Formlabs replacement part guides
Over time, your Formlabs product may need service. Replacement parts are available on the Formlabs web store. Many repair guides and other instructions are available in this article. Parts not appearing in this article must be provided by Formlabs Support or your authorized reseller.
Form 4 generation
ComponentAvailable languages
Backlight UnitENDEESFRITJAZH
Build platform dovetail assemblyENDEESFRITJAZH
CameraENDEESFRITJAZH
Cartridge floorENDEESFRITJAZH
Cartridge RFID boardENDEESFRITJAZH
Cover damperENDEESFRITJAZH
Cover hingesEN
CoverEN
Diffuser panelENDEESFRITJAZH
Leveling feetENDEESFRITJAZH
LevelSense boardENDEESFRITJAZH
Light Processing Unit fanENDEESFRITJAZH
Light Processing Unit fan filterENDEESFRITJAZH
Light Processing UnitENDEESFRITJAZH
Mixer baseENDEESFRITJAZH
Mixer drive assemblyENDEESFRITJAZH
Motherboard (printer manufactured before 2024-11-15)EN
Motherboard (printer manufactured after 2024-11-15)ENDEESFRITJAZH
Power supplyEN
Resin tank latchENDEESFRITJAZH
Resin tank RFID boardENDEESFRITJAZH
Resin temperature sensorENDEESFRITJAZH
Touchscreen assemblyENDEESFRITJAZH
Touchscreen ribbon cableENDEESFRITJAZH
Z-axis limit switchENDEESFRITJAZH
Form 4L generation
CameraEN
Leveling feetEN
Form 3 generation
Build platform handleENDEESFRITJAZH
Cam lockENDEESFRITJAZH
Cartridge dispense armENDEESFRITJAZH
Cartridge dispense springENDEESFRITJAZH
Cartridge spring fingersENDEESFRITJAZH
Cover hingesENDEESFRITJAZH
CoverENDEESFRITJAZH
Display assemblyENDEESFRITJAZH
HeaterENDEESFRITJAZH
X-axis lead screw cleaningENDEESFRITJAZH
Z-axis lead screw cleaningENDEESFRITJAZH
Leveling footEN
Mixer coupler motorENDEESFRITJAZH
Mixer coupler inspectionENDEESFRITJAZH
Optics testENDEESFRITJAZH
Rear shellENDEESFRITJAZH
Extensive resin spill cleaningENDEESFRITJAZH
Optical window assembly (roller holder)ENDEESFRITJAZH
System on module (SOM)ENDEESFRITJAZH
Tensioner motor cable reseatingENDEESFRITJAZH
X-axis limit switchENDEESFRITJAZH
X-axis motor assemblyENDEESFRITJAZH
Z-axis force sensor cable reseatingEN
Form 3L generation
Build platform RFID sensorENDEESFRITJAZH
Cartridge spring finger assemblyENDEESFRITJAZH
Cover and gas springENDEESFRITJAZH
Cover adjustmentENDEESFRITJAZH
Front heater assemblyENDEESFRITJAZH
Laser alignmentENDEESFRITJAZH
Leveling footENDEESFRITJAZH
Mixer motor and couplerENDEESFRITJAZH
Rear heater assemblyENDEESFRITJAZH
Rear intake fanENDEESFRITJAZH
Resin tank induction sensorENDEESFRITJAZH
Light Processing Unit ribbon cableENDEESFRITJAZH
Tensioner motorENDEESFRITJAZH
Tensioner motor manual releaseENDEESFRITJAZH
Tensioner sensor cable reseatingENDEESFRITJAZH
X-hub boardENDEESFRITJAZH
Z-axis force sensor cableENDEESFRITJAZH
Resin Pumping System
Pump tubeENDEESFRITJAZH
Form Wash
Display assembly (1st Generation)EN
Display assembly (2nd Generation)ENDEESFRITJAZH
Elevator/lift plate (2nd Generation)ENDEESFRITJAZH
Impeller (1st Generation)ENDEESFRITJAZH
Impeller (2nd Generation)ENDEESFRITJAZH
Impeller motor and magnetic clutch (1st Generation)EN
Impeller spacer (1st Generation)EN
Inner lid assembly (2nd Generation)ENDEESFRITJAZH
Outer lid assembly (2nd Generation)ENDEESFRITJAZH
Outer lid hinge (1st Generation)EN
Form Wash L
Form Cure
Motor assembly (1st Generation)EN
Form Cure L
Heater moduleENDEESFRITJAZH
LED module cooling fanENDEESFRITJAZH
LED moduleENDEESFRITJAZH
Fuse 1
ComponentSKUAvailable languages
Air exhaust filterEF-FS1-01EN, DE, ES, FR, IT, JA, ZH
Air heater 120V
Air heater 230V
RP-FS1-120-AHTR-01
RP-FS1-230-AHTR-01
EN
Air heater RTD temperature sensorRP-FS1-BRTD-02ENFRITJAZH
Air intake filterIF-FS1-01EN, DE, ES, FR, IT, JA, ZH
Build chamber external frame gasketRP-FS1-BG-01ENDEESFRITJAZH
Build chamber inner gasket (Build chamber volcano sheet seal)RP-FS1-VSS-01EN
Build chamber lead screw cleaning kitRP-FS1-LSCK-01ENDEESFRITJAZH
Build chamber print bedRP-FS1-PB-01ENDEESFRITJAZH
Display assemblyRP-FS1-SN-01EN
Doser assemblyRP-FS1-DOSE-01EN
Flipper motorRP-FS1-BSTEP-01EN
Hopper trough RTD temperature sensorRP-FS1-BRTD-02EN
IR sensorRP-FS1-IR-01EN, DE, ES, FR, IT, JA, ZH
IR sensor flow bodyRP-FS1-IRK-01EN
Laser assembly EN
Motor and temp board (Motempbo)RP-FS1-MOTE-01ENFRITJAZH
Optical cassetteOC-FS1-01EN, DE, ES, FR, IT, JA, ZH
Post Rock boardRP-FS1-PORO-02EN
Power supplyRP-FS1-PSU-01EN
Quartz tube heaters (120 V)
Quartz tube heaters (230 V)
RP-FS1-120-QT-01
RP-FS1-230-QT-01
ENDEESFRITJAZH
Quartz tube heater frameRP-FS1-QTFR-01EN
Recoater motorRP-FS1-BSTEP-01ENDEESFRITJAZH
Recoater rollerRP-FS1-RU-01EN
RFID boardRP-F3L-RFID-01EN
SOMRP-FS1-SOM-01EN
Upper laser windowRP-FS1-ULW-01ENFRITJAZH
Z-motor and drive assemblyRP-FS1-ZMTR-01EN
Fuse 1+ 30W
Air heater 120 V
Air heater 230 V
RP-FS1P-120-HR-01
RP-FS1P-230-HR-01
EN
Buffer trough RTD temperature sensorRP-FS1-BRTD-02EN
Build chamber build frame gasketRP-FS1-BG-01ENDEESFRITJAZH
Display assemblyRP-FS1P-SN-01EN
Doser assemblyRP-FS1P-DOS-01EN
Laser assemblyRP-FS1P-30W-LA-03EN
Nitrogen ball valveRP-FS1P-NV-01EN
RP-FS1-120-QT-01
RP-FS1-230-QT-01
ENDEESFRITJAZH
SOMRP-FS1-SOM-01EN
Fuse Sift
Display assemblyRP-SFT-DP-01EN
Doser assemblyRP-FS1-SDOS-01EN
HEPA air filterHF-FS1-01EN, DE, ES, FR, IT, JA, ZH
MixerRP-FS1-SMIX-01EN
MotherboardRP-SFT-MOBO-02EN
Power supplyRP-SFT-PSU-01EN
Sieve/sifter mesh 150 micron
300 micron
SV-FS1-01
SV-FS1-02
Sifter flangeRP-SFT-SRK-01EN
Fuse Blast
DisplayRP-FB-DISP-01EN
Door windowRP-FB-WIND-01EN
HEPA air filterRP-FB-HFTR-01EN, DE, ES, FR, IT, JA, ZH
Hopper mesh
Fuse Blast Polishing hopper mesh
RP-FB-HMSH-01
FS1-FB-PMM-01
