Introduction to PU Rigid Resins
Note:
Formlabs has sunsetted this material, and it is no longer available for purchase. For information about other Formlabs materials, visit Choosing the right resin.
Polyurethane is used for its excellent noise abatement, chemical resistance, and physical properties. Typically, polyurethane parts are made by casting or reaction injection molding. Formlabs PU Rigid Resins are developed with a hybrid chemistry which allows them to be compatible with Formlabs SLA printers.
A collection of parts printed in PU Rigid Resins
Parts printed with Formlabs PU Rigid Resins have extremely high impact strength and the physical properties of polyurethane, making them ideal for end-use applications that are intended to be exposed to harsh conditions.
Read the articles and documents linked below to learn how to handle, print, and store Formlabs PU Rigid Resins.
Note:
To learn more about the performance or specific material properties of PU Rigid Resins, refer to the Safety Data Sheet (SDS) and Technical Data Sheet (TDS). Always consult the SDS as the primary source of information to understand safety and handling of Formlabs materials.
PU Rigid Resin resources
