stations.
Installing the Fuse Sift Glovebox
The Fuse Sift Glovebox attaches to the Fuse Sift hood, fully enclosing the work surface. To install the Fuse Sift Glovebox:
Using the Fuse Sift Glovebox and Parts Carrier
After installing the Fuse Sift Glovebox, use it when unpacking and recovering your printed parts.
Tip:
Maintaining the Fuse Sift Glovebox
Cleaning the Fuse Sift Glovebox gloves
After using the Fuse Sift Glovebox, be sure to brush or vacuum excess powder off the gloves before opening the hood.
Replacing the Fuse Sift Glovebox gloves
Over time, the Fuse Sift Glovebox gloves may develop holes or tears. Replace the gloves if you notice any damage to prevent powder from escaping the work surface.
To replace the gloves:
