技術白書
Using Flexible 50A Resin
Flexible 50A Resin is an elastomeric material designed for applications requiring high elongation and high energy return. Use Flexible 50A Resin for parts that will bend, stretch, compress, and hold up to repeated cycles without tearing. Elastic is transparent, which makes it well suited for medical models for simulation or education. To learn more about potential applications for this material, read the blog post Introducing Elastic Resin: A Soft, Resilient 3D Printing Material (English only).
Note:
As of June 9, 2026, Elastic 50A Resin V2 has been renamed to Flexible 50A Resin. This better describes its performance relative to other flexible Formlabs resins.
Recommended for:
  • Wearables and consumer goods prototyping
  • Medical models and devices
  • Compliant features for robotics
  • Special effects props and models
Note:
To learn more about the performance or specific material properties of Flexible 50A Resin, please refer to the Safety Data Sheet (SDS) and Technical Data Sheet (TDS). Always consult the SDS as the primary source of information to understand safety and handling of Formlabs materials.
他材料との比較
Elasticity is the ability of an object or material to resume its normal shape after being stretched or compressed. Flexible 50A Resin is designed to “bounce back” and return to its original shape quickly.
Durometer is the hardness of a material. Flexible 50A Resin has a lower durometer than other Formlabs resins, making it suitable for prototyping parts normally produced with silicone. Flexible 50A Resin also has a higher tear strength than comparable materials, making it capable of repeated cycles of use.
See the table below for a comparison of relevant material properties with other engineering resins and with other products:
 Formlabs Flexible 50A Resin, post-curedFormlabs Flexible 80A Resin
Durometer/shore hardness50A80A
Elongation at break (%)160120
Tensile strength (MPa)3.48.9
Tear strength (kN/m)12.324.0
ColorClearClear
Formlabsの各レジンの性能特性の詳細は、
材料特性データシートのライブラリをご覧ください。
Printing with Flexible 50A Resin
備考:
  • 機器の破損を防ぐために、サポート記事Choosing the right material(適切な材料を選定)に記載されているレジンタンクの互換性テーブルを参照し、お使いのレジンタンクに使用予定の材料との互換性があるかどうかを事前に確認してください。
  • まれに、結晶化したレジンやゲル化したレジンがバイトバルブを塞いでいることがあります。レジンが正常に供給されない場合は、手袋をはめた手でバイトバルブをつまみ、詰まりを取り除きます。
Flexible 50A Resin is a unique material that requires more support than some other Formlabs resins. Increase support density for parts with large cross sections, and keep large cross sections closer to the build platform. Avoid orienting parts with merging features-- areas that begin printing separately and then merge together later in the printing process.
  1. Open a model.
  3. Orient to preserve fine details.
  4. Generate supports.
Avoid long unconnected supports when printing with Flexible 50A Resin. Generating isolated supports more than 20 mm long may lead to print failures. Increase support density or add additional supports manually to the model to increase trussing between supports. Supports printed with Flexible 50A Resin normally distort slightly from the force of the peel cycle.
Print feature recommendations
Improve print success with Flexible 50A Resin by designing features according to Formlabs recommendations.
Supported wall thickness
Minimum: 400 microns
Recommended: 600 microns
Unsupported wall thickness
Minimum: 600 microns
Recommended: 800 microns
Shallow angles
Minimum: 19 degrees
Recommended: 45 degrees
Horizontal span/bridge
Maximum: 600 microns
Vertical wire diameter
Minimum: 300 microns
Maximum: 1500 microns
Clearance between adjacent parts
Minimum: 1000 microns
Hole diameter
Minimum: 800 microns
仕上げ
The Form Wash agitates the solvent bath and removes parts from the bath after a set time. Wash parts according to the support article Form Wash time settings. Pay particular attention to information that affects mechanical properties or biocompatibility requirements.
The surface of parts printed with Flexible 50A Resin may feel slightly sticky after washing.
二次硬化の要件
Flexible 50A Resin requires post-curing to reach its optimal mechanical properties.
備考:
このレジンでプリントした造形品を二次硬化するには、ガラス容器に500mL以上の水を入れ、その中に造形品を浸します。部品が完全に水に浸り、表面に気泡がついていないことを確認します。
二次硬化に移る前に、洗浄したパーツが完全に乾くのを待ちます。二次硬化の設定については、Formlabsが提供するサポート記事Form Cure time and temperature settings(Form Cureの時間と温度設定)をご参照ください。
