Danger:
Always consult the safety data sheet (SDS) from Formlabs Resin Washing Solution as the primary source of information.
Formlabs Resin Washing Solution is a non-flammable solution for cleaning resin off printed parts. This solution cleans as well as IPA, but can dissolve twice as much resin before becoming saturated. Reduce wash replenishing and cost per washed part with a part-cleaning solution safe enough for any workspace.
Formlabs Resin Washing Solution is recommended as a solvent for the Form Wash V2 and Form Wash L.
Handling Formlabs Resin Washing Solution
Formlabs Resin Washing Solution is non-flammable per GHS classification, mitigating storage and environmental health and safety concerns. Wear disposable non-reactive gloves (nitrile or neoprene) when working with Formlabs Resin Washing Solution.
Danger:
Wash process
Formlabs Resin Washing Solution can be used with the Form Wash V2 or the Form Wash L.
To wash parts in Formlabs Resin Washing Solution:
Post-curing parts that are still wet after washing with Resin Washing Solution can damage your equipment. On Form Cure V1 and Form Cure L V1 units, the reflective film on the inner walls will fog and become less effective. On Form Cure V2 and Form Cure L V2 units, the film on the inner face of the door will bubble and peel.
Cleaning the build platform
If the build platform has also been washed with Formlabs Resin Washing Solution, clean the build platform thoroughly before using it again.
Replacing used solvent
Formlabs Resin Washing Solution has twice the longevity of IPA and minimal evaporation, leading to less frequent top-offs and full changeouts of washing solution. If a thin film of resin remains on printed parts after washing with the solution, the solution is overly saturated with resin and should be replaced.
Form Wash L V1 and Form Wash L V2 units with firmware version 1.4.0 or later can track the saturation of your Resin Washing Solution using the solvent monitor.
Alternatively, monitor the saturation of your solvent using a hydrometer. The hydrometer packaged with the Form Wash does not measure the correct range of specific gravity for use with Formlabs Resin Washing Solution. A hydrometer that can measure a specific gravity of 0.900–1.000 should be used instead, such as this one sold by Cole-Parmer. The specific gravity of fresh Formlabs Resin Washing Solution is 0.94. When the specific gravity of the used Resin Washing Solution is above 0.975, it will not be fully effective as a final wash.
The water bath loses effectiveness when it is oversaturated with dissolved Formlabs Resin Washing Solution. Replace the water regularly and dispose of the water-solution in accordance with local regulations.
Cleaning a solvent spill
Spilled Formlabs Resin Washing Solution does not present an immediate fire or health hazard, but it does leave an oily residue that can be slippery. The solution evaporates very slowly, so the spill won’t dry by itself.
To clean up a Formlabs Resin Washing Solution spill:
Recycling or disposing of used Formlabs Resin Washing Solution
Over time, Formlabs Resin Washing Solution accumulates dissolved liquid resin, which reduces its efficacy. For best surface quality, replace the solution once parts do not come out well.
Danger:
Disposal
To safely dispose of contaminated Formlabs Resin Washing Solution:
Warning:
Do not pour liquid or partially cured resin into drains or dispose of it with household waste. Do not pour Formlabs Resin Washing Solution that contains dissolved resin into drains or dispose of it with household waste. Safe and appropriate disposal methods of used solvent vary by location. Follow local regulations when disposing of Formlabs Resin Washing Solution.
Recycling
The Formlabs Resin Washing Solution container is made of high-density polyethylene (HDPE). Empty containers of Resin Washing Solution can be recycled in accordance with local regulations.
Compatibility with Formlabs products
Formlabs resins
Caution:
Formlabs resins for biocompatible applications have not been tested with Formlabs Resin Washing Solution. For full compliance, post-process parts printed in resins for biocompatible applications in accordance with the Instructions for Use for the specific resin. If a manufacturer chooses to deviate from recommended instructions, it is the manufacturer’s responsibility to confirm performance and biocompatibility for their applications.
Formlabs Resin Washing Solution is not compatible with the Flexible and Elastic Resin family, Tough 1000 Resin V1, Tough 1500 Resin V2, Tough 2000 Resin V2, or resins that require a validated workflow (biocompatible resins, Flame Retardant Resin, etc.). The full list is given below:
Parts printed in all other Formlabs resins, such as the General Purpose Resins and Alpha Resins, can be washed with Formlabs Resin Washing Solution.
Finish Kit
Formlabs Resin Washing Solution is not intended for use in the Finish Kit rinse buckets, but can be used during the water soak.
Formlabs Resin Washing Solution is compatible for use with the Form Wash V2 and the Form Wash L wash buckets.
Form Cure and Form Cure L
The Form Cure does not vent air while operating, so any evaporated solvent will condense on the heater, fan, and internal surfaces. If a print that still has Formlabs Resin Washing Solution on it is placed in the Form Cure, the solution will evaporate off the print and condense on the inner surfaces of the Form Cure and Form Cure L. This can occasionally cause clouding on the reflective surfaces. Always let prints fully dry (whether they have been washed with IPA, TPM, water, or the Formlabs Resin Washing Solution) before placing them in the Form Cure or Form Cure L.
Formlabs SLA printers
Do not use Formlabs Resin Washing Solution to clean your Formlabs SLA printers, particularly optical surfaces.
Additional resources
