Wash the printed parts for 2 minutes in Ceramic Wash Solution. Do not allow Alumina 4N Resin parts to come into contact with water or IPA, as this will cause cracking. Use a separate wash bucket to prevent loose ceramic particles from adhering to non-Alumina 4N parts. Minimize the amount of time the printed part is covered in Ceramic Wash Solution to prevent cracking.
Gently blow dry parts with air, focusing the airflow on corners and crevices. Wipe accessible surfaces dry with a paper towel. Aggressive drying rates can cause cracking.
Once parts are removed from the build platform, the build platform and any peripherals can be cleaned with IPA or soapy water to remove liquid resin. Remove rafts using a spatula and a hammer. Take care to avoid injury from sudden movements, and wear safety glasses.
Parts printed with Alumina 4N Resin are easy to sand in their green state. Dry sand the parts or use the Ceramic Wash Solution as a lubricant.
