Using BioMed Durable Resin
BioMed Durable Resin is a clear material for applications requiring impact, shatter, and abrasion resistance. This USP Class VI material is made in an FDA-registered, ISO 13485 facility and can be used in applications for long-term skin (>30 days) and short-term tissue, bone, and dentin contact (<24hrs).
alttext
Recommended for:
  • Patient-specific instruments
  • Single-use instruments
  • End-use devices and components requiring biocompatibility and impact resistance
BioMed Durable Resin prints at 100 microns.
 BioMed Durable ResinBioMed Clear Resin
Ultimate tensile strength (MPa)29.152
Tensile modulus (MPa)9942080
Elongation at break (%)3312
Durometer/Shore Hardness75D78D
Flexural modulus (GPa)0.640.23
IZOD Impact strength (J/m)9835
To learn more about the performance properties of Formlabs resins, refer to the library of material properties data sheets.
Printing with BioMed Durable Resin
  1. Open a model.
  3. Orient according to the manufacturing guide.
  4. Generate supports.
Finishing
The Form Wash agitates the solvent bath and removes parts from the bath after a set time. Wash parts according to the manufacturing guide. Pay particular attention to information that affects mechanical properties or biocompatibility requirements.
Post-curing requirements
BioMed Durable Resin requires post-curing to reach its optimal mechanical properties.
Refer to the support article Form Cure time and temperature settings for post-curing recommendations.
Follow post-curing recommendations from Formlabs for the clearest and best possible results. Improper post-curing can lead to suboptimal mechanical and biocompatibility properties.
Additional resources
