Legacy PreForm archive (2023)
Release notes from the year 2024 are available to view. To find the most recent versions of PreForm, check the support article PreForm downloads and release notes.
2024 releases
Previous versions of PreForm are available for download, as well as a list of their associated changes.
PreForm 3.43.1 — December 18, 2024
PreForm 3.43.1 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, Form 4BL, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features bug fixes for issues with PreForm 3.43.0 and new Default print settings for Form 4 and Form 4L generation printers.
Windows Download: Link
Mac Download: Link
  • Bug fixes:
    • Fixed issue where users were unable to load saved dental presets or save new ones in PreForm 3.43.0
    • Fixed crash that could occur on startup in PreForm 3.43.0
  • Print settings updates:
    • Added Default Setting for BioMed Flex 80A V1 at 100 micron for Form 4BL printers
    • Added Default Setting for Castable Wax V1 at 50 micron for Form 4L generation printers
    • Updated print settings for Flexible 80A V1.1, Elastic 50A V2, BioMed Elastic 50A V1, and Rigid 10K V1.1 Resins with reduced in-print wiping speed to mitigate mixer stalls on Form 4L generation printers
    • Reduced preprint wiping speeds for Rigid 10K V1.1 Resin at 100 micron on the Form 4L generation printers to mitigate mixer stalls
    • Added Default Setting for Black V4.1 Resin at 25 micron for Form 3 generation printers
    • Added Default Setting for Clear V4.1 Resin at 25 micron for Form 3 generation printers
    • Updated print setting to V1.1 for Grey V5 Resin at 50 micron on Form 4L generation printers to mitigate early layer delamination issues
    • Updated print setting to V1.1 for Fast Model V1 Resin at 100 micron on Form 4L generation printers to mitigate early layer delamination issues
  • Fuse 1: compatible with firmware version 1.15.3 and later
  • Fuse 1+: compatible with firmware version 1.15.3 and later
  • Form 4B: compatible with firmware version 1.7.2 and later
  • Form 4: compatible with firmware version 1.7.2 and later
  • Form 4L: compatible with firmware version 1.9.0 and later
  • Form 4BL: compatible with firmware version 1.9.0 and later
  • Form 3BL: compatible with firmware version 1.10.8 and later
  • Form 3L: compatible with firmware version 1.10.8 and later
  • Form 3B/3B+: compatible with firmware version 1.19.7 and later
  • Form 3/3+: compatible with firmware version 1.19.7 and later
  • Form 2: compatible with firmware version 1.19.25 and later
PreForm 3.43.0 — December 10, 2024
PreForm 3.43.0 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, Form 4BL, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release introduces Model grouping on Fuse 1 generation printers, improves Hollowing, and reduces touch tip size to 0.1 mm on Form 4 and Form 4L generation printers.
Mac Download: Link
  • New features:
    • CAD file import (Beta): Directly import native CAD files without converting them.
    • Model grouping (SLS): Organize and manage your models using the new model grouping feature. Select models and use the right click menu to group.
    • Import folders: Import a folder of models directly into PreForm, eliminating the need to import files one by one and streamlining your workflow. This workflow is further improved for SLS by automatically putting models imported by folder into a group.
  • Improvements:
    • Fewer warnings when setting up jobs: PreForm will no longer warn when you use small touchtips for supports. Use caution when using small touchtips for large parts - these may come off supports and lead to a print failure.
    • Download Print Report as CSV (SLS): Export your print data to CSV format for easy analysis and record-keeping.
    • Single sign-on with Formlabs Dashboard: Use your existing Formlabs Dashboard login credentials to log into PreForm automatically when you're already signed into Dashboard in your browser.
    • Hollowing: Changed the inner surface “Feature Size” parameter from “Low/Med/High” to a more precise size in millimeters.
  • Bug fixes:
    • Fixed an issue that caused Form Cure devices to stay on a black screen during firmware update with PreForm 3.42.0 and 3.42.1
    • Removed pause between end of print and start of homing on Form 4 and Form 4L generation printers, saving around 20 seconds per print
    • Fixed an issue that would cause some Dental resins to appear red in the Job Setup sidebar
    • Reduced allowable touch tip size to 0.1 mm for all print settings on Form 4 and Form 4L generation printers
    • Reduced the small touch tip warning to 0.2 mm for all print settings on Form 4 and Form 4L generation printers
    • Note: Adjusting touch tip size may lead to poor print performance or increased print failure rate
  • Known issues
    • PreForm is unable to load saved dental presets or save new ones. Roll back to version 3.42.1 to access your dental presets.
PreForm 3.42.1 — November 27, 2024
PreForm 3.42.1 is a recommended update for all Formlabs printers. This release features improved raft label text for Form 4 and Form 4L generation printers, a new Form X materials category, and support for High Temp, Flame Retardant, ESD, Clear Cast, and Tough 2000 Resin on Form 4L generation printers.
Mac Download: Link
  • New features:
    • New Form X materials category: Access powerful manufacturing technologies with Formlabs PU Rigid and Alumina 4N materials. These are now available under the Form X materials category in the Job Setup screen.
    • Improved raft label text: Improved raft label text for all settings on Form 4 and Form 4L generation printers.
    • Form 4/4B: Removed the New Fine Feature Setting for Grey Resin V5 at 100 microns
    • Form 4/4B: Added the Finer Touchpoints Setting V2.0 for Grey Resin V5 at 100 microns. This setting uses 0.2 mm touchpoints for easy support removal and minimal support marks but has increased print times.
    • Form 4L/4BL: Added support for High Temp Resin V1 with 100 micron print settings
    • Form 4L/4BL: Added support for Flame Retardant Resin V1 with 100 micron print settings
    • Form 4L/4BL: Added support for ESD Resin V1 with 100 micron print settings
    • Form 4L/4BL: Added support for Clear Cast Resin V1 with 100 micron print settings
    • Form 4L/4BL: Added support for Tough 2000 Resin V1.1 with 50 micron print settings
    • Form 4L/4BL: Updated Black Resin V5 at 100 microns to setting V1.1 to improve reliability for larger parts
PreForm 3.42.0 — November 6, 2024
PreForm 3.42.0 is a recommended update for all Formlabs printers. This release features added support for the Timelapse feature on Form 4L generation printers, improved part texturing performance and part hollowing, and updated Default print settings for Flame Retardant Resin on Form 4 generation printers.
Mac Download: Link
  • New features:
    • Timelapse on Form 4L: Create stunning Timelapse videos of your print in progress. Turn on the option in PreForm and log into Dashboard to access your videos. Note: enabling the Timelapse feature may increase print time and impact print quality or success. Requires firmware version 1.9.0 or later.
  • Improvements:
    • Better part texturing performance: Improve how the part texturing feature works by controlling the number of triangles in the scene. Use the slider in the Texture flyout and change the max triangle count. The max count depends on your computer’s hardware, available resources, and the number of models you’ve imported in PreForm. You might need to experiment to determine the right value for you.
    • Faster part hollowing: Hollow parts faster and monitor progress with the progress bar. Improved hollowing speed and progress bar accuracy.
    • Detailed warnings when printing with tall parts: Tall parts require more attention when they’re being removed from the printer and during post-processing. PreForm will provide helpful reminders when you’re printing a tall part with instructions for Form Cure L and Form Wash L. (Form 4L)
    • Increased accuracy of cartridge volumes: With more accurate cartridge volume, you can make sure the printer has enough resin for your print job. (Form 4 and Form 4L generation printers)
  • Bug fixes:
    • Fixed issue where backspace key did not delete selected touchpoints
    • Form 4/4B: Updated Default print setting for Flame Retardant at 100 microns to improve print reliability
    • Print Settings Editor: Renamed the “Perimeter to Nominal Geometry Spacing” setting to “Outer Boundary Offset” (Form 3/3L and Fuse 1/1+). Note: Any existing print setting with a custom “Perimeter to Nominal Geometry Spacing” value will be reverted to default. Make sure to enter the values again.
PreForm 3.41.2 — October 31, 2024
PreForm 3.41.2 is a recommended update for all Formlabs printers. This release features an updated Scan to Model workflow in Dental Workspace, restored support for Windows 7, and various new print settings for Form 3L, Form 3BL, and Form 4L generation printers.
Mac Download: Link
  • New features:
    • Updated the Scan to Model workflow in the Dental Workspace to include automated orientation, trim height suggestions and model hollowing with honeycombing infill. Learn more here.
  • Bug fixes:
    • Restored support for Windows 7
    • Fixed a crash that could occur while communicating with Form 4 generation printers
    • Form 3L/Form 3BL: New Default print settings for Black Resin V4.1 at 100 microns
    • Form 4BL: New Default print settings for BioMed Black Resin V1 at 100 microns
    • Form 4BL: New Default print settings for BioMed Elastic Resin V1 at 100 microns
    • Form 4BL: New Default print settings for BioMed White Resin V1 at 100 microns
    • Form 4L/Form 4BL: New Default print settings for Elastic Resin V2 at 100 microns
  • Form 4L: compatible with firmware version 1.7.0 and later
  • Form 4BL: compatible with firmware version 1.7.0 and later
PreForm 3.41.1 — October 25, 2024
PreForm 3.41.1 is a recommended update for all Formlabs printers. This release features a bug fix for an issue with Nylon 12 Powder v5.1 Speed Optimized Print Settings on Fuse 1+ 30W printers, and a fix for a crash that would occur when communicating with Form 4 or Form 4L generation printers over a network.
Mac Download: Link
  • Bug fixes:
    • Fixed issue with Fuse 1+ 30W Nylon 12 Powder v5.1 Speed Optimized Print Settings where some laser paths were out of order, leading to part defects in some cases
    • Fixed a crash which could occur when communicating with Form 4 or Form 4L generation printers over a network
PreForm 3.41.0 — October 15, 2024
PreForm 3.41.0 is a recommended update for all Formlabs printers. This release features added support for Form 4L materials, introduces Formlab API, adds model label and texture editing in PreForm, and various new materials for Formlabs printers.
Mac Download: Link
  • New features:
    • Support for Form 4L/4BL materials:
      • Form 4L: 18 print settings covering 12 unique materials
      • Form 4BL: 25 settings covering 19 unique materials
      • For a full list of Form 4L/4BL materials, settings, and expected release dates see the Form 4L Generation Print Settings Roadmap.
    • Support for Resin Pumping System: Resin Pumping System is now available for Form 4 and Form 4L.
    • Hollow and Holes: Hollow parts (Beta) and create drain holes for faster printing and reduced material usage.
    • Cages: Use part cages for Fuse Series prints to improve your post processing workflow for small and fragile parts.
    • Texture: Easily simulate mass production finishes (Beta).
    • Label: Emboss or engrave text onto parts to improve traceability.
    • Formlabs Print Settings (FPS) files: Unlock collaboration by sharing print settings as FPS files (Beta). Easily apply fine-tuned print settings created by others by importing FPS files.
    • SLS is Open: Fuse Series users can now extend their printer’s capabilities by leveraging Print Settings Editor, Open Material Mode, and Supplier Certified Materials. Expand SLS printing beyond the Formlabs portfolio of materials by purchasing Open Material Mode for Fuse Series printers.
    • Formlabs API: Tap into the Formlabs software ecosystem with a powerful API to build integrations and automate workflows.
    • Preheating: A Form 4 or Form 4L printer in PreForm will start preheating the resin when selected if the feature is enabled on the printer. Requires firmware 1.8.0.
    • New SLS materials: Nylon 12 White Powder and Nylon 12 Tough Powder (Fuse 1+ 30W)
    • New Form 3/B materials: Added support for Clear Resin V4.1 and Black Resin V4.1 with 50 and 100 micron print settings
    • New Form 3L/B material: Added support for Clear Resin V4.1 with 100 micron print setting
    • Clear Cast Resin is now available on Form 2 with 50 and 100 micron print settings
  • Known issues:
    • No support for adaptive thickness in Print Settings Editor: Setting a print setting to use an adaptive thickness will have no impact. PreForm will treat it as a fixed layer thickness.
PreForm 3.40.3 — October 7, 2024
PreForm 3.40.3 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features a bug fix for where PreForm was generating excessive supports on Form 3 and Form 4 generation printers.
Mac Download: Link
  • Bug fixes:
    • Fixed issue where PreForm was generating excessive supports on Form 3 and Form 4 generation printers
PreForm 3.40.2 — October 1, 2024
PreForm 3.40.2 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features a bug fix for an issue where PreForm would crash on startup and added support for Silicone 40A Resin with 100 micron print settings on Form 4 generation printers.
Mac Download: Link
  • Bug fixes:
    • Fixed an issue where PreForm would crash on startup on some computers
  • Settings updates:
    • Added support for Silicone 40A Resin V1 with 100 micron print settings on Form 4 generation printers
Note:
Silicone 40A Resin requires careful print preparation. For best success and part quality, please reference Formlabs design guidelines article.
PreForm 3.40.1 — September 17, 2024
PreForm 3.40.1 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features bug fixes causing false debris detefction with viscous resins on Form 4 generation printers, and updated Speed Optimized print settings for Nylon 12 Powder on Fuse 1+ 30 W printers.
Mac Download: Link
Note:
Form 4 generation printers require an update to firmware version 1.7.2 or later.
  • Bug fixes:
    • Fixed issue causing false debris detection errors during print when using viscous resins on Form 4 generation printers
    • Fixed crashes occurring during startup and support generation
    • Fixed incorrect German translation for Supports
    • Updated Speed Optimized print setting for Nylon 12 Powder on the Fuse 1+ 30 W at 0.110 mm. V5.1 offers improvements to dimensional accuracy, reduced risk of Surface Armor curl and drag failures, and improvements to surface finish of certain geometries compared to the V5.0 setting.
PreForm 3.40.0— September, 12 2024
PreForm 3.40.0 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release introduces Formlabs Certified Materials that let you print with a curated selection of premium certified third-party materials with validated print settings on Form 4 and Form 4B printers. Additional updates include an added Print Report for SLS printers and the launch of Formlabs Clear Cast Resin for investment casting applications.
Mac Download: Link
  • New features:
  • Improvements:
    • Redesigned toolbar: Easily find the tools you need with a cleaner redesigned toolbar and labeled icons
    • Start your prints with fewer clicks: When you’re done setting up your job, click the Print Now button at the bottom of the right sidebar and instantly send the file to your printer
  • Bug fixes:
    • Fixed bug where the Timelapse toggle was not always visible in the Job Setup screen on Form 4 generation printers
    • Fixed bug where the clipping plane was not correctly rendered when using the Scan to Model feature on Form 3B and Form 4B printers
    • Restored missing notice for Fast Model resin when printing with Fast Arch 160 micron setting on Form 4 generation printers
    • Added support for BEGO™ VarseoSmile® TriniQ® Resin with 50 and 100 micron print settings on Form 4B printers
    • Added support for Clear Cast Resin with 50 and 100 micron print settings on Formlabs LFS and LFD printers
  • Known issues:
    • Dental Workspace issue where changing to a printer with a different material in Job Setup always applies the previous preset overrides such as orientation and support on Form 3B, Form 3BL, and Form 4B printers. This issue can be avoided by performing printer selection before setting up any models.
  • Fuse 1: Compatible with firmware version 1.15.3 and later
  • Fuse 1+: Compatible with firmware version 1.15.3 and later
  • Form 4B: Compatible with firmware version 1.3.0 and later
  • Form 4: Compatible with firmware version 1.3.0 and later
  • Form 3BL: Compatible with firmware version 1.10.8 and later
  • Form 3L: Compatible with firmware version 1.10.8 and later
  • Form 3B/3B+: Compatible with firmware version 1.19.7 and later
  • Form 3/3+: Compatible with firmware version 1.19.7 and later
  • Form 2: Compatible with firmware version 1.19.25 and later
PreForm 3.39.2— September, 3 2024
PreForm 3.39.2 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features new Fast Arch print settings and a bug fix for false positive debris detection for Fast Model Resin on Form 4 generation printers.
Mac Download: Link
  • Bug fixes:
    • Fixed false positive debris detection with Fast Model Resin on Form 4 and Form 4B printers: When printing with Fast Model Resin and using the Fast Arch 160 micron setting, during preprint, the printer would incorrectly detect debris and cancel printing.
    • Fast Arch print setting for Fast Model Resin on Form 4 and Form 4B printers: Reduced aggressive preprint wiping for Fast Model Resin.
PreForm 3.39.1— August, 29 2024
PreForm 3.39.1 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features improved debris detection on Form 4 and Form 4B printers, and new Default print settings for Preium Teeth Resin for Form 4B printers.
Mac Download: Link
  • Improvements:
    • Improved debris detection on Form 4 and Form 4B printers. While preparing to print, the printer would incorrectly detect debris and stop the print. This release increases the accuracy of debris detection and reduces false positives.
    • New Default print settings for Premium Teeth Resin for Form 4B printers
      • Default print settings at 100 and 50 microns have improved support structures for reliability
      • Default print settings at 50 microns have improved mixer behavior to improve surface finish
PreForm 3.39.0 — August, 13 2024
PreForm 3.39.0 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features the ability to view the camera feed from Form 4 generation printers, cup mitigration improvements, bug fixes for issues with manual supports, and improvements to the Model Powder parameter for SLS printers.
Mac Download: Link
  • New features:
    • View the camera feed: Form 4 generation printers are equipped with an onboard camera. Select a Form 4 or Form 4 printer in the Job Setup screen to see the camera feed. During printing, use the camera feed to see how the print is coming along. When the printer is idle, use it to check for parts on the build platform.
  • Improvements:
    • Updated the Model Powder parameter under Model Properties to include three decimal places when printing with an SLS printer. This parameter now shows the mass of a model down to the gram.
    • Cup mitigation improvements: Form 4 printers will slow down layer printing speed if cups are detected. This improves surface finish and print reliability but might slow down the print. You can control this behavior using the Cup Mitigation Enabled toggle in the Print Settings Editor.
  • Bug fixes:
    • Fixed issue where jobs printed with Silicone 40A Resin on Form 3 and Form 3B printers could not be supported manually
    • Fixed bug where manual supports could not be added using the brush on some flat surfaces
    • Fixed issue where the red shading applied during manual support editing did not reset when exiting that mode
    • Updated cup mitigation parameters for small parts on all Form 4 resin settings
    • Added notice about Denture Teeth Resin being retired on December 3, 2024
  • Known issues:
    • PreForm may not remember the last selected print setting (such as Default or Legacy) when restarted. Make sure to reconfirm the desired print setting in Job Setup.
PreForm 3.38.1 — August 1, 2024
PreForm 3.38.1 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features added support for Open Material Model for Form 4 and Form 4B printers, improved cup artifact migration on Form 4, Form 4B, Form 3L, Form 3BL, Form 3/3+, and Form 3B/3B+ printers, and a bug fix affecting Dental Workspace for Form 2 printers.
Mac Download: Link
  • New features:
    • Added support for Open Material Mode to unlock the ability to print with any 405 nm photopolymer resin
  • Improvements:
    • Improved cup artifact mitigation. This may lead to slower print times for parts with cups.
  • Print setting updates:
    • New Default print settings for Alumina 4N Resin at 50 microns for Form 4 generation printers
  • Bug fixes:
    • Fixed bug affecting Dental Workspace
    • Fixed issue where adaptive layer thickness did not work correctly
  • Form 4B: compatible with firmware version 1.3.0 and later
  • Form 4: compatible with firmware version 1.3.0 and later
PreForm 3.38.0 — July 24, 2024
PreForm 3.38.0 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features improvements to the Job Setup card, the ability to rotate parts in 15° by holding down the Shift key, bug fixes for the auto-orientation feature in Dental Workspace, and new print settings for Form 4 and Form 4B printers.
For more information about PreForm 3.38.0, click here.
Mac Download: Link
  • New features and improvements:
    • Added more information in the Job Setup card about consumable status and printer readiness
    • Created more space in right sidebar by relocating the Print Summary panel between the right sidebar and the bottom left using the docking button
    • Enabled users to rotate parts in 15° by holding down the Shift key before or while rotating parts
    • New Default print settings for High Temp V2 Resin at 50 microns for Form 4 generation printers
    • New Default print settings for Denture Base V1 Resin at 50 microns for Form 4B printers
  • Bug fixes:
    • Fixed the auto-orientation issue with the splint and surgical guide templates in the Dental Workspace. In previous versions, these presets were rotating the models along the incorrect axis.
    • Fixed an issue where the additional time for creating timelapses was not included in the total time estimates
PreForm 3.37.5 — July 3, 2024
PreForm 3.37.5 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features new Default print settings for Tough 2000 on Form 4 and Form 4B printers.
Mac Download: Link
ProductWhat's New
Fuse 1
  • Compatible with firmware 1.15.3 and later
Fuse 1+
  • Compatible with firmware version 1.15.3 and later
Form 4B
  • Compatible with firmware 1.3.0 and later
  • New Default print settings for Tough 2000 V1.1 Resin at 50 microns and 100 microns
Form 4
Form 3BL
  • Compatible with firmware version 1.10.8 and later
Form 3L
Form 3B/Form 3B+
  • Compatible with firmware version 1.19.7 and later
Form 3/Form 3+
Form 2
  • Compatible with firmware version 1.19.25 and later
PreForm 3.37.4 — June 27, 2024
PreForm 3.37.4 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features new Beta print settings for Nylon 11 Powder on Fuse 1+ printers and introduces new Default print settings for Form 4 and Form 4B printers.
Mac Download: Link
ProductWhat's New
Fuse 1
Fuse 1+
  • Added new Beta v2.0 print settings for Nylon 11 Powder with improvements to surface finish of certain geometries
Form 4B
  • New Default print settings for Black V5 Resin at 25 microns
Form 4
Form 3BL
Form 3L
Form 3B/Form 3B+
Form 3/Form 3+
Form 2
PreForm 3.37.3 — June 20, 2024
PreForm 3.37.3 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features new Default settings for Form 4 and Form 4B printers, and a bug fix for Form 3L, Form 3BL, Form 3B/3B+, and Form 3/3+ printers for when some print settings were not applied to jobs in Fleet Control.
Mac Download: Link
ProductWhat's New
Fuse 1
Fuse 1+
Form 4B
  • Added New Fine Feature settings for Grey V5 Resin at 100 microns
  • New Default settings for Clear V5 Resin at 25 microns
  • New Default settings for Castable Wax V1 Resin at 25 microns
  • Minor accuracy adjustments for Flexible 80A Resin at 100 microns
Form 4
Form 3BL
  • Fixed bug where print settings like Fast Arches were not applied to some Fleet Control jobs
Form 3L
Form 3B/Form 3B+
Form 3/Form 3+
Form 2
PreForm 3.37.2 — June 11, 2024
PreForm 3.37.2 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features improved slicing performance for jobs with complex lattice structures when printing with TPU 90A Powder on Fuse 1 and Fuse 1+ printers, and a bug fix for v2.0 Speed Optimized Print Settings for TPU 90A Powder on Fuse 1+ printers.
Mac Download: Link
ProductWhat's New
Fuse 1
  • Improved slicing performance for jobs with complex lattice structures when printing with TPU 90A Powder
Fuse 1+
  • Fixed a bug in v2.0 Speed Optimized Print Settings for TPU 90A Powder
Form 4B
Form 4
Form 3BL
Form 3L
Form 3B/Form 3B+
Form 3/Form 3+
Form 2
PreForm 3.37.1 — June 10, 2024
PreForm 3.37.1 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release introduces support for the Open Material License for LFS printers, new Speed Optimized Print Settings for TPU 90A Powder on Fuse 1+ printers, and new Default Print Settings for Form 4 and Form 4B printers.
Mac Download: Link
ProductWhat's New
Fuse 1
Fuse 1+
  • Improved Print Settings for TPU 90A Powder to print finer features and more intricate lattices using the new v2.0 Speed Optimized Print Settings
Form 4B
  • Improved Default Print Settings for Elastic 50A V2 Resin and BioMed Elastic 50A V1 Resin to mitigate rare model duplications
  • New Default Print Settings for BioMed Durable V1 Resin at 100 microns
  • New Default Print Settings for LT Comfort V1 Resin at 100 microns
  • New Default Print Settings for Flexible 80A Resin v1.1 at 100 microns
  • New Default Print Settings for Grey V5 Resin at 25 microns
Form 4
  • Improved Default Print Settings for Elastic 50A V2 to mitigate rare model duplications
Form 3BL
  • Added Support for Material License to unlock the ability to print with any 405 nm photopolymer resin
Form 3L
Form 3B/Form 3B+
Form 3/Form 3+
Form 2
PreForm 3.37.0 — June 3, 2024
PreForm 3.37.0 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features improvements to Nylon 12 v4.0 Print Settings for Fuse 1+ printers, added support for Form 4 and Form 4B printers to use the Print Settings Editor, and various bug fixes.
Mac Download: Link
ProductWhat's New
Fuse 1
Fuse 1+
  • Fixed issue with Nylon 12 v4.0 Print Settings that caused some reduction in part accuracy and fine feature strength. The new v4.1 Print Settings reflect the initial v4.0 settings released in November 2023, which have improved fine feature preservation and accuracy.
Form 4B
  • Added support for Form 4 and Form 4B to use Print Settings Editor
  • Fixed issue that required selecting raft type twice in the Support flyout
  • Fixed issue where generated rafts did not have vent holes leading to excessive cup detection warnings
  • Fixed issue where jobs could not be sliced on Windows 11 Pro
Form 4
Form 3BL
Form 3L
Form 3B/Form 3B+
Form 3/Form 3+
Form 2
PreForm 3.36.3 — May 22, 2024
PreForm 3.36.3 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features new Default Print Settings for Form 4 and Form 4B printers, and improvements to their starting print temperatures.
Mac Download: Link
ProductWhat's New
Fuse 1
Fuse 1+
Form 4B
  • New Default Print Settings for BioMed Amber V5 Resin at 50 microns
  • New Default Print Settings for BioMed Black V6 Resin at 50 microns
  • New Default Print Settings for ESD V1 Resin at 50 microns
  • New Default Print Settings for BioMed White V1 Resin at 100 microns
  • New Default Print Settings for Surgical Guide V1 at 50 microns
  • Updated the start temperature for materials to be within 5 ºC of printing
Form 4
Form 3BL
Form 3L
Form 3B/Form 3B+
Form 3/Form 3+
Form 2
PreForm 3.36.2 — May 16, 2024
PreForm 3.36.2 is a recommended update for Fuse 1, Fuse 1+ 30W, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This PreForm update adds support for printing new materials on Form 4/Form 4B and improvements to printing some existing materials on Form 4/Form 4B.
Mac Download: Link
ProductWhat's New
Form 4B
  • New Default Print Settings for IBT Flex Resin at 50 microns
  • New Default Print Settings for Flame Retardant Resin at 50 microns
  • New Default Print Settings for Rigid 4000 Resin at 50 microns
  • Early layer improvements for Fast Model Resin 100 micron and 200 micron Default settings
  • Motion profile improvements for Fast Model Resin Fast Arch 160 micron settings to mitigate printer stalls and print failures
  • Reduced the wiper speed on all materials to prevent resin splashing
  • Reduced the resin fill height by 0.5 mm to prevent resin splashing
Form 4
Fuse 1
Fuse 1+
Form 3BL
Form 3L
Form 3B/Form 3B+
Form 3/Form 3+
Form 2
PreForm 3.36.1 — May 9, 2024
PreForm 3.36.1 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features new Default Print Settings for Form 4 and Form 4B printers, and various bug fixes.
Mac Download: Link
ProductWhat's New
Fuse 1
  • Fixed an issue where PreForm would not remember the last selected printer in some cases
Fuse 1+
Form 4B
  • New Default Print Settings for Surgical Guide Resin at 100 microns
  • New Default Print Settings for BioMed Amber Resin at 100 microns
  • New Default Print Settings for Premium Teeth HT Resin (A2, A3, B2, Bleach) at 100 microns
  • New Default Print Settings for ESD Resin at 100 microns
  • Fixed issue that caused poor raft generation
  • Fixed issue that caused resin to splash in the early layers during print jobs
  • Fixed crash that happened when an unrecognized material was inserted into the printer
Form 4
Form 3BL
Form 3L
Form 3B/Form 3B+
Form 3/Form 3+
Form 2
PreForm 3.36.0 — April 30, 2024
PreForm 3.36.0 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release introduces improvements for Form 4 and Form 4B printers: added support for generating timelapse videos, improved print job generaton times, reduced motor noises at the start of prints, and the ability to send print jobs remotely to Dashboard from anywhere.
Mac Download: Link
ProductWhat's New
Fuse 1
Fuse 1+
Form 4B
Form 4
Form 3BL
Form 3L
Form 3B/Form 3B+
Form 3/Form 3+
Form 2
PreForm 3.35.0 — April 17, 2024
PreForm 3.35.0 is a recommended update for Fuse 1, Fuse 1+, Form 3BL, Form 3L, Form 4B, Form 4, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features added support for Form 4 and Form 4B printers, reduced print time calculations for Fuse 1 and Fuse 1+ 30W printers, and also introduces support for the Form Wash (2nd Generation) in the FormWashCureUpdater package.
Mac Download: Link
ProductWhat's New
Fuse 1
  • Updated printer type filter in Job Setup
  • Reduced the time it takes to calculate print time estimates
Fuse 1+
Form 4B
  • Compatible with firmware 1.1.2 and later
  • Added support for the Form 4B printers
  • Added support for Grey V5 Resin
  • Added support for Clear V5 Resin
  • Added support for White V5 Resin
  • Added support for Black V5 Resin
  • Added support for Precision Model Resin
  • Added support for Fast Model Resin
  • Fixed a bug that caused supports to be removed when using the orientation flyout tool to rotate models along the z-axis
Form 4
  • Added support for the Form 4 printers
Form 3BL
  • Improved the ability to edit settings in the Print Settings Editor
Form 3L
Form 3B/Form 3B+
Form 3/Form 3+
Form 2
PreForm 3.34.3 — March 28, 2024
PreForm 3.34.3 is a recommended update for Fuse 1, Fuse 1+, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features updated Fuse 1+ Nylon 12 Print Settings.
Mac Download: Link
ProductWhat's New
Fuse 1
Fuse 1+
  • Updated Fuse 1+ Nylon 12 Default Print Settings to reintroduce Default v4.0 Print Settings. V4.0 settings were initially released with PreForm 3.33.0 in November 2023.
  • Renamed Fuse 1+ Nylon 12 v5.0 Print Settings to Speed Optimized Settings. V5.0 settings were initially released with PreForm 3.34.0 in February 2024 and included significant print time reductions.
Form 3BL
Form 3L
Form 3B/Form 3B+
Form 3/Form 3+
Form 2
PreForm 3.34.2 — February 22, 2024
PreForm 3.34.2 is a recommended update for Fuse 1, Fuse 1+, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release added support for Elastic 50A Resin V2 and fixed a bug related to the build height increases (from PreForm version 3.34.0) on Form 3B, Form 3B+, and Form 3BL printers.
Mac Download: Link
ProductWhat's New
Fuse 1
Fuse 1+
Form 3BL
  • Compatible with firmware version 2.3.0 and later
  • Added support for Elastic 50A Resin V2
  • Fixed a bug that made it so the Form 3BL did not receive the build height increases expected in PreForm version 3.34.0. This bug was also present in some situations when switching from a Form 3B to a Form 3 or Form 3L to Form 3BL.
Form 3L
Form 3B/Form 3B+
  • Fixed a bug that made it so the Form 3B and Form 3B+ did not receive the build height increases expected in PreForm version 3.34.0. This bug was also present in some situations when switching from a Form 3B to a Form 3 or Form 3L to Form 3BL.
Form 3/Form 3+
Form 2
PreForm 3.34.1 — February 13, 2024
PreForm 3.34.1 is a recommended update for Fuse 1, Fuse 1+, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release fixed a bug that caused print failures when printing with Polypropylene Powder on the Fuse 1+.
Mac Download: Link
ProductWhat's New
Fuse 1
Fuse 1+
  • Fixed a bug that caused print failures when printing with Polypropylene Powder
Form 3BL
Form 3L
Form 3B/Form 3B+
Form 3/Form 3+
Form 2
PreForm 3.34.0 — February 5, 2024
PreForm 3.34.0 is a recommended update for Fuse 1, Fuse 1+, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features reduced file upload and print times when printing with Nylon 12 on the Fuse 1+, added support for taller parts on Form 3 and Form 3L printers, and updates to the manipulator to improve model rotation in the 3D scene.
Mac Download: Link
ProductWhat's New
Fuse 1
  • Fixed group rotations when using text box rotations in the orientation flyout. Groups of parts will now rotate together around the center of the group, rather than independently around each model's center.
  • Fixed free rotate functionality
  • Fixed Model Properties box placement
  • Added firmware update and log download functionality for the Fuse Blast
  • Updated the manipulator to improve model rotation and translation when facing one of the build volume faces head on
  • Added background updater capabilities for Windows installations. This feature can be turned off by going into File > Settings > Update Manager.
Fuse 1+
  • Reduced print times when printing with Nylon 12
  • Reduced warping when printing with Nylon 12
  • Reduced file upload times when printing with Nylon 12
Form 3BL
  • Added support for taller parts. The Form 3BL max build height has increased from 300 mm to 320 mm.
Form 3L
  • Added support for taller parts. The Form 3L max build height has increased from 300 mm to 320 mm.
Form 3B/Form 3B+
  • Added support for taller parts. The Form 3B max build height has increased from 185 mm to 193 mm.
Form 3/Form 3+
  • Added support for taller parts. The Form 3 max build height has increased from 185 mm to 193 mm.
Form 2
PreForm 3.33.3 — January 18, 2024
PreForm 3.33.3 is a recommended update for Fuse 1, Fuse 1+, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features added support for Polypropylene Powder on Fuse 1+ 30W printers, added support for Premium Teeth Resin on Form 3B printers, and promoted Beta Fast Arch Print Settings to Default Fast Arch Print Settings for Grey V4 Resin and Draft Resin at 100 microns on the Form 3 and Form 3B.
Mac Download: Link
ProductWhat's New
Fuse 1
Fuse 1+
  • Added support for Polypropylene Powder
Form 3BL
Form 3L
Form 3B/Form 3B+
  • Added support for Premium Teeth Resin
  • Promoted Beta Fast Arch Print Settings to Default Fast Arch Print Settings for Draft Resin at 100 microns
  • Promoted Beta Fast Arch Print Settings to Default Fast Arch Print Settings for Grey V4 Resin at 100 microns
Form 3/Form 3+
Form 2
PreForm 3.33.2 — January 9, 2024
PreForm 3.33.2 is a recommended update for Fuse 1, Fuse 1+, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release introduces automatic updates for PreForm (Windows only) and various bug fixes for all printers.
Mac Download: Link
ProductWhat's New
Fuse 1
  • PreForm will now automatically update itself in the background (Windows only). To turn automatic updates off, go to File > Settings. Make sure to turn on notifications to know when a new PreForm is available.
  • Fixed behavior of free rotation tool
  • Fixed bug that caused model properties (found by clicking Model List > Model Properties) to appear in random locations on in the 3D scene
Fuse 1+
Form 3BL
Form 3L
Form 3B/Form 3B+
Form 3/Form 3+
Form 2
Older versions
