Third-party dental resins with available Open Material Mode print settings
Starting January 12, 2026, all new Form 4B and Form 4BL printer packages include Open Material Mode (OMM) by default*. With Open Material Mode, you can print with most 385 and 405 nm photopolymer resin on Formlabs SLA printers, giving you greater flexibility with third-party materials. Please note that if you print with OMM, Light Processing Unit wear and damage will not be covered under your warranty. For more information, see our article on Understanding Light Processing Unit lifetime (Form 4 and Form 4L generation).
Formlabs does not develop or validate print settings for third-party resins. Below is a list of third-party dental resins whose manufacturers have gone through their internal development process and provided print settings for Form 4B and Form 4BL printers with Open Material Mode. Several additional resin manufacturers currently have settings development in progress, but Formlabs does not have control over the timelines and cannot commit to any specific dates.
When printing third-party resins with Open Material Mode, resin must be manually poured into the tank. Print settings are supported by the resin manufacturer, not Formlabs, so consult their documentation for instructions and any questions. For biocompatible applications, always follow the resin manufacturer’s instructions for use and/or manufacturing guidelines to ensure compliant printing and post-processing.
*Users who purchased a Form 4B or Form 4BL package before January 12, 2026 need to purchase the OMM capability separately.
Last updated: August 24, 2026
Resins and print settings
Manufacturer Resin Indication Print setting (FPS) file source Printer
ApplyLabWork DLP SG Clear Surgical Guide Download from ApplyLabWork Form 4B
Flex BT Translucent Indirect Bonding Tray Download from ApplyLabWork Form 4B
Tray Orange Custom Tray Download from ApplyLabWork Form 4B
D-Tech Surgical Guide Surgical Guide Email [email protected] Form 4B
Tryin Denture Try In Email [email protected] Form 4B
Crown & Bridge Temporary Restoration Email [email protected] Form 4B
Crown & Bridge Pro Temporary Restoration Email [email protected] Form 4B
Denture Base Denture Base Email [email protected] Form 4B
Splint Splint Email [email protected] Form 4B
Dentsply Sirona Lucitone Digital Print™ 3D Denture Base Denture Base Lucitone Certification for Digital Print Dentures
Download from Dentsply Sirona
Form 4B
Lucitone Digital IPN™ 3D Premium Tooth Denture Teeth Lucitone Certification for Digital Print Dentures
Form 4B
Lucitone Digital Value™ 3D Economy Tooth & Trial Placement Denture Teeth, Denture Try In Lucitone Certification for Digital Print Dentures
Form 4B
Detax dx direct aligner Direct Aligner Folder of Detax print settings Form 4B
dx direct retainer Direct Retainer Folder of Detax print settings Form 4B
Freeprint Denture Impact Denture Base Folder of Detax print settings Form 4B
Freeprint Denture Denture Base Folder of Detax print settings Form 4B
Freeprint Crown Permanent Restoration, Denture Teeth Folder of Detax print settings Form 4B
Freeprint Splintmaster Taff Splint Folder of Detax print settings Form 4B
Freeprint Splintmaster Flex Splint Folder of Detax print settings Form 4B
Freeprint Denture Flex Pink Partial Denture Folder of Detax print settings Form 4B
Freeprint Denture Flex Clear Partial Denture Folder of Detax print settings Form 4B
Freeprint Temp Temporary Restoration Folder of Detax print settings Form 4B
Freeprint Try-in Denture Try In Folder of Detax print settings Form 4B
Dreve FotoDent denture pink-opaque Denture Base Folder of Dreve print settings Form 4B
FotoDent denture pink-transparent Denture Base Folder of Dreve print settings Form 4B
FotoDent gingiva Gingival Mask Folder of Dreve print settings Form 4B
FotoDent guide - 405 Surgical Guide Folder of Dreve print settings Form 4B
FotoDent tray2 blue-transparent Custom Tray Folder of Dreve print settings Form 4B
FotoDent tray2 green-transparent Custom Tray Folder of Dreve print settings Form 4B
FotoDent tray2 reddish-transparent Custom Tray Folder of Dreve print settings Form 4B
FotoDent TryIn Denture Try In Folder of Dreve print settings Form 4B
Graphy TC-85DAC, TA-28, TR-07 Direct Aligner, Direct Retainer Folder of Graphy print settings Form 4B
TC-80DP, BR-23, R-191 Permanent Restoration, Temporary Restoration Folder of Graphy print settings Form 4B
THD-P1000 Denture Base Folder of Graphy print settings Form 4B
TFDH-P1000 Partial Denture Folder of Graphy print settings Form 4B
TE-151 Splint Folder of Graphy print settings Form 4B
TE-600 Gingival Mask Folder of Graphy print settings Form 4B
SG-100 Surgical Guide Folder of Graphy print settings Form 4B
SC-130 Castable Folder of Graphy print settings Form 4B
TT-BU Custom Tray Folder of Graphy print settings Form 4B
Keystone KeyDenture® Base Denture Base Folder of Keystone print settings
More information from Keystone
Form 4B
KeySplint Soft® Clear Splint Folder of Keystone print settings
Form 4B
Form 4BL
KeySplint Soft® (tinted) Splint Folder of Keystone print settings
Form 4B
KeySplint Hard® Clear Splint Folder of Keystone print settings
Form 4B
NextDent by 3D Systems NextDent SG (Surgical Guide) Surgical Guide Folder of NextDent by 3D Systems print settings Form 4B
NextDent Tray Custom Tray Folder of NextDent by 3D Systems print settings Form 4B
Pac-Dent Rodin BioArch RPD Partial Denture Download from Rodin Form 4B
Rodin Bite Tray Custom Tray Download from Rodin Form 4B
Rodin Denture Base 2.0 Denture Base Download from Rodin Form 4B
Rodin Sculpture 2.0 Permanent Restoration Download from Rodin Form 4B
Rodin Surgical Guide Surgical Guide Download from Rodin Form 4B
Rodin Titan All-On-X Download from Rodin Form 4B
Rodin EnVision Permanent Restoration Download from Rodin Form 4B
Rodin RapidCeram Permanent Restoration Download from Rodin Form 4B
Saremco saremco print CROWNTEC Permanent Restoration Download from Saremco Form 4B
Vita Vita Vionic Dent Resin Denture Teeth, Temporary Restoration Folder of Vita print settings
Download from Vita
Form 4B
Vita Vionic Base Resin Impact Denture Base Folder of Vita print settings
Download from Vita
Form 4B
Vita Vionic Try-in Resin Try in Folder of Vita print settings
Download from Vita
Form 4B
Vita Vionic Base Resin Flex Clear Partial Denture Folder of Vita print settings
Download from Vita
Form 4B
Vita Vionic Base Resin Flex Pink Partial Denture Folder of Vita print settings
Download from Vita
Form 4B
Voco V-Print C&B Temp Temporary Restoration Download from Voco Form 4B
V-Print dentbase Denture Base Download from Voco Form 4B
V-Print Comfort Splint Download from Voco Form 4B
V-Print Splint 2.0 Splint Download from Voco Form 4B
V-Print DT Denture Teeth Download from Voco Form 4B
Zirlux Zirlux Nightguard & Splint – Flexible​ Splint Folder of Zirlux print settings Form 4B
Form 4BL
Zirlux Nightguard & Splint – Rigid​ Splint Folder of Zirlux print settings Form 4B
Note:
Formlabs sells and has validated print settings for specific shades of BEGO™ VarseoSmile® TriniQ® Resin. This is currently the only third-party resin for which Formlabs has formally validated settings. These are available in Preform. To print with other shades with OMM, start by copying the existing Formlabs BEGO™ VarseoSmile® TriniQ® Resin print settings.
Relevant links
