Formlabs replacement part guides
Over time, your Formlabs product may need service. Replacement parts are available on the Formlabs web store. If your part or product is not listed here, contact Formlabs Support or your authorized reseller.
Installation and usage guides are listed below for each replacement part, along with a store link (where available). Some guides for legacy products are published as PDFs—in those cases, each language is linked separately.
SLA printers
Form Studio 1
Component Store link Guide
Fuse N/A Replacing the Form Studio 1 fuse
LevelSense, camera, and resin tank RFID assembly N/A Replacing the Form Studio 1 LevelSense, camera, and resin tank RFID assembly
Light Processing Unit N/A Replacing the Form Studio 1 Light Processing Unit
Form 4 generation
Backlight Unit
RP-F4-BLT-01
Replacing the Form 4 Backlight Unit
Build platform dovetail assembly
RP-F4-DOVE-01
Replacing the Form 4 build platform dovetail assembly
Build platform handle
N/A
Replacing the Form 4 build platform handle
Camera
RP-F4-CAM-01
Replacing the Form 4 camera
Cartridge floor
RP-F4-DIP-01
Replacing the Form 4 cartridge floor
Cover
RP-F4-COVR-01
Replacing the Form 4 cover
Cover damper
RP-F4-DAMP-01
Replacing the Form 4 cover damper
Cover hinges
RP-F4-HING-01
Replacing the Form 4 cover hinges
Diffuser panel
RP-F4-DIFP-01
Replacing the Form 4 diffuser panel
Leveling feet
RP-FHA-LF-01
Replacing the Form 4 leveling feet
LevelSense board
RP-F4-LVL-01
Replacing the Form 4 LevelSense board
RP-F4-LCD-01
Replacing the Form 4 Light Processing Unit
Light Processing Unit fan
RP-LFAN-01
Replacing the Form 4 Light Processing Unit fan
Light Processing Unit fan filter
RP-F4-BCFTR-01
Replacing the Form 4 Light Processing Unit fan filter
Mixer drive assembly
RP-F4-WP-01
Replacing the Form 4 mixer drive assembly
Motherboard (printer manufactured after 2024-11-15)
RP-F4-MOBO-01
Replacing the Form 4 motherboard (post 2024-11-15)
Motherboard (printer manufactured before 2024-11-15)
RP-F4-MOBO-01
Replacing the Form 4 motherboard (pre 2024-11-15)
Power supply
RP-F4-PSU-01
Replacing the Form 4 power supply
Resin cartridge RFID board
RP-F4-CRFB-01
Replacing the Form 4 resin cartridge RFID board
Resin tank latch
RP-F4-TLTCH-01
Replacing the Form 4 resin tank latch
Resin tank RFID board
RP-F4-CRFB-01
Replacing the Form 4 resin tank RFID board
Resin temperature sensor
RP-F4-RIR-01
Replacing the Form 4 resin temperature sensor
System on module (SOM)
RP-F4-SOM-01
Replacing the SOM
Touchscreen
RP-F4-DISP-01
Replacing the Form 4 touchscreen assembly
Touchscreen ribbon cable
RP-F4-DISPC-01
Replacing the Form 4 touchscreen ribbon cable
Z-axis lead screw
N/A
Cleaning and lubricating the Z-axis lead screw (Form 4 generation)
Z-axis limit switch
N/A
Replacing the Form 4 Z-axis limit switch
Form 4L generation
Backlight Unit
RP-F4L-BLU-01
Replacing the Form 4L Backlight Unit
Camera
RP-F4L-CAM-01
Replacing the Form 4L camera
Cartridge floor
RP-F4-DIP-01
Replacing the Form 4L cartridge floor
Diffuser panel
RP-F4L-DIFF-01
Replacing the Form 4L diffuser panel
Leveling feet
RP-F4L-LVL-01
Replacing the Form 4L leveling feet
LevelSense board
RP-F4-LVL-01
Replacing the Form 4L LevelSense board
RP-F4L-LPU-01
Replacing the Form 4L Light Processing Unit
RP-F4L-LFAN-01
Replacing the Form 4L Light Processing Unit fan
RP-F4L-FLTR-01
Replacing the Form 4L Light Processing Unit fan filter
LPU HDMI cable
RP-F4L-HDMI-01
Replacing the Form 4L HDMI cable
RP-F4L-MXDR-01
Replacing the Form 4L mixer drive assembly
Motherboard
RP-F4-MOBO-01
Replacing the Form 4L motherboard
Power supply
N/A
Replacing the Form 4L power supply
RP-F4-CRFB-01
Replacing the Form 4L resin cartridge RFID board
Resin tank latch
N/A
Replacing the Form 4L resin tank latch
RP-F4-CRFB-01
Replacing the Form 4L resin tank RFID board
RP-F4-RIR-01
Replacing the Form 4L resin temperature sensor
RP-F4-SOM-01
Replacing the Form 4L SOM
Touchscreen
RP-F4L-DISP-01
Replacing the Form 4L touchscreen assembly
RP-F4L-DISPC-01
Replacing the Form 4L touchscreen ribbon cable
Z-axis lead screw
N/A
Cleaning and lubricating the Z-axis lead screw (Form 4L generation)
Z-axis limit switch
N/A
Replacing the Form 4L Z-axis limit switch
Form 3 generation
RP-BP2-HNDL-01
Replacing the build platform handle (Form 2 and Form 3 generation)
Cam lock
N/A
Replacing the Form 3 cam lock
EN
DE
ES
FR
IT
JA
ZH
Cartridge dispense arm
RP-F3A-CDA-01
Replacing the Form 3 cartridge dispense arm
Cartridge dispense spring
RP-F3-DAS-01
Replacing the Form 3 cartridge dispense spring
Cartridge floor
RP-F3-FCF-01
Replacing the Form 3 cartridge floor
Cartridge spring fingers
F3-CSF-01
Replacing the Form 3 cartridge spring fingers
Cover hinges
RP-F3-HING-01
Replacing the Form 3 cover hinges
EN
DE
ES
FR
IT
JA
ZH
Cover
Cover bracket: RP-F3-CB-01
Cover: F3-ASM-000117
Display assembly
Form 3/Form 3+: F3-FD-01
Form 3B/Form 3B+: RP-F3B-DISP-01
Display cable: RP-WL-DISPC-01
Replacing the Form 3 display assembly
Ethernet and USB board
N/A
Replacing the Ethernet and USB board (Form 3 generation)
EN
DE
ES
FR
IT
JA
ZH
Exhaust fan
N/A
Replacing the Form 3 exhaust fan
EN
Heater
Form 3/Form 3B: RP-F3-HTR-01
Form 3+/Form 3B+: RP-F3P-HR-01
Replacing the heater (Form 3)
EN
DE
ES
FR
IT
JA
ZH
Heater cable reseating
N/A
Reseating the heater cable (Form 3)
EN
DE
ES
FR
IT
JA
ZH
Interlock sensor cable reseating
N/A
Reseating the Form 3 interlock sensor cable
EN
DE
ES
FR
IT
JA
ZH
Leveling foot
RP-FHA-LF-01
Replacing the Form 3 leveling feet
LevelSense board
RP-F3-LVS-01
Replacing the Form 3 LevelSense board
LPU: F3-LPU-01
Flex cable: RP-F3-FX-01
Replacing the Form 3 Light Processing Unit
Mixer coupler motor
N/A
Replacing the Form 3 mixer coupler motor
EN
DE
ES
FR
IT
JA
ZH
Mixer coupler inspection
N/A
Inspecting the Form 3 mixer coupler
EN
DE
ES
FR
IT
JA
ZH
Optics test
N/A
Printing the Form 3 optics test
EN
DE
ES
FR
IT
JA
ZH
Rear shell
N/A
Removing the Form 3 rear shell
EN
DE
ES
FR
IT
JA
ZH
Resin spill
N/A
Cleaning after an extensive resin spill (Form 3/Form 3B)
Optical window assembly (roller holder)
F3-RHA-01
Replacing the Form 3 roller holder (optical window assembly)
N/A
Replacing the Form 3 SOM
EN
DE
ES
FR
IT
JA
ZH
Tensioner motor cable reseating
N/A
Reseating the tensioner motor cable (Form 3)
EN
DE
ES
FR
IT
JA
ZH
X-axis lead screw
RP-F3-XDR-01
Replacing the X-axis lead screw (Form 3 generation)
X-axis lead screw cleaning
F3-XACK-01
Cleaning and lubricating the X-axis lead screw (Form 3 generation)
X-axis limit switch
RP-F3-LS-01
Replacing the Form 3 X-axis limit switch
X-axis motor assembly
N/A
Replacing the X-axis motor assembly (Form 3)
EN
DE
ES
FR
IT
JA
ZH
Z-axis force sensor cable reseating
N/A
Reseating the Z-axis force sensor cable (Form 3)
EN
Z-axis lead screw cleaning
N/A
Cleaning and lubricating the Z-axis lead screw (Form 3 generation)
Form 3L generation
Build platform 2L side handles
RP-QRBPL-HDL-01
Replacing the Build Platform 2L side handles
Build platform RFID sensor
RP-F3L-RFID-01
Replacing the Form 3L build platform RFID sensor
EN
DE
ES
FR
IT
JA
ZH
RP-F3A-CDA-01
Replacing the Form 3L cartridge dispense arm
EN
DE
ES
FR
IT
JA
ZH
RP-F3-DAS-01
Replacing the Form 3L cartridge dispense spring
EN
DE
ES
FR
IT
JA
ZH
Cartridge floor
RP-F3L-FCF-01
Replacing the Form 3L cartridge floor
Cartridge spring finger assembly
F3-CSF-01
Replacing the Form 3L cartridge spring finger assembly
EN
DE
ES
FR
IT
JA
ZH
Cover and gas spring
Cover: RP-F3L-CVR-01
Gas springs: RP-F3L-GSP-01
Replacing the Form 3L cover and gas spring
Cover adjustment
N/A
Adjusting the Form 3L cover
EN
DE
ES
FR
IT
JA
ZH
Display assembly
Display: RP-F3L-DP-01
Replacing the Form 3L display assembly
Front heater assembly
RP-F3L-FHTR-01
Replacing the Form 3L front heater assembly
Interior lighting module
N/A
Replacing the right interior lighting module (Form 3L)
EN
DE
ES
FR
IT
JA
ZH
Laser alignment
N/A
Aligning the Form 3L lasers
Leveling foot
RP-F3L-LF-01
Replacing the Form 3L leveling feet
LevelSense board
RP-F3L-LVL-01
Replacing the Form 3L LevelSense board
F3L-LPU-01
Replacing the Form 3L Light Processing Unit
Mixer motor and coupler
Motor: RP-F3L-MXMR-01
Coupler: RP-F3L-MXC-01
Replacing the Form 3L mixer motor and coupler
Optics test
N/A
Printing the Form 3L optics test
EN
DE
ES
FR
IT
JA
ZH
Rear heater assembly
RP-F3L-RHTR-01
Replacing the Form 3L rear heater assembly
Rear intake fan
RP-F3L-RFAN-01
Replacing the Form 3L rear intake fan
EN
DE
ES
FR
IT
JA
ZH
Rear shell
N/A
Removing the Form 3L rear shell
EN
DE
ES
FR
IT
JA
ZH
Extensive resin spill cleaning
N/A
Cleaning an extensive resin spill for the Form 3L
EN
DE
ES
FR
IT
JA
ZH
Resin tank induction sensor
RP-F3L-ISE-01
Replacing the Form 3L resin tank induction sensor
EN
DE
ES
FR
IT
JA
ZH
RP-F3L-RFID-01
Replacing the Form 3L resin tank RFID board
EN
DE
ES
FR
IT
JA
ZH
Resin tank Y-stops
N/A
Replacing the Form 3L resin tank Y-stops
EN
DE
ES
FR
IT
JA
ZH
Resin tank VHB tape inspection
N/A
Inspecting a Form 3L resin tank for signs of VHB separation
EN
Light Processing Unit ribbon cable
RP-F3L-XFLX-01
Replacing or reseating the Form 3L main LPU ribbon cable
EN
DE
ES
FR
IT
JA
ZH
F3L-FR-01
Replacing the Form 3L roller holder (optical window assembly)
N/A
Replacing the Form 3L SOM
EN
DE
ES
FR
IT
JA
ZH
Tensioner motor
RP-F3L-TMTR-01
Replacing the Form 3L tensioner motor
Tensioner motor manual release
N/A
Manually releasing the Form 3L tensioner motor
EN
DE
ES
FR
IT
JA
ZH
Tensioner sensor cable reseating
N/A
Reseating the Form 3L tensioner sensor cable
EN
DE
ES
FR
IT
JA
ZH
X-axis limit switch
RP-F3L-XZLIM-01
Replacing the X-axis limit switch (Form 3L)
EN
DE
ES
FR
IT
JA
ZH
X-hub board
Hub board: RP-F3L-XHUB-01
Short flex cable: RP-F3L-SHFX-01
Replacing the Form 3L X-hub board
EN
DE
ES
FR
IT
JA
ZH
N/A
Reseating the Form 3L Z-axis force sensor cable
EN
DE
ES
FR
IT
JA
ZH
Form 2
ABL nut
F2-HDW-000119
Replacing the Form 2 ABL Nut
EN
RP-BP2-HNDL-01
Button
N/A
Replacing the Form 2 Button
EN
Cam lock spring
F2-ASM-000078
Replacing a Broken Cam Lock Spring
EN
Cam lock
F2-ASM-000078
Replacing the Form 2 Cam Lock
EN
Tuning the cam lock
N/A
Tuning the Form 2 cam lock
EN
DE
ES
FR
IT
JA
ZH
Cartridge floor
F2-ASM-000083
Replacing the Cartridge Floor Assembly
EN
DE
ES
FR
IT
JA
ZH
Cover
F2-ASM-000026
Replacing the Form 2 Cover
EN
DE
ES
FR
IT
JA
ZH
Display assembly
F2-ASM-000008
Replacing the Form 2 Display Assembly
EN
DE
ES
FR
IT
JA
ZH
Galvanometer cable reseating
N/A
Reseating the Form 2 galvanometer cables
EN
DE
ES
FR
IT
JA
ZH
Galvanometer mirror cleaning
N/A
Cleaning the Form 2 galvo mirrors
EN
DE
ES
FR
IT
JA
ZH
Lead screw lubrication
N/A
Lubricating the Form 2 lead screw
EN
DE
ES
FR
IT
JA
ZH
LevelSense grounding screw reseating
N/A
Reseating the Form 2 LevelSense grounding screws
EN
DE
ES
FR
IT
JA
ZH
Limit switch
F2-HDW-000113
Replacing a Form 2 Limit Switch
EN
DE
ES
FR
IT
JA
ZH
Main mirror cleaning
N/A
Cleaning the Form 2 main mirror
EN
DE
ES
FR
IT
JA
ZH
Main mirror
N/A
Replacing the Form 2 Main Mirror
EN
Optical window underside cleaning
N/A
Cleaning the underside of the Form 2 optical window
EN
DE
ES
FR
IT
JA
ZH
Optical window
F2-ASM-000011
Replacing the Form 2 Optical Window
EN
DE
ES
FR
IT
JA
ZH
Optics test
N/A
Printing the Form 2 Optics Test
EN
DE
ES
FR
IT
JA
ZH
Pulley set screw adjustment
N/A
Adjusting the Pulley Set Screw
EN
Resin spill cleaning
N/A
Cleaning an extensive resin spill for the Form 2
EN
DE
ES
FR
IT
JA
ZH
Shell
N/A
Removing and Replacing the Form 2 Shell
EN
DE
ES
FR
IT
JA
ZH
Shuttle motor cable reseating
N/A
Reseating the Form 2 Shuttle Motor Cable
EN
System on module (SOM) board connection
N/A
Reseating the SOM Board Connection
EN
Resin tank spring finger adjustment
N/A
Adjusting the Form 2 Tank Spring Fingers
EN
DE
ES
FR
IT
JA
ZH
Tank carrier
N/A
Replacing the Form 2 resin tank carrier
EN
Wiper belt position adjustment
N/A
Adjusting the Wiper Belt Position
EN
SLA post-processing and accessories
Form Cure V2
Form Cure L V2
Form Cure V1
Form Cure L V1
Form Wash V2
Form Wash L (V1/V2)
Form Wash V1
Base limit switch
N/A
Replacing the Form Auto base limit switch
EN
DE
ES
FR
IT
JA
ZH
Base mount assembly
RP-FA-MT-01
Replacing the Form Auto base mount assembly
EN
DE
ES
FR
IT
JA
ZH
Camera assembly
RP-FA-CAM-01
Replacing the Form Auto camera assembly
EN
DE
ES
FR
IT
JA
ZH
Cover actuator
N/A
Replacing the Form Auto cover actuator
EN
DE
ES
FR
IT
JA
ZH
Gantry drawer slide
N/A
Replacing the Form Auto gantry drawer slide
EN
DE
ES
FR
IT
JA
ZH
Ethernet port
RP-FA-ETH-01
Replacing the Form Auto Ethernet port
EN
DE
ES
FR
IT
JA
ZH
Gantry drive assembly
RP-FA-DSHF-01
Replacing the Form Auto gantry drive assembly
EN
DE
ES
FR
IT
JA
ZH
Tensioning the gantry drive belt
N/A
Tensioning the Form Auto gantry drive belt
EN
DE
ES
FR
IT
JA
ZH
Repairing a slipping gantry pulley
N/A
Repairing a slipping gantry pulley (Form Auto)
EN
DE
ES
FR
IT
JA
ZH
Testing a slipping gantry pulley
N/A
Testing a slipping gantry pulley (Form Auto)
EN
DE
ES
FR
IT
JA
ZH
Motherboard
N/A
Replacing the Form Auto motherboard
EN
DE
ES
FR
IT
JA
ZH
Part removal mechanism belt
N/A
Tensioning the Form Auto part removal mechanism belt
EN
DE
ES
FR
IT
JA
ZH
Part removal mechanism limit switch
N/A
Replacing the Form Auto part removal mechanism limit switch
EN
DE
ES
FR
IT
JA
ZH
Part removal mechanism pulley
N/A
Proactively servicing the Form Auto part removal mechanism pulley
EN
DE
ES
FR
IT
JA
ZH
RP-FA-THD-01
EN
DE
ES
FR
IT
JA
ZH
Fast Cure
Control board
RP-FCU-CTRL-01
Replacing the Fast Cure control board
EN
DE
ES
FR
IT
JA
ZH
LED modules
Left: RP-FCU-LFLED-01
Upper: RP-FCU-UPLED-01
Right: RP-FCU-RTLED-01
Replacing the Fast Cure LED modules
EN
DE
ES
FR
IT
JA
ZH
Motor assembly
N/A
Replacing the Fast Cure turntable assembly
EN
DE
ES
FR
IT
JA
ZH
Power supply
RP-FCU-PSU-01
Replacing the Fast Cure power supply
EN
DE
ES
FR
IT
JA
ZH
Touchscreen
RP-FCU-LCD-01
Replacing the Fast Cure touchscreen
EN
DE
ES
FR
IT
JA
ZH
Resin Pumping System
SLS printers
Fuse 1+ 30W
Air heater
120 V: RP-FS1P-120-HR-01
230 V: RP-FS1P-230-HR-01
Replacing the Fuse 1+ 30W air heater
Air heater RTD
RP-FS1-BRTD-02
Replacing the Fuse 1+ 30W air heater RTD
Buffer trough RTD or heater
RTD: RP-FS1-BRTD-02
Replacing the Fuse 1+ 30W buffer trough RTD or heater
Build chamber external frame gasket
RP-FS1-BG-01
Replacing the Fuse 1 generation build chamber external frame gasket
Build chamber inner gasket
RP-FS1-VSS-01
Replacing the Fuse 1 generation build chamber inner gasket
Build chamber latch spring
RP-FS1P-LTSPR-01
Replacing the Fuse 1+ 30W generation build chamber latch spring
Build chamber plug case
N/A
Replacing the Fuse 1 generation build chamber plug case
Build chamber print bed
RP-FS1-PB-01
Replacing the Fuse 1 generation build chamber print bed
Build chamber socket and cable harness
N/A
Replacing the Fuse 1 generation build chamber socket and cable harness
Display assembly
RP-FS1P-SN-01
Replacing the Fuse 1+ 30W display assembly
Doser assembly
RP-FS1P-DOS-01
Replacing the Fuse 1+ 30W doser assembly
Doser gasket
RP-FS1-DGSK-01
Replacing the Fuse 1 generation doser gasket
Flipper motor assembly
RP-FS1-BSTEP-01
Replacing the Fuse 1 generation flipper motor assembly
Heater control board
RP-FS1-PORO-02
Replacing the Fuse 1 generation heater control board
Hopper LED board
N/A
Replacing the Fuse 1 generation hopper LED board
Hopper powder sensors
RP-FS1-POSE-01
Replacing the Fuse 1 generation hopper powder sensors
Hopper trough RTD or heater
RTD: RP-FS1-BRTD-02
Replacing the Fuse 1+ 30W hopper trough RTD or heater
Interlock board
N/A
Replacing the Fuse 1 generation interlock board
IR sensor flow blody
RP-FS1-IRK-02
Replacing the Fuse 1+ 30W IR sensor flow body
Laser assembly
RP-FS1P-30W-LA-03
Replacing the Fuse 1+ 30W laser assembly
Motor and temperature controller board
RP-FS1-MOTE-01
Replacing the Fuse 1 generation motor and temperature controller board
Nitrogen ball valve
RP-FS1P-NV-01
Replacing the Fuse 1+ 30W nitrogen ball valve
Nitrogen controller board
N/A
Replacing the Fuse 1+ 30W nitrogen controller board
Print enclosure door hinges
RP-FS1-DA-01
Replacing the Fuse 1 generation print enclosure door hinges
Print enclosure door latch and striker
RP-FS1-DA-01
Replacing the Fuse 1 generation door latch and striker
Print enclosure interlock magnets
RP-FS1-DA-01
Replacing the Fuse 1 generation print enclosure door interlock magnets
Quartz tube heater frame
RP-FS1-QTFR-01
Replacing the Fuse 1 generation quartz tube heater frame
Quartz tube heaters
120 V: RP-FS1-120-QT-01
230 V: RP-FS1-230-QT-01
Replacing the Fuse 1 generation quartz tube heaters
Rear access panel gasket
RP-FS1-IEGSK-01
Replacing the Fuse 1 generation print enclosure rear access panel gasket
Recoater motor assembly
RP-FS1-BSTEP-01
Replacing the Fuse 1 generation recoater motor assembly
Recoater roller
RP-FS1-RU-01
Replacing the Fuse 1 generation recoater roller
RFID board
N/A
Replacing the Fuse 1+ 30W RFID board
System on Module
N/A
Replacing the Fuse 1 generation SOM
Upper laser window
RP-FS1-ULW-01
Replacing the Fuse 1 generation upper laser window
Z motor and drive assembly
RP-FS1-ZMTR-01
Replacing the Fuse 1 generation Z motor and drive assembly
Fuse 1
Air heater
120 V: RP-FS1-120-AHTR-01
230 V: RP-FS1-230-AHTR-01
Replacing the Fuse 1 air heater
Air heater RTD
RP-FS1-BRTD-02
Replacing the Fuse 1 air heater RTD
RP-FS1-BG-01
RP-FS1-VSS-01
N/A
RP-FS1-PB-01
N/A
Display assembly
RP-FS1-SN-01
Replacing the Fuse 1 display assembly
Doser assembly
RP-FS1-DOSE-01
Replacing the Fuse 1 doser assembly
Doser gasket
RP-FS1-DGSK-01
RP-FS1-BSTEP-01
RP-FS1-PORO-02
Hopper gasket
RP-FS1-HGSK-01
Replacing the Fuse 1 hopper gasket
Hopper LED board
N/A
RP-FS1-POSE-01
Hopper trough RTD
RP-FS1-BRTD-02
Replacing the Fuse 1 hopper trough RTD
Interlock board
N/A
IR sensor flow body
RP-FS1-IRK-02
Replacing the Fuse 1 IR sensor flow body
RP-FS1-MOTE-01
Power supply
RP-FS1-PSU-01
Replacing the Fuse 1 generation power supply
RP-FS1-DA-01
RP-FS1-DA-01
RP-FS1-DA-01
RP-FS1-QTFR-01
Quartz tube heaters
RP-FS1-IEGSK-01
RP-FS1-BSTEP-01
Recoater roller
RP-FS1-RU-01
RFID board
N/A
Replacing the Fuse 1 RFID board
System on Module
N/A
Upper laser window
RP-FS1-ULW-01
RP-FS1-ZMTR-01
SLS post-processing and accessories
Fuse Sift
Fuse Blast
