To perform a factory reset, tap Settings > System > Factory Reset, then follow the prompts on the touchscreen. To confirm a successful factory reset, tap Queue on the touchscreen. After a successful reset, the print queue is empty.
If you cannot perform a factory reset due to a touchscreen issue, you can force a factory reset using a button on the printer motherboard:
- Turn off the printer using the breaker switch at the back of the machine, leaving the power cable connected to the rear panel.
- Using a 2.5 mm hex driver, loosen and remove the eight 6.0 mm M4 countersunk screws that flank the display along the buffer, top, and hopper sides of the printer.
