Unboxing the Fuse X1
The Fuse X1, vacuum conveyor, and build unit are delivered in a single crate on a pallet. Other accessories and devices are packaged separately. The custom packaging the printer arrives in is specially designed to protect the machine during shipping. During unboxing, inspect the product for any damage or missing items. In the case of damage or missing items, contact Formlabs Support or a certified service provider.
Unboxing the printer
Caution:
Removing the machine from its packaging requires at least two people that are comfortable lifting and moving large and heavy objects.
  1. Using a forklift, move the crate to a large, flat area, ideally near the printer’s final installation location. The printer crate can be lifted from either the short or long end. Leave enough space to open and lower the narrow sides of the crate.
Uncrating the Fuse X1
  1. The right-hand crate panel is hinged at the bottom so it can be lowered to create a ramp. Identify the ramp side and ensure there is enough space for the ramp to lower.
  1. Unlatch and remove the top and side panels of the crate.
  2. Carefully lower the ramp.
  3. Remove the vacuum conveyor box and set it aside.
  4. Remove the foam on top of and in front of the build unit. Roll the build unit down the ramp and set it aside.
  1. Locate and remove the rectangular lifting frame located underneath the printer in the crate.
  2. Insert the lifting frame under the printer on the side opposite the ramp until it reaches its hard stops.
  1. The printer rests on four blocks, one under each corner of the machine. With the help of another person, use the lifting frame as a lever to carefully lift the machine by 1–2 inches. Remove the two blocks from under the side of the printer closest to the lifting frame. Lower the printer onto the crate.
  2. Repeat step 9 on the right side of the printer. Once all four corner blocks are removed, the printer should rest on its wheels.
Caution:
After this step, the printer is on wheels and can roll if the crate is not on a level surface.
  1. With the help of another person, carefully roll the printer down the crate ramp and into its installation location.
  2. Remove any additional foam or other packaging from the outside of the printer.
Tip:
Formlabs recommends moving the Fuse X1 on its integrated wheels. If you come to a threshold that is too large for the printer wheels, use a pallet jack or pallet truck with long, narrow forks to help move the printer. For example, model H-2640 from Uline has a fork size of 72 × 21 in. Insert the forks under one of the short ends of the printer so they span the entire width of the machine.
Next steps
After unboxing the printer, proceed with installation.
