Caution:
Sintering nylon powder produces byproducts such as laurolactam which accumulates within the print enclosure, filter mediums, and exhaust. Proper ventilation is required whenever the printer is operating.
Before receiving your printer and accessory products, prepare a space to install and operate them. Read and understand the instruction manuals and their safety instructions before using the Fuse X1 printer or Fuse Sift X1.
If your product has any visible shipping damage upon delivery, add a note to the shipping receipt or bill of lading. Contact Formlabs Support or your certified service provider and provide photos of the damage, both to the unopened package and its contents.
Footprints
Reserve the following minimum dimensions for the most convenient access:
Environs
Consider the following additional requirements:
Compressed air
For details on each device:
Caution:
Power requirements
| Product | Minimum power requirement | Socket style | Plug style | |
| Fuse X1 |
50 A @ 200–240 VAC 3.5 kW Typ., 7.5 kW Max (at 208 VAC) |
Hardwired |
Power cable not included. Specific cable and termination to be determined by the user in consultation with an electrician. There is a panel on the back of the printer that must be removed, exposing a terminal block. Users can wire in the cable that meets their requirements and local plug type. The wiring must have locally-compliant strain relief where the wire passes into the printer. For more information, see our Fuse X1 electrician hookup guide (EN). |
| Fuse Sift X1 | 20 A @ 120 VAC* 10 A @ 240 VAC* |
IEC C19 |
Cables with the following plug style are included depending on shipping region:
| Fuse Blast | 6 A @ 120 VAC 3 A @ 230 VAC |
IEC C19 |
| Mix Kit X1 | 10 A @ 208–240 VAC | Hardwired | Power cable not included. Specific cable and termination to be determined by the user in consultation with an electrician. The Mix Kit X1 has exposed power wires (rather than a terminal block like the Fuse X1), allowing users to wire in the cable that meets their requirements and local plug type. | |
| Vacuum conveyor |
100–240 VAC |
IEC C19 |
* The Fuse Sift X1 requires an AC circuit capable of powering both the Fuse Sift X1 and the third-party vacuum. Consult the manuals for both units and follow all relevant electrical codes.
Networking requirements
The Fuse X1 has an RJ-45 Ethernet (10BASE-T/100BASE-TX/1000BASE-T) LAN port. Connect with a shielded Ethernet cable (not included): minimum Cat5, or Cat5e or Cat6 for 1000BASE-T.
Additional supplies
Aside from the contents of the printer and Fuse Sift X1 package, you need additional supplies to post-process your printed parts and to clean and maintain the printer and powder recovery station.
Prepare your workspace by purchasing them in advance:
Tip:
More information on supplies, such as personal protective equipment (PPE):
