PreForm software issues and troubleshooting
PreForm print preparation software helps configure 3D files for printing. Always ensure you are running the latest version of firmware and software before attempting troubleshooting. If you are experiencing an error message on a printer's touchscreen, check the support article for your printer to learn more:
Tip:
Download PreForm log files and printer diagnostic logs to aid Formlabs Support in troubleshooting your problem.
Downloading the PreForm log file
To access the PreForm log file:
  1. Open PreForm.
  2. Click Help > Open Log Directory. The PreForm logs folder opens.
  3. Attach the log.txt file when contacting Formlabs Support or your authorized reseller.
To manually access the PreForm log file:
macOS
To download the PreForm log file on macOS:
  1. Hold the Option key on your keyboard, and click the Go menu in the Finder menu bar at the top of the screen.
  2. Select Library from the Go menu (while holding down the Option key) to access the hidden folder.
  3. In Library, select the Application Support folder.
  4. In Applications Support, navigate to /Formlabs/PreForm/Logs/log.txt.
  5. Attach the log.txt file when contacting Formlabs Support or your authorized reseller.
Windows
To download the PreForm log file on Windows:
  1. Press the Windows key + E on your keyboard to open the File Explorer.
  2. Follow the Windows instructions to show hidden files in the File Explorer.
  3. In File Explorer, navigate to C:UsersUSERNAMEAppDataLocalFormlabsPreFormLogs, replacing USERNAME with your local user name.
    • If you're not sure what your user name is, navigate to C:Users to view a list of user names in use on the computer.
  4. Attach the log.txt file when contacting Formlabs Support or your authorized reseller.
For information about printer and accessory logs, see Downloading and sending diagnostic logs.
Software bugs
We are always working to improve our software and appreciate your help in spotting potential problems. If you encounter what you think is a software bug, check if you have the latest version of PreForm software installed. If the bug persists after updating PreForm, contact Formlabs Support or your authorized reseller with details, screenshots of your experience, and information about your operating system, PreForm version, graphics card, and processor. Our support team will resolve the issue as soon as possible.
Software crashing
The most common causes of a software crash are out-of-date graphics card drivers and large STL/OBJ/3MF files. Make sure the file you import is not too large (100 MB or greater). Contact your computer manufacturer to update your graphics card drivers if you are experiencing frequent crashes.
Unable to open PreForm/Application error (Windows)
PreForm gets stuck on splash screen
When you open PreForm, it displays a splash screen with the software version number, copyright information, and a highlighted Formlabs product while it loads. Various software issues can cause PreForm to hang at this splash screen and not finish loading. To resolve this issue:
  1. Uninstall and reinstall PreForm.
  2. Uninstall the current version of PreForm and roll back to a previous version.
  3. Try opening PreForm in compatibility mode.
  4. Use the Windows Program Install and Uninstall troubleshooter to uninstall PreForm and remove any associated registry keys, then reinstall PreForm.
  5. If the issue persists, contact Formlabs Support or your authorized reseller and attach the PreForm log file to your message.
PreForm fails to open with Application Error
As of PreForm version 3.29.0 and later, PreForm requires the installation of Visual Studio 2015, 2017, 2019, and 2022 to support Dental Workspace functionality in Windows. If the runtime library is not installed, PreForm cannot open and displays the error message PreForm.exe - Application Error.
Preform error messaged Application Error
  1. Download and install the latest Visual Studio 2015, 2017, 2019, and 2022 version for X64 architecture.
  2. If the issue persists after downloading and installing Visual Studio, contact Formlabs Support or your authorized reseller.
Update Error (macOS)
Starting with PreForm 3.56, PreForm requires macOS 13 or later. If you are on an earlier version of macOS and try to update to PreForm 3.56 or later, PreForm will display an Update Error message. To resolve this issue, update to macOS 13 or later, then try updating PreForm again. If you cannot update your operating system, you will not be able to update PreForm.
PreForm Update Error
PreForm is slow to open (macOS)
Starting with PreForm 3.56, PreForm requires macOS 13 or later. Some macOS users may encounter an increased load time during the first application launch following the update. This initialization process will occur on the first launch each time you update PreForm (after version 3.56.0) until Formlabs releases a native ARM64 build of PreForm for macOS.
PreForm fails to discover printer
When you install or launch PreForm for the first time, your operating system will confirm if you want to give the program access to your local network. If you dismiss the request, deny access, or the operating system fails to show the request, PreForm will be unable to connect to any networked printers, even if your computer is on the same network as those printers.
If your corporate IT policies prevent you from granting PreForm access to your local network, contact Formlabs Support.
macOS
To grant local network access on macOS:
  1. Click the Apple menu icon in the top-left corner and select System Settings > Privacy & Security > Local Network.
  2. Enable local network access for PreForm.
Windows
To grant local network access on Windows:
  1. Select Settings > Privacy & Security > Windows Security > Firewall & Network Protection > Allow an App through Firewall.
  2. Grant PreForm Public/Private permissions.
    • Only private network permissions are required if your network’s profile is marked as private. To mark a network as private, go to Settings > Network & Internet > Properties (for current network) and change the network profile type.
File import error message
PreForm warns you if an STL/OBJ/3MF file has flipped faces or other irregularities. When detected, the software offers to attempt an automatic repair. Check the support article Preparing a valid model in PreForm to learn more about what features cause a FILE IMPORT or BROKEN MODELS DETECTED error. Changes to the model's mesh may be necessary.
If the repair is successful:
  1. Slice through the model to ensure that there are no unknown values causing holes or other irregularities.
  2. Support your model.
  3. Orient your model.
  4. Save your model as a FORM file.
Graphical issues
A variety of factors can cause unusual graphical issues and artifacts, such as:
  • Models are not rendering in PreForm, or are rendering incorrectly
  • PreForm does not register clicks in the 3D view
  • Text is missing from PreForm
  • White screens, such as the Dashboard login screen
To resolve these issues:
  1. Run as administrator (Windows only): Right-click on the PreForm application and select Run as Administrator. Some computers have security settings which prevent PreForm from running correctly unless run as an administrator.
  2. Reinstall PreForm: Uninstall PreForm and delete the QtWebEngine folder (if present) in C:\Users\USERNAME\AppData\Local\Formlabs\PreForm\ (Windows) or /Formlabs/PreForm/ (macOS). Reinstall the latest version of PreForm.
  3. Use software rendering mode (Windows only)
    1. Navigate to the PreForm installation folder. By default, this is:
      • C:\Program Files (x86)\Formlabs\PreForm (PreForm 3.19.1 and earlier)
      • C:\Program Files\Formlabs\PreForm (PreForm 3.20.0 and later)
    2. Double-click on the PreForm (Software Rendering) application. PreForm launches in Software Rendering mode.
    3. If software rendering mode resolves the issue, update your graphics card drivers.
  4. Update Dell Backup & Recovery (Windows: Dell users only): Some Dell computers come with a utility called Dell Backup & Recovery. A problem with older versions of this program can sometimes crash PreForm. Check for this program and update it if you are using version 1.9.2.8 or older.
  5. Disable antivirus software: Some antivirus software can block some or all of PreForm’s functions. Temporarily disable your computer’s antivirus and/or add an exception for PreForm. If this resolves the issue, you may need to adjust your antivirus settings to allow PreForm to run.
  6. Disconnect from external monitors: Connecting a computer that is running PreForm to multiple or external monitors can affect how PreForm displays, especially if the monitors are of an unusual resolution. Try disconnecting any external monitors and restarting PreForm.
  7. Disconnect your 3D mouse: Connecting a computer that is running PreForm to a 3D mouse can affect how PreForm displays. Try disconnecting the 3D mouse, if present, and restart PreForm.
3Dconnexion 3D mouse not working
3Dconnexion 3D mice may not work correctly with older versions of PreForm due to driver incompatibilities. If you are having issues with your 3Dconnexion 3D mouse, update PreForm to version 3.11 or later.
Offset cursor with multiple monitors
When using PreForm on multiple monitors with different resolutions, the cursor may be offset from the true location on screen. To resolve, close out all instances of PreForm and restart the application. In rare instances where the issue persists, reinstall the latest version of PreForm.
Firmware compatibility
If you update your printer’s firmware after adding a print job to its queue, the printer may be unable to print the job. If a queued job fails to print, remove it from the queue, update update PreForm,and reupload the print job.
Additionally, when updating either PreForm or your printer's firmware, you may be required to update the other to maintain compatibility and be able to print. Keep both PreForm and your printer's firmware fully up to date for best results
If the problem persists after reuploading your print job, contact Formlabs Support or your authorized reseller.
Supports not generating
The most likely reason supports will not generate is out-of-date graphics card drivers. Contact your computer manufacturer to update these and then resume with support structure generation.
Updating firmware and software
Ensure you are using the latest firmware and software versions available.
To view the currently installed version of PreForm:
  1. Open PreForm.
  2. Click Help > About PreForm.
  3. Check the support article PreForm downloads and release notes to ensure you are running the latest version of PreForm.
Tip:
PreForm automatically prompts an update if a new firmware version is available. If an automatic update is unavailable, perform a manual firmware update.
To view the firmware version currently installed on your printer:
  1. On your printer's touchscreen, tap Settings.
  2. View installed firmware:
    • On a Formlabs LFS printer (Form 3 or later), tap Settings > System > Printer Info.
    • On a Form 2, tap Your Printer > Settings > Printer Info.
  3. Check the support article Firmware downloads and release notes to ensure you are running the latest version available.
Tip:
View the support article Updating firmware for Formlabs SLA printers to learn more.
Could not open DFU device
To correct this error:
  1. Ensure that a print is not currently in progress on your printer.
  2. Unplug the printer and wait 30 seconds.
  3. Plug the printer back in.
  4. Save open files in PreForm as a FORM file.
  5. Close PreForm.
  6. Re-open PreForm.
Note:
If PreForm continues to display Could not open DFU device, then the printer may be in DFU mode or your computer is not recognizing the printer. Contact Formlabs Support or your authorized reseller for instructions on how to reload your firmware.
Running in a virtual machine
We do not support running PreForm in a virtual machine. If you want to try running in a virtual machine, make sure you have 3D graphics acceleration turned on for best results.
To enable in VMWare:
  1. From the menu bar, click Virtual Machine > Settings > Display.
  2. Enable Accelerate 3D graphics.
Note:
The virtual machine must restart in order to make this change.
Surface Pro installation
If you are experiencing an issue opening PreForm on your Microsoft Surface Pro:
  • Update your operating system to Windows 8.1 or later.
  • Update your graphics driver directly from the manufacturer's website (e.g., Intel), rather than using the Microsoft updates.
Note:
Future Microsoft updates may replace the manufacturer's drivers.
FL0 generation failed
  1. Clear disk space on your computer.
  2. If your Windows username includes special characters such as accents or Unicode characters, create or log into an account that does not include those characters.
Error 0x80070643 Setup Failed
Error 0x80070643 Setup Failed and the error message "The feature you are trying to use is on a network resource that is unavailable." indicate a corrupted or misplaced installation file on a Windows computer.
  1. Run the Windows Program Install and Uninstall troubleshooter.
    1. Go to Fix problems that block programs from being installed.
    2. Click Download.
    3. Click Run or Open. Follow the steps in the troubleshooter.
  2. Manually browse for the PreForm installation file.
    1. Click Browse in the error message box.
    2. Browse to the path where the .exe is located within the install source media.
    3. If the install package is missing, reinstall the latest version of PreForm.
    4. Continue with the updated installation.
  3. Use the Registry Editor to rectify the installation source path.
    1. Search REGEDIT in the Windows search bar.
    2. Double click Registry Editor. The Registry Editor opens.
    3. Follow the path to HKEY_LOCAL_MACHINESOFTWAREClassesInstallerProducts
    4. Click on each Product until you find the PreForm installation file. Your PreForm installation file may have a different name than in the example.
    5. Right click the malfunctioning PreForm installation file. Select Delete. The computer deletes the malfunctioning PreForm installation file.
    6. Close the Registry Editor.
    7. Restart the computer.
    8. Install the latest version of PreForm.
If the issue persists, contact Microsoft Support.
Calibration step failed
A failed job upload with the message Calibration step failed generally indicates a connectivity problem. To resolve this issue:
  1. Uninstall and reinstall PreForm, then try again. If you have multiple versions of PreForm installed, uninstall all copies and then install the latest version.
  2. If you are trying to upload the job via Wi-Fi, try connecting to your printer via Ethernet or USB instead.
Form 1+ appears disconnected
Sometimes PreForm’s orange Print button may display the disconnected USB icon even when your printer is connected and otherwise recognized as a device. This can happen if you have two instances of PreForm open.
To resolve:
  1. Save your models as FORM files.
  2. Close all instances of PreForm.
  3. Reopen a single instance of PreForm.
Tip:
If you cannot see a second instance of PreForm, open your task manager to check for other instances of PreForm running in the background. Close additional instances.
Alternatively, if you only have one instance of PreForm open, you can restart your Form 1+:
  2. Disconnect the USB cable from your computer.
  3. Unplug the Form 1+ and wait 30 seconds.
  4. Plug the Form 1+ back in.
  5. Reconnect the USB cable into a different USB slot.
Tip:
If the printer remains Disconnected in PreForm, open your device manager to ensure that your computer is recognizing the Form 1+. If it is not recognized, uninstall and then reinstall PreForm.
