Using BEGO™ VarseoSmile® TriniQ® Resin
The Form 4 Flex Build Platform is required for printing with BEGO™ VarseoSmile® TriniQ® Resin.
BEGO™ VarseoSmile® TriniQ® Resin is a ceramic-filled material for highly accurate permanent restorative parts, provisional restorative parts, and denture teeth. Use this resin to create precisely fitting permanent single-unit restorations (crowns, inlays, onlays, implant-supported crowns) or up to three-unit bridges with accurate marginal adaptation. This resin can also be used to create provisional single-unit restorations, up to seven-unit provisional bridges, and denture teeth for full or partial removable dentures.
As a Formlabs Certified Material, BEGO™ VarseoSmile® TriniQ® Resin is fully compatible with the Form 4B automated resin dispensing system, the PreForm Dental workspace, and other aspects of the Formlabs ecosystem.
This resin is available in three commonly used VITA shades: A2, A3, and B1.
Note:
To learn more about the performance or specific material properties of BEGO™ TriniQ® Resin, refer to the Safety Data Sheet (SDS) and Technical Data Sheet (TDS). Always consult the SDS as the primary source of information to understand safety and handling of Formlabs materials.
Recommended for:
  • Permanent restorative parts (crowns, bridges up to three-units, inlays, onlays, veneers, implant-supported crowns)
  • Provisional restorative parts (crowns, bridges up to seven-units, inlays onlays, veneers, implant-supported crowns)
  • Denture teeth for full or partial removable dentures
BEGO™ VarseoSmile® TriniQ® Resin prints at 50 microns and 100 microns.
Required resources
Sold by Formlabs:
This is an abbreviated version of the Instructions for Use. Read the guide for detailed instructions about the workflow.
Design guidelines
IndicationDesignPermanent ( > 12 months)Temporary (< 12 months)Design requirement
Single tooth restorations
Fully anatomical single crown in the anterior region
Fully anatomical single crowns in the posterior region
Veneer
Inlay, onlay
Minimum wall thickness for posterior and anterior teeth: 0.7 mm
Minimum wall thickness for veneers: 0.5 mm
Bridge constructionsFully anatomical monolithic bridge constructions for the anterior and/or posterior region, up to 7 units without pontics✔✔
Maximum of one pontic between two abutment crowns
Bridges in the anterior region
Minimum wall thickness occlusal and circumferential: 1.0 mm
Minimum connector cross-section: 14 mm2
Bridges in the posterior region
Minimum connector cross-section: 16 mm2
Fully anatomical monolithic bridge constructions for the anterior and/or posterior region with max. one pontic, up to 3 units
X✔
Fully anatomical monolithic bridge for the anterior and/or posterior region with max. 3 non-neighboring pontics (up to 7-unit bridge constructions)
Artificial teethArtificial teeth for connection with a denture base✔✔Minimum wall thickness: 1.0 mm
Printing with BEGO™ VarseoSmile® TriniQ® Resin
  1. Open a model.
  3. Orient to preserve fine details.
    • Orient crown and bridge patterns with the fitting areas or margins facing upwards to avoid adding supports to the most critical part of the restoration.
    • Orient restorations horizontally, with the occlusal plane facing the build platform.
      alttext
  4. Generate supports.
Shake the resin cartridge for two minutes to ensure the resin is mixed completely.
Washing
Follow the part washing recommendations in the Instructions for Use for the clearest and best possible results. Improper washing can lead to suboptimal mechanical and biocompatibility properties.
Post-curing requirements
BEGO™ VarseoSmile® TriniQ® Resin requires post-curing to reach its optimal mechanical properties. Post-cure according to the Instructions for Use.
Additional resources
